Question about Denso BHT-8044D
Scandisk found invalid files refer to file "$$BRKLST.SYS" for more information. refer to system administator error (3010)
I downloaded the contents of my Tascam DR-05 to my computer because it was full, but, instead of doing it as always, by just downloading the soundfiles, I copied the file folder dr005 to my computer,
Eric have you tried to do a "Quick Format"? If I'm not mistaken when that is done, you re-format your card and the small memory in the DR05. I had trouble with mine at first but when I did the formatting after I put the bigger 2GB memory card in the DR05 worked great. I record on "All Files" too, that seems to work well also.
Hope that helps,
Patrick
Oct 14, 2014 | Tascam DR-05 Portable Digital Recorder
Initial value contains and invalid value & the standard value is set (Entry = Double side) (Code S310011)
Hello Peggy,
This error message is Twain Driver error. The cause is that a value outside the range or an invalid character was found among the items in the initial value data file. (Item XXXXX indicated by Entry=XXXXX)
If the file was intentionally changed, the value set for that item may be incorrect. If the file was not intentionally changed, the file may be corrupt. The value has been set to the standard value. The file must be written again, for assistance, please see "Initial Value File" in the "Operator's Guide".
A hard disk check (chkdsk or scandisk) and virus check must be performed regularly.
Hope this helps.
Thanks & regards,
ScanCare
Jan 22, 2014 | Fujitsu Fi-6140 High Performance Color...
Fix error 651 on windows 7
In windows 7, when you try to connect using your PPPoE connections, you may be faced with the following error: Error 651: The Modem (or other connecting device) has reported an error.
These connections would work just fine with Windows XP or Windows Vista PCs.
Again, you are not alone, this seems to be a known bug in Windows 7 that is being worked at. However, you can workaround this problem.
The RAS PPPoE driver file "raspppoe.sys" found under c:windowssystem32drivers folder seems to be the root cause of the problem. Fortunately, we can workaround the problem simply by renaming the original raspppoe.sys file to something like "raspppoe_orig.sys" copying a working file from a Windows Vista system. If you do not have access to a Windows Vista system. click here to download raspppoe.sys file (unzip). This should help!
Jan 01, 2011 | Computers & Internet
I am connected to internet but get error 651
I am assuming you have purchased a new pc with Windows7 and have a DSL internet connection. If so the following tutorial should prove useful. This is a common problem and known bug within the Windows7 framework that they are working to correct. Keep in mind that this fix is only applicable for the Windows7 operating system.
"The RAS PPPoE driver file "raspppoe.sys" found under c:windowssystem32drivers folder seems to be the root cause of the problem. Fortunately, we can work around the problem simply by renaming the original raspppoe.sys file to something like "raspppoe_orig.sys" copying a working file from a Windows Vista system. If you do not have access to a Windows Vista system click here to download raspppoe.sys file (unzip)."
http://www.windowsreference.com/windows-7/error-651-with-pppoe-connections-in-windows-7/
Once downloaded and unzipped you may rename the old rasppoe file as mentioned above by right clicking the icon and choosing 'rename'. Then copy the new rasppoe file you downloaded into the applicable folder. You will find this file in the following directory C:\WINDOWS\system32\drivers. Bear in mind, when searching for the file inside the drivers folder, the .sys file extension may or may not be included in the actual name. If the original file is named 'rasppoe' without the .sys file extension in the name, leave this file extension off when renaming and copying as well.
Dec 10, 2010 | E-Machines eMachines Desktop PC
Wireless not working pc told me error 651
The RAS PPPoE driver file "raspppoe.sys" found under c:windowssystem32drivers folder seems to be the root cause of the problem. Fortunately, we can workaround the problem simply by renaming the original raspppoe.sys file to something like "raspppoe_orig.sys" copying a working file from a Windows Vista system . If you do not have access to a Windows Vista system. click here to download raspppoe.sys file (unzip)
DO VOTE ME
Dec 07, 2010 | Computers & Internet
Scandisk found invalid files refer to file "$$BRKLST.SYS" for more information. what can i do to resolve this problem?
Aug 05, 2010 | Denso BHT-8044D
Stop:0X00000024 (0x00190203, 0X86f02b00, 0XC0000102, 0x00000000)
A problem occurred within NTFS.SYS, the driver file that allows the system to read and write to NTFS file system drives. There may be a physical problem with the disk, or an Interrupt Request Packet (IRP) may be corrupted. Other common causes include heavy hard drive fragmentation, heavy file I/O, problems with some types of drive-mirroring software, or some antivirus software. I suggest running ChkDsk or ScanDisk as a first step; then disable all file system filters such as virus scanners, firewall software, or backup utilities. Check the file properties of NTFS.SYS to ensure it matches the current OS or SP version. Update all disk, tape backup, CD-ROM, or removable device drivers to the most current versions.
Feb 10, 2010 | Dell Computers & Internet
Boot error stop 0x00000024, (0x00190203, etc ....
Here is a write up regarding the STOP code 0x24 complements of http://aumha.org:
0x00000024: NTFS_FILE_SYSTEM
(Click to consult the online MSDN article.)
Here is an article from MS regarding the recovery console http://support.microsoft.com/kb/314058.
Another option you have is putting the HDD into another system and running chkdsk and defrag from the good system.
Aug 19, 2009 | Computers & Internet
Hard drive backup
This seems to be a good article on ASR backup and how to eliminate your error message.
See Link
Dec 16, 2007 | Dell Latitude D600 Notebook
Armada E500
using edlin you can enter for config sys device=c:\dos\himem.sys device=c:\dos\emm386.exe noems device=c:\dos\cdrom.sys /d:mscd001 /l:e for autoexec bat @c:\dos\mscdex.exe /d:mscd001 ----------------------------------- config sys himem.sys is the upper memory manager emm386.exe is the 'gate' to allow access or combine all of it noems turns off expanded memory cdrom.sys is the CD Driver - yours may have a different name /d:mscd001 refers to the name of the CD Rom Drive (generic) /l:e refers to the drive letter (e:) to designate for the CD Hope that helps If used, rate me
Nov 11, 2006 | Compaq Armada E500 Notebook
Denso BHT-8044D Logo
165 people viewed this question
Top Denso Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Denso Office Equipment and Supply Expert? Answer questions, earn points and help others
