Question about Sony Computers & Internet
I recently installed more memory. When I pull up the computer info it shows the new memory, but I keep getting the message that my memory is very low. Can you tell me what went wrong or maybe something I didn't do that I should have?
  • MICHELLE DELUNA Aug 24, 2010
    Thanks madhatter639 for your quick response. I followed your instructions (I have Windows XP), but when I tried to reset the new numbers my computer would not let me. The response was "There is not enough space on this drive for the paging file size specified." Then I was instructed to clear more disk space on that drive or lower the file size. Kind of a catch 22.
    Sergeant:
  • 260 Answers
Most likely this means "virtual memory", and not the actual RAM. I don't know what operating system you are using, but these directions should walk you thru the steps of changing your virtual memory size if you're using Windows XP, Vista, or Windows 7. 1) Go to Computer (My Computer in Widows XP). 2) Right-click and choose Properties. 3) Choose Advance System Settings (just labeled "Advanced" in XP). 4) Click on the Settings button in the "performance" area. 5) Choose "Advanced" Again. 6) Click on the "Change" button in the "virtual memory" area. 7) Make sure to click\highlight the drive you want to use for virtual memory. 8) Make sure that the dot next to "Custom size" is filled in. 9) Increase your Initial Size and Maximum Size by adding 1024 to whatever number is in the box for each category, then click "Set", Then click "OK", then click "Apply" if its not grayed-out. 10) Reboot your computer.
This should resolve the problem of your memory being low.
Posted on Aug 05, 2010
  • madhatter639
    madhatter639 Aug 24, 2010
    Then it sounds like you don't have a memory issue at all. Either your hard drive is full or you have some kind of bug in your computer that is making Windows believe that it is full. In computer lingo: "Memory"= RAM (Random Access Memory); which is the go-between from your hard drive & CPU. Memory (RAM) fit into slots on your motherboard. They look like long, skinny boards with ICs or what alot of people would call micro-chips on them. "Storage"= Disc Space (Hard Drive); which is where every program in your computer is stored. Everything runs from the hard drive, and all the files & folders you save are kept on the hard drive. When the hard drive gets full things tend not to run properly because the programs in your computer don't have enough disc space to run. You only have 2 options if your hard drive is near maximum capacity: 1) Search thru all of your files and folders and start deleting the ones you don't need or want anymore. 2) Buy a larger hard drive and transfer all of your stuff over to that.
Lost driver & installer
hello
due to the fact that this memory card is no longer available, Kingston does not have drivers fo this card . As a matter of fact SD cards normally do come with drivers , as they are conformed in a way that operating systems recognise them once you plug them into the SD slot
i hope this inofrmation helps you make a decsion
some background on this particular SD memory card you have
SDCZ2-512-A10-KT (Discontinued) Description: 512MB USB 2.0 DataTraveler I write up to 3MBps Discontinued Additional Info: DataTraveler I USB 2.0 Flash Drive Write up to 1.5MBps Read up to 6MBps Mfgr's System P/N's: SDCZ2-512-A10 (Kingston) Form Factor: USB Flash Memory Warranty: 5 Yrs†
here are some solutions .
When the problem occurs is a clue as to the cause.
For example, your response to a memory error message depends on whether:
  1. You have just bought a new computer.
  2. You have just installed new memory.
  3. You have just installed new software or a new operating system.
  4. You have just installed or removed hardware.
  5. Your computer has been running fine and you've made no other recent changes.
UNEXPECTED PROBLEMS
If your system has been running fine, but suddenly starts to produce memory errors, and crash or lock up frequently, the chance of a hardware failure is more likely, since configuration and installation problems show up as soon as the computer turns on. Sometimes you can get memory problems if your computer is overheating, if you are having a problem with your power supply, or if corrosion has developed between the memory module and the socket, weakening the connection.
HANDLING SPECIFIC PROBLEMS
Here is a list of the most common ways the computer informs you of a memory problem.
  1. The computer won't boot, merely beeps.
  2. Computer boots but doesn't recognize all the installed memory.
  3. The computer boots but the screen is blank.
  4. The computer reports a memory error.
    1. Memory mismatch error
    2. Memory parity interrupt at xxxxx
    3. Memory address error at xxxxx
    4. Memory failure at xxxxx, read xxxxx, expecting xxxxx
    5. Memory verify error at xxxxx
  5. The computer has other problems caused by memory.
    1. The computer intermittently reports errors, crashes frequently, or spontaneously reboots.
    2. Registry Errors
    3. General-protection faults, page faults, and exception errors
Nov 07, 2010 | Kingston (SDCZ2-512-A10-KT)...
My computer with windows xp after a while dumps its memory
First off, have you installed any new hardware or software/drivers recently?
Random memory dumps are caused by out-dated or incorrect drivers, or malfunctioning hardware.
In most cases you can reference an error message by going into your event logs using
start, run
type
eventvwr.msc
Click on system or application
Dr Watson is a program in windows xp that is used to diagnose these error messages. Look at this link
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/drwatson_overview.mspx?mfr=true
Jul 30, 2010 | Microsoft Windows XP Home Edition for PC
I have just installed a new hard disc in my samsung x05 but keep getting an error message coming up saying windows (xp) has been shut down etc then kernel_data_inpage_error, followed by atapi.sys - address...
Well if it does that you should make sure all media is unplugged from the computer. If you have the Windows XP Original Release disk insert it and re-install Windows XP. If still says the same error "operating system not found" take it to a computer specialist near you or go on another computer and contact www.microsoft.com, thats all I can say.
Apr 07, 2010 | Samsung X05 Notebook
We are getting a message on our GPS that memory is low and we need to move stuff to our storage .HOW DO WE DO THIS? There is no info on the screen and when we reset it it comes back as before, we can't put...
does yours have a memory card slot on the right side? if so u can upgrade that memory card and transfer the info from the old to the new by putting the info on a computer with a card reader then putting the info from the computer to the new bigger memory card. i would get like more than double the current memory. cards are fairly cheap these days.
Sep 15, 2009 | Navigon 2100 Portable GPS Receiver
I have a Dell Inspiron 6000. I was recently
Remove the drive by turning the computer upside down and take the screw out between the battery and the memory cover (next to a padlock symbol). Insert the screw driver into the little notch in the plate next to where the screw was and slide it towards the drive. The drive should now pop out. Boot the computer. Shut the computer down and reinsert the drive and reboot.
Aug 28, 2009 | Dell Inspiron 6000 Notebook
No network adapter after restarting computer
Go to the computer manufacturers web site and put in the product number for your computer, then when you have the info on your computer up, you should see a link for support or software and drivers, when you are on the drivers page, look for networking drivers and download.
Apr 04, 2009 | Dell 430-0008 Network Adapter
Printer keeps saying insert memory card
The message is not an error message and does not indicate an issue with the product. The message is designed to be an invitation to print photos from a memory card. Follow these steps to insert a memory card into the product. For more information please check the link bellow: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01436439&cc=us&lc=en&dlc=en&product=3194498 Good Luck
Aug 21, 2008 | HP Photosmart C6280 Printer
Windows XP: Blue Screen of Death
Hi are you connecting the usb devices b4 or after windows has started? what version of windows r u running?
Do the usb devices come with their own driversand software?
Dec 18, 2007 | Dell INSPIRON 6000 CENTRINO...
Computers & Internet Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
