Question about Maytag MSD2351HEB 33" 23 Cu. Ft. Side-By-Side Refrigerator w/ Dual Cool System & PuriClean II Water/...
I have a MSD2351HEB Side-by-Side that the freezer all of the sudden stopped working. I checked the coils and they all seem fine. The fridge side seems to be working properly. There is an occasional buzzing noise coming from the refrigerator. It is not all of the time, just every so often. Lights and everything else work.
    Genius:
  • 1,478 Answers
Check the thermostat for temperature setting. Also check the condenser coils and clean them if found clogged with dust. Unplug the freezer and wait for a couple of hours before plugging it again. If you can hear it running or whining, perhaps the compressor is being overheated. Test various components such as temperature control knob, evaporator fan, defrost timer, compressor relay, overload protector and the compressor motor.
Check the thermostat for temperature setting. Make sure your freezer is not too stuffed and that there is enough space for air flow. Check for the restriction of air flow in the vents. Clean the coils of the condenser if found clogged. Also look out for clogged drain tube and if there is a leakage of the refrigerant. Test various components such as temperature control knob, evaporator fan, defrost timer and the door switch.
Take care.
Posted on Aug 05, 2010
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Freezer works fine, fridge is not cold enough
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Jul 19, 2011 | Maytag MSD2351HEB 33" 23 Cu. Ft....
Refrigerator Side not working freezer working fine
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 17, 2011 | Maytag MSD2351HEB 33" 23 Cu. Ft....
Freezer is working fine but fridge isnt cool ,stat seems fine, checked damper in top back of fridge and it is open
The evap coil is most likely frozen over inside the freezer. If it is, it is either the defrost thermostat, defrost control or defrost heater at fault.
Nov 10, 2010 | Amana DRS2663B Side by Side Refrigerator
GSS25KGMB CC side by side GE fridge not cool.
You should check first to see if the condenser coil is dirty ( condenser coil is the Fin type coil you see in front of the compressor ) You can clean this by just brushing it out with a brush .The relay is plugged directly onto the compressor
May 17, 2017 | GE GSS25KGMBB / GSS25KGMWW / GSS25KGMCC...
Fridge side is not cooling, freezer side is fine
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 08, 2009 | Refrigerators
Fridge not cold freezer is fine
Your defrost element is faulty, this is attached to the bottom of the freezer coils and also has a defrost limiting thermodisc which should be replaced at the same time. You are getting a freeze up and therefore no air circulation. Also check that the fanmotor is ok.
Mar 04, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Samsung RCS21DCNS Side by Side
probly the evaporator coil in fridge all frozen up you need to pull all the back out inside the fridge section and defrost with air drier
Sep 21, 2007 | Samsung RS2630SH Side by Side Refrigerator
Maytag MSD2351HEB 33" 23 Cu. Ft. Side-By-Side Refrigerator w/ Dual Cool System & PuriClean II Water/... Logo
54 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
