Question about KDS Radius RAD-9p 19" Flat Panel LCD Monitor
I have this monitor and a bunch of misc power packs and video cords. I need to make sure I'm going to use the right power pack for this model RAD-9p, therefore I want to identify the right power pack. The one I think belongs to this monitor has a label ADP (Asian Power Devices) Model No. DA-60F19 DC output 19Vdc - 3.16A. Is this the right power pack?? if not can you supply the info that should be on the back of the right power pack - Thank you, Paul Rotondi
4 Suggested Answers
SOURCE: KDS Rad-9p wont stay on
my monitor will not work it will come on when the pc is cut on but it will not display
Posted on Sep 02, 2008
  • 1684 Answers
SOURCE: RAD-9p shuts off for no reason
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Corporate Computer
Over 21 years of computer and printer support/repair
Posted on Jul 23, 2009
  • 748 Answers
SOURCE: RAD 9p shutting off Have checked all capacitors
The capacitors need to checked with an ESR meter. Althought capacitors sometimes bulge when they go bad this is not always true. Capacitors change value internally very easily when the conditions are right. High heat.
You can send this to my company for repair or if you need more help go ahead and email me.
Posted on Jul 24, 2009
Show me how and where to hook up power cord, to charge battery for camcorder, omni2
many camcorders have a power pack that attaches to the camcorder and then the battery attaches to the power pack you can also put the plug in and run the camcorder when everything's attached
Feb 26, 2015 | Video Cameras
GEM GL 1821A black out
at first i would have said it was the video card in your comp,
but if you have tried it on other computers then that cant be the problem.
So if we no its deffinatey not the video card then it is going to be one of two things.
the first thing is its going to be the power pack over heating thid does happen from time to time and can be resolved by replacing the power adaptor this is the cheaper sollution as long as this is the problem,
The other problem it could be is a solder problem because if the monitor comes on everytime and then switches off the chances are if it is not the power pack then it is going to be a bad solder on one of the resistors this is also a common problem with monitors and television.
Now the problem you have got is do you replace the power pack hoping it is that over heating, but if you do this and it is not this that is to fault then you have wasted your money on a power pack that you dont need but hopefully can get a refund on.
Or do you look at the other option a bad solder this is also not very expensive to repair but without knowing what your looking for and without the equipment to check the resistance and finding where the bad solder is.
If you have tried a different power pack then the problem is going to be a bad solder now you can do this yourself but could take ages to find the fault yourself and buying equipment also expensive.
If you can buy a power transformer on the basis you can take it back if this is not the problem i would try this first but make sure you can get refund if it makes no difference.
If you have the equipment to do it yourself and you know aht you are looking for then this should be inexpensive just the price of some solder aslong as you have all equipment if you dont then take to repair shop tell them the problem and they should fix this for a small fee would be alot cheaper than replacing the monitor let me know what you want to do.
If you are capable of doing this yourslef you will need spec sheet but not having an idea what you are looking for will mean you wont find the problem and alot of people totally destroy the unit trying to repair themselves let me know
Nov 28, 2007 | 3G Technology GL1821a (Black) 18 in. Flat...
EMachine Desktop Computer
Hi there.
Remove the power cord from the back of the computer, take the side panel off the computer so you can see the motherboard, take out the system memory, looks like this >>>>
get a clean, dry soft paintbrush and clean the brass contacts and the slots that the memory (ram) goes into of dust and any other foreign objects.
When you are satisfied that all the dust has gone reseat the memory back into the slots making sure they/it clips into place nice and tight, put back the side panel, plug the power cord back in and try to restart the PC.
Good luck and thanks for using FixYa!!
May 24, 2009 | E-Machines eMachines Desktop PC
Sanyo CLT2054 - power cord has light but when I plug it into the
OK you need a volt meter to check the voltage output of your power pack as two things cause this now enough power out the pack to run your unit or the unit has a short both problems will unlight the light so you need to know if the power supply is working right first as it should say like 120 volts AC in and 12 volts DC 1000 ma out so you will need to mesure this with a volt meter. this is a common problem loading the load of the curcuit as in your TV is mor the the power pack is giving out thus shorting out the power pack of any voltage present, as the little LED light your seeing only takes 5 volts at very ittle current to light and dose not repersent the total voltage output of the power pack itself
May 16, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Need A/V cord for Sony TRV68
i have a sony TRV 12 E which is not getting switched on even by AC power and even when i remove the batt pack. can this happen if batt pack is fully discharged? should i change the batt pack.?
