Question about Sewing Machines
My PE750D isnt picking up the bobbin thread and ripping the material, any ideas?
    New Friend:
  • 194 Answers
Hi,...either the needle is bent or damaged or the machine is not in time anymore. Try a new needle and see if that works. If it is the timing, it is time tosee a serviceperson.
Doug
Posted on Aug 05, 2010
My thread keeps getting tangled and it isnt feeding the material through any ideas
Ok. A machine cannot work unless it is threaded perfectly from the first thread guide to the opening in the needle. Guidelines for threading will be in your manual. A rule of thumb is never allow the thread to crisscross. And, usually machines are threaded progressively from the right to left, or left to right. No back and forth. The top thread guide determines which direction to begin from.
Feb 15, 2015 | Sewing Machines
My sisters singers brand new Athena sewing machine she just started jusing about 5 or 6 times just stopped picking up the bobbin thread and sewing thread in the material. It is just leaving holes in
Needs a new needle right way around, most likely. And check the threading on both bobbin and top of the machine. It makes a big difference which way the bobbin turns in the bobbin case.
Jan 14, 2014 | Brother CS-8150 Computerized Sewing...
Machine just quit picking up bobbin thread and sewing in the material. It is just making holes in the material.
Needles need to be replaced every 2-8 hours of sewing time, on average, or about 1 needle per garment. A needle that has hit the presser foot or needle plate is "dead", and needs to be replaced to (and eventually, you'll need to buff out the rough spots on the presser foot, and needle plate).
Common causes of skipped stitches (stitching that looks like
_ _______ _ _ _______ _ _____________ instead of _ _ _ _ _ _) or of not picking up the bobbin thread are: dull or damaged needle, needle in backwards, needle not fully up in the needle clamp, needle too small a size for the thickness of fabric, dirty machine, misthreaded machine, and way, way, way down on the list, machine out of time.
Jan 14, 2014 | Singer Sewing Machines
Bottom thread not picking up!!
try turning the bobbin the opposite direction and if that doesn't
help the it would be a good idea to have the machine serviced..
May 15, 2013 | Brother PE-150V Computerized Sewing...
John Lewis mini sewing machine
This was really helpful for me fixing my daughter a John Lewis (janome) mini sewing machine, and now can get the bobbin thread up again, however, when you sew, the thread is not staying in stitches, just coming off the material completely. I tried forcing the gears on one more time but then it didn't pick up the bobbin thread again so went back to the other gear position. Any ideas of what to try and get it stitching again? Thanks
Apr 02, 2013 | Janome Mini Compact
My stitches are regular for the most part and then the stitch will be anywhere from 1/4 in to 1 inch. The stitching is very sporatic. It seems to work on cotton but I have a problem with pul material. I'm...
With any stitch problem, always a good idea to re-thread the machine - top and bobbin also - making sure the threads go into their correct tension areas. The next best stand-by "cure-all" is to replace the needle. Use one appropriate to the project being sewn. There are different size needles for finer through to heavy materials, and different needle types for lingerie fabric, regular cotton, denim, stretch etc.
Jun 15, 2010 | Sewing Machines
Bobbin thread will not pick up
Ensure the bobbin thread is mounted on correctly and using your right hand turn the gear that makes the needle go up and down until it catches the thread.
Apr 08, 2010 | Necchi 3102 Mechanical Sewing Machine
I've tried cleaning the machine, re-threading the
Its still under warranty best bring it back sounds like a broken needle or tread knot.
Aug 16, 2009 | Sewing Machines
Not picking up the bobbin thread
Make sure the needle is facing the right way. If it's in backwards it won't pick up the bobbin thread.
Jan 04, 2009 | Baby Lock Esante
Sewing Machines Logo
16 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
