Samsung 32" crt tv, hissing sound - Televison & Video
  • 1,512 Answers
G'Day,
You will find that the Flyback assembly or the EHT cap connected to the top of you picture tube is "leaking". The hissing sound is arcing caused by insulation breakdown in the plastic block of the flyback assembly, a faulty tuning capacitor in the horizontal output stages, or if you live in a humid climate, dust that may have accumulated on the back of the tube/high tension stages , will create a track of conductivity when it takes on moisture from the air. The hissing sound is the air being ionised by the high voltages present.
There is in excess of 25,000 volts in these areas, and repairs to your set should be done by a professional with good experience if you are not familiar with the problem I am speaking of, particularly about the rubber cap connected to the tube. Voltages remain present here even after the set has been turned off, and will remain so for an extended period. The picture tube needs to be discharged correctly before any attempts to repair problems here are made.
I am happy to discuss things further if you wish.
regards robotek
Posted on Aug 05, 2010
  • 3,866 Answers
This hissing sound might be comming from your high limit transformer, Spomething you might want to check in the shop for as its a sign of a breakdown and you want to knab it before it becomes more parts and $$ out your pocket.
I am sure this can be repaired but I do not know how you feel about having it repaired it might not be worth the $$ but then again people cheerish there old tech.
Thanks hope this helps please do consider leaving a rating.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
2 Suggested Answers
jerryg50
  • 1689 Answers
SOURCE: Lost Power
The power supply may have failed. Very often when there are failures in these sets it is from one of the scan amplfiers, and then it takes the power supply down with it.
Your set can be serviced by an experienced tech who especialy knows details about your model type.
Jerry G.
Posted on Apr 18, 2008
Toshiba 32'' tv no power no sound red led in front on and blinks also hearing hissing from flyback model#cx32f60
for sure your tv has power as indicated by your flyback hissing it also indicates leaking high voltage that might destroyed your vertical or any other parts near your flyback ,the flyback itself should be replaced for its high voltage arcing can ruin so many components
Oct 13, 2009 | Toshiba Televison & Video
32" Samsung TV, No Power or Sound, power LED on, flashes 3 times
Most likely the set has lost vertical sweep or the feedback from that circuit. This will shut the set down to prevent a horizontal line from burning the face of the CRT. This will have to be looked at by a technician.
Sep 11, 2009 | Samsung LN32A330 32 in. LCD TV
Rca arcing and hissing
Most likely,you have a bad transformer AKA flyback ......
Is 32V420TYX6 the service # of your TV ?......Verify..........T.
Apr 05, 2008 | RCA 32V420T 32" TV
PS32500 32" TV Problem
The sound that you hear is coming from the sound detector not working or not receiving any audio. If the set is set to a second audio (SAP) program this could be you trouble. Some programs are broadcast this way. (such as Spanish for Spanish speaking people. Check you audio program settings.
Stargazer
Feb 19, 2008 | Proscan PS32500 32" TV
Buzzing sound
You haven't specified where the buzzing sound is coming from, if it is coming from speakers, changing capacitors in the audio section will fix the problem, especially the filters. Now if it sounds like a hissing sound from back of the tv, the CRT base socket is the culprit. It is an easy thing to fix, and the base is cheap, but make sure you purchase the exact same type of base or it will harm the CRT. Good luck.
Jan 22, 2008 | Samsung TXN2775HF 27" TV
Sound
It's probably the audio amp Ic, which in that unit is a LA7612n...
Replace that and esr the caps locally and you should be good as new.. Otherwise the hissing will eventually be heard on all channels...
Bill
Dec 07, 2007 | GE 32GT740 32" TV
Tv went crazy
maybe defective display tube
Sep 10, 2007 | Mitsubishi WS-55807 TV
TV screen wont turn on but just a loud noise coming from the tv
I think maybe the G-board needs to be replaced. A TV shop will have to repair it. They normally start around $200.00
Jul 02, 2007 | Panasonic CT-32G23 32" TV
Crackle noise and hissing - panasonic
solder all around the flyback area if this not resolve the problem replace the flyback
Nov 26, 2006 | Panasonic CT-32D12D 32" TV
Televison & Video Logo
687 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