Oct 20, 2008 | Sony Handycam CCD-TRV68 Camcorder
My psp wont turn on!
    Confirm the system is not in HOLD mode
    Make sure the PSP system is not in Hold Mode (in the down position). Slide the Power/Hold switch up to clear Hold Mode. Or try sliding the Power/Hold switch up and holding it there until the power indicator light turns off and the PSP system is completely turned off. Then try turning the PSP on again.
    • Confirm the backlight is ON
      Make sure the LCD screen's backlight is not turned off. If it is, press any button to turn ON the backlight.
    • Confirm use of only licensed products (AC Adaptor, battery pack and charger)
      The AC Adaptor, battery pack and battery charger must be licensed for use with the PSP system. All licensed products for use with the PSP will have the following logos displayed directly on the product and/or the packaging:
      pslogor.gif global_logos_psplogo_168x35.jpg global_logos_scealogowhite_60x73.gif
      If any of the products you are using does not have these logos on them, we recommend that you immediately discontinue the use of these products, as they void the PSP system's warranty, and can cause damage to the system. See compatible peripherals for the PSP system for a full list of supported products.
      There are some products that can be used with the PSP system that may not display our logos. Products such as San Disk 1GB Memory Sticks, or various USB cables, needs only to be genuinely certified. Look for the genuine certified logos on these products or contact the company which manufactures these products for more information.
    • Confirm the battery pack is correctly inserted
      Make sure the battery pack is in its proper position (see inserting the battery pack for details).
    • Try the battery pack only
      Unplug the AC adaptor from the PSP system. Make sure a charged PSP battery pack is inserted inside the PSP system. Turn on the unit. If you get power, then the problem may be with the AC adaptor and power cord.
    • Try the battery pack in a different PSP system
      If possible, try your PSP battery pack in a different PSP system. If your battery works on a different PSP system, it may indicate an issue with your PSP system.
    • Try a different PSP battery pack
      If possible, try a different battery in your PSP system. If a different battery pack does work on your PSP system, it may indicate an issue with the original battery pack.
    • Try the AC adaptor and the PSP battery pack
      Insert the battery pack and plug in the AC adaptor. If you still do not get any power, your PSP system may need to be sent in for service (see PSP Service for details).
    • Try the AC adaptor / power cord only
      Turn off the PSP system, unplug the AC adaptor, and remove the battery. Now plug in the AC adaptor to the PSP system with the battery removed. Confirm the AC adaptor and power cord are firmly connected to each other. Now make sure they are also firmly connected to the PSP system and the electrical outlet.
      If the PSP system powers on, the battery may need to be replaced.
    • Check AC adaptor and power cord for damage
      Visually inspect the AC adaptor and the power cord for damage. Do not use if frayed, cut, or damaged in any way.
    • Check the electrical outlet
      Confirm the electrical outlet that you are using is active (receiving power). Try using a different electrical outlet.
    • Try a different AC adaptor and power cord
      If possible, try a different AC adaptor and power cord. If a different AC adaptor and power cord does not work, the PSP system may need to be sent in for service (see PSP Service for details).
    • Confirm no unauthorized system software or downloads were used
      Confirm that you have not used any unauthorized system software updates or downloads on the PSP system. Use of such unauthorized firmware updates voids the warranty and can damage the PSP system.
    • WLAN turned off
      Make sure the wireless (WLAN) network function is not in use while charging. The battery pack cannot be recharged when the WLAN function is being used.
    • Power surge
      If you experienced a power surge, shortage, or a lightning storm in your geographical area recently, this may have affected the PSP system's power supply. Please contact Consumer Services below for information.
    Sep 03, 2008 | Sony PlayStation Portable (PSP) Console
    Power Cords for a monitor
    Most monitors take this one. However, a lot of LCDs take a specialized power pack / power cord. If this isn't the one, please supply your monitor model and I can find you the right one.
    Jun 28, 2008 | Computers & Internet
    Monitor doesn't work
    When you got the pc, you should have been given a starter pack with some CD-ROM's in the pack, one of them should be the drives for the monitor, you might need to use anothermonitor to see the instructions, but the basic graphics card should power the monitor enough to set things up, until then you won't be able to adjust the settings.
    Apr 17, 2007 | Kogi L7CH Monitor
    KDS Radius RAD-9p 19" Flat Panel LCD Monitor Logo
    78 people viewed this question
    Top KDS Computers & Internet Experts
    Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
