Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
When trying to set a cycle on the salt water system, three beeps sound when the up button is pressed. Ditto for the down button. I can't get past this to set a cycle. Any thoughts?
  • 297 Answers
Try unpluging and and wait a few minutes to reset.
If that does not work if your system is less than 2 years old and you have the receipt you can call intex for a free replacement
They will e-mail you a form fill it out and fax back to them
You will have a new unit at your door in a few days
Posted on Aug 05, 2010
I have a salt water pump 8110. It won't go pass start up and when I push the left button it just keeps beeping. It will not let me unlock the keys to set timer. I have already unplugged for 10mins....
Okay... Let's do this step by step...
1st... Press the down arrow button until you hear the beep and let it go quickly..
2nd ..Press the up arrow button until you hear the beep and let go quickly..
At this point, the LED reading should be blinking 00.. If it is, you have unlocked the keys and you can now press the up arrow button to increase the timer to 01, 02 and up to 12. Note: To adjust the time, press the up arrow button in short intervals, do not hold down the button. It tends not to adjust if you hold down the button longer than 1 sec.. I hope this helps and it not a bad unit.. If it did, please post a comment and rate.. really appreciated...
Aug 08, 2011 | Intex Automatic Salt Water System for ...
I do not have my user manual for my intex saltwater system, I bought it and used it last summer. I forget how to set my system and it is beeping like mad right now. I just want to run the filter system to...
Alright I imagine you have it hooked up already if its beeping at you. A couple of things to ensure first. One is a PCV pipe that has a electrical connection going to a T at the top. On that section of PVC pipe there should be an arrow. Ensure that arrow is pointing in the same direction as the stationary PVC pipe that contains the titanium plates. Now Ensure that you r filter pump is Supplying water to your salt water system. So it should be pool to filter pump to salt water system back into the pool. Now in order to program your salt water system you need to lift the screen protector. Press the left (down arrow) until you hear a short beep then press the right button (up arrow) until you hear another short beep. You just unlocked the keys, now you need to set the hours of operation by pressing the up arrow. For 2000gal pool you want to set for 2 hours if it is 68 to 97 degrees out. anything higher run it for 3 hours. For a 4000gal pool you want to run it for 5 hours if its 68-82 degrees. 6 hours from 84-97 degrees and 7 hours if its hotter than that. Once you have the hours set the machine will automatically start (ENSURE THEFILTER PUMP IS ON). You can relock the keypad by press and holding the down arrow button until it beeps then the up arrow button. A green chlorine light should light up within the next 5 minutes, which indicates the saltwater system started the chlorine production.
Jul 24, 2011 | Intex Automatic Salt Water System for ...
When trying to set my salt water system the down button works but when I push the up button it doesn't set the pool to 00
Are you holding the up arrow long enough Push hard and steady ti'll it beeps
Then it is short pushes on the up arrow to set time
Then down and up again to lock it
It will take 2-10 minutes for the second light to come on and start generating
Jul 19, 2010 | Intex Automatic Salt Water System for ...
Operating instructions
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?source=intexstore
press and hold down arrow till it beeps
press and hold up arrow till it beeps
now use up arrow to select hours to run
now down again till beeps
and then up again till it beeps
wait 2-10 minutes for second green light to come on
Jun 06, 2010 | Intex Automatic Salt Water System for ...
Cant get the salt water pump started
Hold the left button until it beeps. Hold the right button until it beeps. You should see flashing 00. Set the time by moving the right button. Then hold down the left button for a long beep. Then hold down the right button for a long beep.
May 29, 2010 | Intex Automatic Salt Water System for ...
How do i set my salt water generator?
Hold the down button until it beeps, then hold the up button until it beeps. Now its ready to be set. push the up button to the desired amt of time you want the system to run. Once you have the time set, hold the down button until it beeps then the up button until it beeps. Now its locked and ready to go!
May 26, 2010 | Intex Automatic Salt Water System for ...
How do you set the panel on a salt water intex pump mdl no.8110 and how much salt do use
to set the system, hold the down button until it beeps, then hold the up button until it beeps. Now the system is ready to set. Push the up button to the desired number of hours you want it to run. Now, hold the down button until it beeps, then the up button until it beeps. It should be locked and ready to start working.
Without knowing how large your pool is, I can't give you an exact amount of salt to use. If you know how many gallons your pool holds the formula is Gallons x 0.025 = pounds of salt to start up. When you need to add salt, its gallons x 0.0067 = pounds of salt to add when needed.
May 20, 2010 | Intex Automatic Salt Water System for ...
I can't get the (Intex) salt generator to time set. It just stays on 88.
Did you attempt to unlock the keypad before trying to set the time? In case you didn't, these would be the proper steps:
Unlock the keypad by pressing and holding the "down arrow" for 5-seconds until you hear a long beep and then the "up arrow" for 5-seconds until you hear a long beep.
Set the number of hours you want it to run by adjusting the time display using the "up arrow" or "down arrow" until you have the correct number of hours.
After setting the time re-lock the keypad by pressing and holding the "down arrow" for 5-seconds until you hear a long beep and then the "up arrow" for 5-seconds until you hear a long beep. Several minutes later the Green LED should come on indicating the cycle has started.
Jul 06, 2009 | Intex Automatic Salt Water System for ...
After going thru the Start up set up our Intex
After setting the time did you remember to re-lock the keypad by pressing and holding the "down arrow" for 5-seconds until you hear a long beep and then the "up arrow" for 5-seconds until you hear a long beep? Several minutes later the Green LED should come on indicating the cycle has started.
Jul 03, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
128 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
