Question about Nikon EM 35mm SLR Camera
Film will not wind when you take a picture it unwinds
  • kakima Aug 05, 2010
    On a Nikon EM? The EM has a manual film advance. Are you saying the film goes backward when you pull the film advance lever?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Having received no response in over a month, I assume this is no longer a problem.
Posted on Sep 19, 2010
My Nikon N60 wont load film. I load the film but it doesnt wind the film, but when i take a picture it rewinds it. I dont know what im doing wrong
Hi. Pay careful attention to the way the end of the film fits through the take-up reel. Open the back (empty) and give the wind knob a few twists. That will tell you which way it is turning. Put the end of your film through the slot in the take-up reel so itd winds onto itself as it advances. There's usually enough extra unexposed wound onto the factory reel that it won't cost you and pix at the end of it. Pull enough out of the cassette to be sure your winding-load position is really going to hold when you advance. Good luck.
Oct 30, 2016 | Nikon N60 35mm SLR Camera
How do you load it
To open back cover lift knob on top of camera ( this knob has a small arm that unfolds - used in rewinding).
Once open you will see which side is the film side ( under this knob) and the take up side. On the film side raise the knob again in order to insert film case, the top of this should flip over later used to rewind film. with film trail out toward back of camera. Now push the knob down. Film should only be loaded one way so the knob can be lowered into film canister. Lower knob and Film canister is now secure.
Next thread film leader onto take up spool. Some times these have a slot , but most Just have the teeth that fit the film edge.thread the film into slot then unto teeth. You will need to use film advance arm (There should be an arm on the top opposite side of film knob) you would move that would advance film.
as you move this arm ( with cover open ) film holes should engage the teeth on bottom and top. ( if you can't advance after 1 or 2 advance arm swings) press take picture button ( releases springs).
continue until film is captured top and bottom. Use the film spool knob gently wind film back into canniester until snug don't over wind. Close cover, take a picture with lens cap on, repeat that. As you wind ,the film cartridge knob should rotate.
You are not wasting pictures film was designed for this waste.
you should know how many photos were on film 12/24/36 pictures.
you may have a knob to set to that number.
When your ready to remove film ,push silver button on bottom and use winder handle ,rotating until free and easy. Open cover mention earlier.
wow can't believe I remembered all that and hope that helps.
Sep 23, 2016 | Photography
The film did not automatically rewind after the last shot. How do I get the film to reqidn without exposing it and losing pictures.
You'll have to do it manually. Take the camera into a totally dark and lightproof room: if you can see anything at all in the darkness then it's not dark enough.
Open the camera back and remove the film can. Wearing clean lint free gloves, gently but firmly pull on the film to slowly unwind it from the take up spool, as you do so turn the spigot on the film can to wind it back in.
Note that on a manual wind camera, you would have been able to press a rewind button to disengage the film take up sprocket gears, but on your you can't. If the film seems at risk of tearing then try pulling it out at a right angle to the back of the camera. This ensures that you're not pulling it back over the sprockets and it should then come out quite easily. If your film is likely to contain important and irreplaceable images then you may wish to buy 12 or 24 exposure cheap film and borrow another 35mm camera to practice the method I've recommended in the light where you can see what you're doing.
Sep 20, 2011 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
My film in Canon ae 1 came out blank :S
I would say either the film didn't wind properly as it was going along,or the shutter isn't working properly.Did it make the whirring noise like it was winding after you took a picture?If you can,try taking a picture with the door open,no film,and see if the shutter moves.If it does open,it's probably the winder which pulls the film after a picture is taken.Good luck!
May 01, 2010 | Canon Photography
Film has not rewound but has 'reverted' to showing
On the toplate of the camera, to the left hand side, is a button which slides to the left. It is marked with a film cassette outline, and two arrows to the left <| <|
At any time, you can use this button to rewind the film back into the cannister. It should make a whirring noise for 5-10 seconds, and will stop automatically.
If it makes no noise, you may have a flat battery, or the film may already be rewound.
You can insert new power (battery) without affecting the film cassette, if need be.
However, if really unsure, then:
1) Slide the rewind button to rewind(i.e. to the left).
2) Familiarise yourself with where the back opening latch is.
3) Go into a pitch black room. Preferably under a quilt in a pitch black room.
4) Open the back and take out the cassette. If it comes freely, its probably fully rewound. If its still attached to the take-up spool by film, then (holding the film by the edge only) pull on the film to release it slowly from the take up spool. Whilst it can be quite a tug, they are designed to let go of it "under protest". (Do not pull it so hard that you strip the gears, but fairly firmly).
5) Using the spool winder on the top of the cassette, wind the trailing film back into the cannister. If you've never seen a 35mm cassette, then in the dark one end has an elevated round part, the other end has a void into the cassette. You can tell the elevated part, and start winding - it should only wind one way and feel like its winding onto the reel (wind the other way and it feels like its unwinding - even in the dark!)
6) Only when you are sure film is in the cannister, can you turn on the light.
Films are very sensitive to light, so if you do not feel comfortable doing this procedure in total darkness, go to a photo processing store who will do this for you, usually for no charge (other than the hope you'll let them process the film). They put your camera in a sort of black pillowslip, but the procedure is the same.
Hope this helps
Jan 20, 2010 | Olympus SuperZoom 700BF Film Camera
New roll of film rewinds instead of advancing
Your camera has a faulty winding mechanism. It suppose to rewind in the end of the film when there are tension present but somehow the detecting system in your winding mechanism is detecting when the back door is closed. Remedy is replacing the clutch system within winding mechanism. Average repair runs about $90. -James. For further assistance by email, go to www.camerarepairjapan.com
Mar 21, 2009 | Nikon N55 35mm SLR Camera
Film fast forwards
This is normal operation for the Canon Rebel film cameras, they are designed to pre-wind the film so each time you take a picture the camera winds it into the film cartridge. This means if the camera has a problem or the film door gets opened by accident your pictures are safe in the canister.
Nov 05, 2008 | Canon EOS Rebel X 35mm SLR Camera
N65 Film Winding problem
I have the same problem and I suspect that is the contact of the door.
Jun 19, 2008 | Nikon N65 35mm SLR Camera
Canon rebel k-2
Go into a darkened bedroom, dive under the thickest covers you can muster, with the camera. Open the camera back. You can now remove the cassette and unwind the film from the take-up spool (press the rewind button to free it) and wherever it has got caught up. Using the spindle on the cassette, wind the film back into the cassette. Now you can get out from under the covers and breathe again! Examine the camera mechanism to see if there's anything obviously untoward. Take it back to the camera shop & get them to check it out for you. If necessary, buy a cheap roll of film, put it through the camera until it jams (you can repeat this several times with the same roll if necessary). Then you can open the back in daylight & see what's going wrong - or, again, take it to the shop for help. They may want to send it for repair like that: if so send it with a note that the film is trashed & they can just open the back in daylight.
Sep 28, 2007 | Canon EOS Rebel K2 35mm SLR Camera
Nikon EM 35mm SLR Camera Logo
57 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Nikon Photography Expert? Answer questions, earn points and help others
