SOURCE: problems with Whirlpool dishwasher model GU1500XTKB0
will these units (silo and jtrip) start back on their own? if so, it is likely they are heating the water.
otherwise it sounds like a logic board, unless there is a defective door switch or sensor issue.
electronics seem to be a recurring problem with whirlpool.
i would ask whirlpool (electorlux) to either buy it back or fix it.
good luck
mark
have they checked the thernals on the bottom of the tub
SOURCE: No power to dishwasher; checked breakers they seem
you need to check the power only:
1- check the power come to the wall right ,if not
get elecricity man to bring it to plug in the wall
2- check the cord of m/c if it has fuse check it
and replace with same values ampers,....so on
3- if problem still check electricity reach at end of cord if not ,chang cord
4- if you still have problem inform us
>be ware of electricale chock it is your your life> thanks from me m abba
SOURCE: close door, no lights come on, no sign of power.
There is a fuse on your main control board that comes off and can be replaced somewhat easily. Start by TURNING OFF THE POWER. Open the door down to the floor and take a torx(or starhead) screwdriver and remove every screw (10 of them usually) along the left hand side & right hand side of the inner door panel. Upon removing the screws on both sides it will free the outer door panel which can easily be removed by lifting the door back up to a closed position and pulling the top of the panel outward then lift up towards the ceiling and it should slide right off. Push the door back down to a fully open position (door back to the floor)and remove the 4 screws along the top which will free the control panel. Inside you will see a cover that covers the control board and has some arrows on it pointing to some pushtabs. You may be able to unlock these with your finger or get a screwdriver and just pry each one while pulling the cover up. Now you should see your main control board and your fuse, which is attached to the side of the control. It always helps to use your replacement fuse to compare it with. Before trying to yank the fuse off, gently pull the ribbon cable off from the left side of the board. Then go a little more to the left and you will see 2 more release tabs on the side of the board. Pry the tabs back and pull the whole control board upwards and it should pull up an out. With the board out it should be easy to identify the fuse clipped to the side. Use a flathead screwdriver to pry in between the plastic casing on the board and the fuse clip and slide the new one in its place. Always replace the fuse according to manufacter instructions, once removed improper install will lead to a premature failure of the fuse and you will get to do this all over again.
SUDS DETECTION
During Drain Routine
During the Drain Routine, the water level is checked continuously. Normal drain will occur until the
pressure switch senses no water in the wash tub and there is no foam (suds). The drain pump will
operate an additional 15 seconds after the pressure switch reports no water or foam.
If the drain routine operates for four (4) minutes and the pressure switch senses any foam (suds) in
the wash tub, the Central Control Unit will start the "Kill-Foam" Routine. (See description of this
Routine below.) After the Kill-foam Routine is concluded, the Drain Routine will restart. If, after
four (4) minutes the pressure switch still senses foam in the wash tub, the Central Control Unit will
go into Failure Mode. The digital display will show, F02.
During Spin (Extract) Routine
During the Spin/Extract Routine the water level is checked continuously. If, during this routine, the
pressure switch senses the presence of foam (suds) in the wash tub, the Central Control Unit will
stop the drive motor and the basket will stop spinning. The electronic control will count the number
of spin repetitions that are attempted due to foam (suds). There are a maximum of three (3)
attempts for each Spin/Extract Routine.
Kill-Foam Routine
1. The Remaining Time counter is stopped.
2. The digital display shows Sud.
3. The Drain Pump is turned OFF.
4. The Central Control Unit will fill the wash tub with 1 gal. (4 L) of cold water.
5. While the tub is filling the basket will tumble 1 sec. ON/15 Sec. OFF.
6. Once the tub is filled, the drive motor will turn OFF and the basket will rest without any
movement for five (5) minutes.
7. After the five (5) minute rest, the remaining time counter will restart and the digital display
will show the remaining time left in the routine.
NOTE: If the Kill-Foam routine was initiated during a Spin/Extract Routine, the tumbling action
will be reduced to a cycle of 3 sec. ON/13 sec. OFF. If, at the end of either the Drain or Spin/
Extract Routines, a suds condition still remains, the digital display will show Sud.
Sud will also be displayed for a short period at the end of a cycle, if a Suds condition was
detected during the cycle. This will alert the consumer to reduce the amount of detergent in
subsequent uses.
