Question about Polaroid TLA-04011C 40 in. LCD TV
My TV has two vertical bars on each side, equal is size, and one is a green transparent and the other is a purple trasparent bar. What can I do to fix this?
    Sergeant:
  • 252 Answers
You have a bad capacitor in th e horizontal section of your tv or your horizontal chip is bad. If you are not a tech I would advise you to take it to the nearest one.
Posted on Aug 05, 2010
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
Jan 16, 2016 | LG Televison & Video
Relisys vertical bars
Sorry this wont help you much, but may put you out of your misery trying to repair it.
The LCD panel has failed. In particular the driver tabs that connect to the physical panel have failed and there is no way to repair them.
The only soloution is to replace the entire panel, a cost that would be close to if not more then a new TV of the same size.
I would put it on Ebay for parts (powerboard, logic board etc), and use the money towards it's replacement.
Peter
Mar 25, 2010 | Relisys RLT1720 17" LCD Monitor
Have a 56-inch Samsung flatscreen projection TV. On cable it has 5 equally spaced vertical green bars. Each green bar is comprised of 8 smaller vertical lines. It also has intermittant purple horizontal...
The digital board is bad and needs replaced. If you can get the board you hace to crack the metal chassi . Its a pain but if you are mechaniaclly inclined you might be able to do it. Pull the chassi and dissassemble. Lots of screws. Don't force anything and study it closely. It's tricky. There is also a memory transfer proceedure. The board from Samsung comes with instructions.
Mar 25, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
2 vertical bars on tv screen
OPEN THE TV AND BLOW IT OUT ..THOSE BARS ARE THE EFFECT OF DUST INSIDE THE UNIT CLEAN OUT AS WELL AS YOU CAN AND THAT SHOULD FIX
YOUR PROBLEM
I’m happy to help further over the phone at https://www.6ya.com/expert/jovani_c02b023fe087f6cd
Feb 06, 2018 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Green vertical bars on a Samsung projection
That is a problem with your main board - some of your inputs work fine and another is bogus. The tv input is not working because there could be a defect in your tuner. If you have cable try a different input for the signal.from the box. If you are using OTA, then use an external HD OTA tuner to feed your set.
Sep 09, 2017 | Samsung HLR5067WX 50" Rear Projection HDTV
Green/blue/purple vertical bars on my viewsonic va712b
you're video card is failing, try the secondary port if you have one, artifacting such as different colors, shapes and lines are VGA related, you need a new VGA card and for more info contact http://tinyurl.com/m7ghqz
Jun 18, 2009 | ViewSonic VA712B 17" Flat Panel LCD...
LG DLP Projection TV Green/Brouwn vertical Bar
Hi there.
The excessive heat from your lamp has burned one or 2 polarizing lenses.
To replace this you have to pull the optic engine out of the unit and dismantle it.
You will see 3 square lenses in there, remove one by one until you find the burned one.
Then go to ebay and type in hoya polarizing lense.
Buy the 72mm one and cut it to size.
hope this helps.
Sep 30, 2008 | LG RU-52SZ51D 52" Rear Projection...
Green translucient vertical bar on left side of screen
Cover green CRT lens with towel and see if red/blue video is normal......= bad CRT ?.............................T.
May 09, 2008 | Toshiba 57H82 57" Rear Projection...
Transparent horizontal bar
disconet the ground on the power cord of your tv will fix the problum. or the subwofer power ground .
May 14, 2007 | LG 42PX5D 42 in. Plasma HDTV
Polaroid TLA-04011C 40 in. LCD TV Logo
73 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
