Question about Goodman GMS90703BXA Heater
I live in canada and when my furnace comes on the burners are so loud but there is something you can take out of the burners
    President:
  • 1,515 Answers
Hi, if the burners are loud when it fires up, it sounds as though the gas pressure is not set properly at the inlet and outlet side, to much gas. Call out you local gas company and tell them you think you smell gas. This will get them rolling. Even if you don't, they will come out and check the inlet and manifold pressures as well as a gas leak even though you don't have one. It takes a special gauge to set the pressures and just bring this up to them after they soap it up for leaks. This is free of charge to you. I have had many customers do this. That's the problem, to much gas will cause it to be very loud. Let me know the out come on this and please rate me and be kind as I know you will. You need to get them out any way as to high of pressure can be dangerous.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Posted on Aug 06, 2010
Our Gibson KG7TC060D24B "tries" to start, but the shuts off before ignition. Technicians have replaced the control panel and other components but the problem persists, with the furnace working for a few...
This is possible, however it is possible they are missing something simple. I hope you can follow along.
1) Is this a Sealed Combustion Furnace, meaning you cannot get to the burners even after you remove the Door Panels?
2) If yes, is this furnace vented with pvc/plastic piping?
3) If yes, do both pipes go outside?
4) If yes then try this.
1) Turn the main power off to the furnace
2) Remove the Door Panel to the burner section.
3) Turn Furnace back and turn the thermostat all the way up.
4)Look into the burner compartment and tell me if the igniter glows red. If it does and the goes out with the burners not coming on.
5) If you feel comfortable or know of someone that is.
6) Turn the furnace off, remove the panel that conceals the burner compartment.
7) Turn the furnace on, if the igniter glows red and the burners ignite. Your problem is in the venting system. Most likely the intake pipe if it goes outside. It could be plugged or something is blocking it. If the burners do not ignite the next thing to make sure that is happening is that the Exhaust blower is operating and you can feel air outside where the pipe terminates. If you it is but no very strong, then your problem could be the inducer motor or to small of vent pipe.
If you could, send me some information about how it starts up
1) Main blower may come on and shut off, make sure the blower runs in on position 1st then back to Auto position. If it does not, you have another problem.
2) The Exhaust blower should come on next
3) About 17secs. later the igniter should glow red.
4) You will here the gas valve make a click
5) The Burners will ignite
6) The flame sensor rod on the far left hand side of the burner will keep the burner lit. If it is dirty the burners will shutdown.
7)About 90secs. later the main blower will come on.
Oct 26, 2013 | Gibson KG7TC060D24B 60,000 BTU 95.1% Gas...
Coleman evcon furnace
So the furnace will come on and heat sometimes ? Then other times it will click but not heat ?
Check for fault codes if it has them and make sure it is clean inside burner tubes and clean the flame sensor.
Oct 13, 2013 | Heating & Cooling
I have an old coleman furnace we use at our hunt camp.Last year we were there and the furnace started to ingnite under the burner and make a loud bang. It blew the pilot out it was so loud and hard. What...
Neil, usually when this happens, it's due to delayed ignition. What happens is the gas is released from the burner, but is not ignited in a timely manner. That's why there was a loud bang, when it did ignite and blew the pilot out. Clean the interior of te furnace, particularly the firebox chamber will help. A shop vac with a hose, brush & crevice tool attachments will help in cleaning it. Also, use a can of compressed air with a straw nozzle (like you clean your computer with) to blow out the pilot tip and the surrounding pilot assembly. Vacuum the burner(s) thoroughly, as they may be partially clogged with dust, lint and spider webs.
Competing all of the above, should help solve the problem. Doing it on a regular basis, is good routine maintenance.
Hope this helped and thanks for choosing FixYa.
Aug 15, 2011 | Heating & Cooling
Our furnace began making a loud band during ignition of the gas. This only happens once in a while.
An obvious sign of a dangerous situation !!!!
Please don't risk lives for the sake of a few dollars. This condition could cause an explosion if not addressed by a certified technician, a.s.a.p. Shut it down and call someone ! It might only be a cleaning of the burner, so don't risk your lives. You have to agree to the repair and price before they can do it, so if you think it's unreasonable, call in another.
Mar 31, 2011 | Heating & Cooling
Furnace seems loud when burners ignite like a small "woof" didnt always do that seems to be something new. Checked all venting nothing obstructed. Had gas presure checked it is LP input is 10...
Depending on the age of the unit the gas pressures should be fine. The first thing I would do is to give the burners a thorough cleaning and make sure pilot is clean if so equipped. I would shut furnace off and remove the burners for easier and better cleaning. Use a wire brush to lightly clean openings on the burners,and gently tap inlet end of burners on soft wood block or thick cardboard pad to clean soot and rust from inside the burners. Also blow out with air if you can.
I always do one burner at a time and put them back in the order they were removed in. When you get everything back together and furnace lit then you can loosen retaing screws on air baffles if needed to get the best looking cleanest flame possible.Flames should be tight on the top of the burners with nice blue flame with sharparrow points with just a little yellow on the very tip.
I hope this helps you. Thank you
Jan 10, 2011 | Heating & Cooling
Desa TD 104 Patio Gas heater
Sounds like you may not be getting enough gas up to the main burner. Bugs, such as spiders, love to make homes out of the main supply lines. Does your pilot light burn blue, and strong? If not, it may need to be cleared of the obstruction. Also, when opening the the gas tank valve, are you opening it slowly?
Feb 08, 2009 | Desa International TD104 Patio Heater
Loud humming noise
when was last time furnace was serviced --air filter change burner area cleaned vacuumed the hum can be a few reasons ---fan bearing need service [ oiled ] fan bracket bushings damaged or loose --burner out of adjustment burning improper etc these are a few
Jun 03, 2017 | Heating & Cooling
Intertherm furnace
On the oil burner is an air intake adjustment that will adjust the air flow that will reduce the soot. It sounds like they are not adjusting this properly.
Oct 16, 2008 | Intertherm P3RA-048K Air Conditioner
Furnace burners wait too long to come on
Sounds like the burners need to be removed from the furnace and cleaned thoroughlyto help with gas distribution if these are in-shot burners they look sort of like an air plane, they have a cross over tube on each side of each burner and if that is rusted up the gas will not distribute evenly from one burner to the next if the pilot and burners go off at the same time then it sounds like you may have some flame blow back maybe due to soot build up in the heat exchanger. Overall sounds like your furnace could use a good servicing
Oct 03, 2007 | Heating & Cooling
Goodman GMS90703BXA Heater Logo
80 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
