Question about Craftsman Garden
I have a crafsman Briggsstratton 675 series 190cc ,model no#917.376460.today I try to started and I pull the cord and it would not start.please tell me what I can do?
  • 760 Answers
This listing was listed for a riding mower, but the model number you listed (which by the way is exactly the correct thing to do) is for a self propelled walk behind. Ok, I'm assuming you were holding down the operator presence bar on the handle. The mower shouldn't run unless it is held down. Make sure the cable is moving the lever on the engine from this bar. Ok then to the basics. You need fuel and spark for it to run. Disconnect spark plug wire, and insert screwdriver or other object and set to jump spark to ground, and pull cable and check for spark.If you have good spark, then it must be fuel. If you add a very small amount of fuel to carb and it runs for a second, then you have a fuel problem most likely in the carburetor.
Posted on Aug 05, 2010
Mototiller, Gear Drive 675 series ,190cc. Cannot find the Primer, Cannot start the engine.
No results found for Mototiller, Gear Drive 675 series ,190cc sorry this is a google search result
Sep 28, 2016 | Garden
Why doesn't the pull cord wont move
Could be a few things but I would start by taking the spark plug out to reduce the compression. This will make it easier for the engine to turn just to make sure the piston is moving. If it is an older machine you may have rust build up all the way to a seized engine depending on maintance preformed on the mower.
Jun 20, 2014 | Craftsman 675 Series 190cc 22" Briggs ...
Craftsman Briggs and Stratton 675 series Mower fuse location
Is battery powered, did you try calling sears tech center for further info ?
i have found them to be very helpfull with mower problems.
Sep 12, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
Pull cord hard to pull since I hit tree root
see if the blade is bent the check the key under the flywheel
Aug 12, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
Craftsman 675 series wont start
can you pull the rope and it doesn't start or is it stuck like the engine is locked up?check for spark also how old is the fuel gas is only good 30days from the pump for small engines
Jun 11, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
Lawn mower 675 series 190 cc Briggs Stratton 22
did this happen after hitting a rock?and you sheeredthe flywheel key is the gas older than 30 days?drain and refill if still no good clean the carb
May 03, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
When I try to start it with the key start it will not turn over changed fuse but still no start. How do I check the starting system?
What you probably have is either a bad connection to the starter, or switch, or you have a faulty starter, or battery. I would start by checking the wires. Take them loose and reconnect them. If that is to no avail, then you will want to have the battery and starter tested.
Mar 16, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
