Question about ViewSonic Computers & Internet
I have a ripped cable from the LCD screen to the circuit board. The part number is RX150FH0.PCB. Is there a way to repair it. or get another one? What are my options? The monitor is a ViewSonic VG150. Thank you, Evan I found that another person had the same problem and he posted pictures: http://lumenlab.com/forums/index.php?showtopic=19929
    Guru:
  • 1,082 Answers
Try looking for the parts on ebay.
Posted on Aug 05, 2010
The screen on my 42"
Hi.
If the screen is dark and there is still sound is usually because there is no power to the inverter board. Parts that cause this are inverter, power supply or main controller board. Power to the LCD panel should also be tested.
before declaring the TV faulty make sure that the problem is not cable settings or source selection.
Check if there is on screen display (the menu). If OSD is displayed, then the problem is either cable/source settings or a defective input circuit. Try also disconnecting power cord for ten minutes and then up to one hour. Power drain may fix temporary faults.
If all that does not work, then the problem is either inverter or power board. In some case the main controller board may also be responsible.
The inverter is a power board that converts DC voltage from PSU into AC high voltage, powering the whole backlight system. When there is a problem with the inverter the whole screen will be completely dark, while the sound keeps going on.
A problem with the inverter will mean that either inverter is bad, power supply is bad and does not power the inverter, or main board is bad and does not turn inverter on. Those are the three parts that must be tested when the inverter does not fire up ( sound and dark screen). Here broad description of how to test the three parts: Before proceeding...
From a user level point of view, all you should do is disconnecting power cord for fifteen minutes, and testing the TV with different connected devices and different cables (e.g. with a DVD, a receiver box, using a SCART and using HDMI).
Disconnecting power will allow a power reset that sometimes can fix temporary problems (usually not sound but no picture).
Testing different cables and devices excludes the chance of the problem being given by a bad cable connection.
If that does not work, call the manufacturer at the number listed in the owners manual. Verify warranty status (warranty may have expired 09/10). Make present to the operator that the TV is just out of warranty, and that the fault occurred without you making any wrong use of the TV. Some manufacturer in some case apply special condition.
Here replacement parts for most flat panel TV models:ShopJimmy.
See also:
PartStore
Regards.
Ginko.
Sep 13, 2011 | Philips 42PFL3603D/27 42 in. LCD TV
I have a broken LCD screen on my LG TV
Not repairable or worth repairing.Only must have a replacement of the LCD screen panel.Not buy able any where except the tvs corporations themselves only.The tv LCD screen panel it is 90% important to the tv functions and the cost of the tv.Can't do replacement of the tv LCD screen panel will cost the same as a new tv.Tv now only worth as a salvages tv only for it electronic boards only for uses it PCB electronic boards as replacement for other used tvs need used PCB boards only.
Aug 26, 2011 | LG 42LC2D 42 in. LCD HDTV
I have a Sony Bravia KDL-40s5100 and the screen is now red and dark and seems to be in almost slow motion. My warranty is up by 28 days and Sony will not honor the repair and told me it was my cost. From...
This problem can be caused by bad connections on the LVDS cable (the signal cable from the main pcb to the display control pcb.), sometimes cleaning the control pcb socket/cable plug can cure this. Other possibilities are: the display control PCB, or more probably, the display itself.
Jan 03, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
When i slide my phone.my phone was gone black & invisible lcd screen.
You display flex cable (the cable/wire which connects the display and printed circuit board/pcb) has been damaged, this happens usually with slide phone. You can get a replacement from the market. Good luck. Thanks for using FixYa.
Jun 06, 2010 | Samsung SGH-G800 Cellular Phone
Looking for circuit board for a 19in proview lcd monitor
Which pc board are you looking for? Most LCD monitor companies use third party PCB assemblies. Can you get the name and number as printed on the PCB?
http://s807.photobucket.com/home/budm/allalbums
Apr 18, 2010 | Proview PL913S 19" Flat Panel LCD Monitor
Tv fell on floor and now does not switch on
Take the aparts.Check all PCB boards.Might have PCB boards broken.Might even have LCD screen pannel broken,not worth repairing if LCD screen picture pannel is broken.
Mar 17, 2010 | Televison & Video
My viewsonic lost a cap no 1000uf @ 16volt after replacing that cap the screen came back on but know has a half screen and on the other side there are about 50 colored lines that are vertical from top to...
You can have the a LCD controller (circuit board on the LCD panel where the flat connector from the digital/controller board is connected to) failure or the falt connector came loose. Check that out first.
Feb 24, 2010 | ViewSonic Optiquest Q19wb LCD Monitor
Vertical lines on screen different colors
The problem is the LCD panel or the logic PCB (printed circuit board). you can find the logic pcb attatched via flat ribbon cables or small plugs. Good luck. The part number should be on the printed circuit board. I hope this helps.
Nov 16, 2009 | Toshiba 42HL196 42 in. LCD HDTV
SD400 LCD Screen White after Replacement
There are a number of possible common faults that can cause the screen problem that you are describing.
It is possible that the new replacement screen is defective, or there is a defect in the ribbon cable, or the sockets are not making proper contact, or there is a cold solder connection at the socket or on the circuit board, or the driver circuits on the circuit board have a failure.
The service tech would try another screen, or ribbon cable (if changeable), or the circuit board to locate the defect. Once he finds the defective board, he will leave in the new replacement.
These cameras are serviced by modular approach.
Jerry G.
Jan 08, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
I have a sanyo CE27LD-3B with sound but no pic. The back light is working, and there seems a lot of activity on the input to the panel drive pcb from the main pcb for example when I change channel the...
screen driver fault sounds like. could also just be the lead from the av board to the screen driver board or its connector, if you wiggle the cable see if the screen reacts with the wiggle.
May 23, 2017 | Televison & Video
Computers & Internet Logo
74 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
