Question about Kenmore 24 in. 15689 Built-in Dishwasher
My dishwasher will wash, but will not drain. None of the water used is draining out. It is now leaking out of the sides of the appliance. What can I do?
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasherMy dishwasher will wash, but will not drain. None - 2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Aug 05, 2010
Hi, I have a Maytag Mdb8959sas dishwasher that was leaking during a normal wash cycle. I pulled the dishwasher out from under the counter and saw that it appears to be leaking directly below the point...
I will assume that you have cleaned gasket around door and at washer. Quite often a build up of scale at lower gasket surfaces is all that is causing leak.
Feb 19, 2014 | Dishwashers
Drain pump runs non-stop. Continues when dial is in Stop position. When disconnected for hours, drain pump starts immediately when power restored. In any wash cycle position, drain pump runs and cycle...
sounds like the flood switch has activated.
You will have to drag the dishwasher out from under the counter after turning off the power to it. Tilt to one side so that any water collected under it is expelled. This will free up the flood switch. Wait about 30 minutes and turn the power back on.
There could be a leak of some sorts from the door seal or hoses which is causing the water to collect.
Hope this solves the problem. It is unclear why none of the lights are lighting up to show a fault condition.
Nov 09, 2010 | Miele 23 in. Novotronic G841 Built-In...
Water not draining after wash. Checked the troubleshooting guide and none apply to problem. It seems like the pump isn't running.
Have you purchased a new food waste disposer for the kitchen sink area? If so, make certain if you are draining the dishwasher directly into the food waste disposer, that you have removed the plug from the food disposer. Or you may be correct that the water pump is inoperable due to an obstruction or basic malfunction. Contact an appliance service company.
Apr 14, 2010 | Bosch 23 in. SHU33A Built-In Dishwasher
After washing don't pump out water and blinking lights
Hi.
You will need to disconnect appliance from power, to access the pump hose located in the lower side of the tub, and to undo the pump hose, so to remove eventual blockage.
If there is no blockage, then the impeller pump may need replacement.
If the drain system works, but you get some water after draining, Check also the water level sensing device.
You usually have a floater sensor, and often a pressure switch located on the drain system.
Spares for most appliances available here: Appliance Parts
Or try: Appliance Parts Pros.
Regards.
Nov 20, 2009 | GE Adora GHDA654LBG Dishwasher
Water not going into dishwasher. We turned off the water temporarily because we first had a leak. Fixed the leak and tried the dishwasher. It would not drain, the garbage disposer was clogged. We put in a...
Is the drain attached directly to the side of the disposal? If so, you didnt take the "knock out" out. Where the drain goes for the washing, there is a block in case the house does not have a washing machine. U need to knock this out with a screwdriver and whatever (plyers or hammer). Not tough to do. Good luck
Jul 09, 2009 | Hotpoint 24 in. HDA2000Z Built-in...
Water leaking
Check the fill hoses to check for tightnes, also check the other: Washer in the fill hose end, facult connection, drain hose in drain, drain pluged. If none of these, call a appliance repairman for help if cannot solve the other yourself. Hope this might help.
Jun 02, 2009 | Whirlpool LSR9434PQ Top Load Washer
Won't drain standing water
If it leaks from the sides it is overvilling, in that case check the water level switch.
If it leaks from the bottom check the water level.
Then check the drain hose connected to the pump, see if it is blocked.
If the drain lines are ok then the pump is not starting.
Double check that water level is OK.
The pump is tested by energizing. If the pump is working then it can be wiring to timer control or timer control board.
Test and repairs must be done by qualified pesonnel.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
May 02, 2009 | Maytag Dishwashers
Water slowly filling cabinet when dishwasher is off.
either
leaking valve - to check, turn water off and see if it still happens
or
if appliance is plumbed in to a spigot on the sink trap, then when you empty sink, some of the water finds its way into the dishwasher via the drain hose. to cure, take the drain hose as high as possible under the sink in a swan neck
Oct 08, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Water leaking into washer
is the drain plumbed into a spigot on the sink trap? if so this may be the source of water coming in when appliance not in use.
take the drain hose as high as possible in a swan neck under the sink and see if this cures it.
other possibility is a leaking inlet water valve but would expect fault then not to be intermittant
Aug 28, 2008 | Kenmore Elite 45986 Front Load Washer
Dishwasher Leaking
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom
of the dishwasher, the following instructions probably apply to you.
But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the
entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from
leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher,
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly.
You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the
rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten
or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues
to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the
dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the
leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Aug 27, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore 24 in. 15689 Built-in Dishwasher Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
