Question about OKI Office Equipment & Supplies
I have an OKI B2520 MFP and on the display it says "Printer Error Fuser Temp." How can I fix this to get this working again? Appreciate the help. Dean
  • toyota1z Feb 15, 2009
    print error fuser temp
This is a common error especially if you have power surges or outages, before calling in follow the following steps:
  1. Press Down Arrow
  2. Press *
  3. press #
  4. select SOS1
  5. switch the first digit from a 0 to a 1
  6. press OK
  7. Press the Red Stop button
Now you need to clear the error
  1. press the down arrow
  2. Press #
  3. press the letter T ( on the keyboard of the printer)
It should reboot itself although it may not, if it doesn't then turn off the switch then back on. you should see some black bars flashing on teh screen. This clears the error and wil help determine if the fuser is actually broken. Before you print and start using it you have to set it back to operational mode by doing the following steps
  1. Press the Down Arrow
  2. Press *
  3. Press #
  4. select "SOS1"
  5. Change first digit from 1 back to 0
  6. press OK
  7. Press the red stop button
Those are the steps required to clear the fuser temp error from the okidata support desk
Posted on Dec 30, 2009
  • duna Oct 22, 2012
    no consigo que me desaparezca el mensaje. una vez reiniciada me sigue poniendo el mismo error al arrancar. Alguien conoce otra forma de solucionar el problema? GRACIAS
Try turning on the printer in a dark room. You should see a bright light in the rear area of the printer. If you do not see that light, then the lamp in the fuser assembly has blown or is otherwise operable. The bulbs are special to this unit and are not available in most local shops, however you may be able to find them online. IMPORTANT! do not touch the glass surface of the bulb, if you do the bulb will distort and possibly break the glass where you touched it, once it gets hot. You would of course have to take the printer apart to get at the bulb, and this is not recommended for the average user.
Posted on Mar 20, 2009
Si despues de hacer este reseteo no se quita el error no habria que cambiar el fusor sino la placa logica.
Posted on Apr 29, 2014
Fuser TEMP
Posted on Mar 25, 2011
I can't find driver for mac os leopard for my oky b2520
Hi.
B2520 MFP Mac OS X is not supported for this product
source: http://www.oki.co.uk/support/printer/troubleshooting/detail.aspx?id=tcm:122-95564&prodid=tcm:122-4267
sorry
Dec 06, 2012 | OKI B2520 All-In-One Laser Printer
Hi, I have an oki B2520 MFP. We can print , scan and receive faxes however. We cannot send faxes it doesnt seem to dial the fax number. Is there any way to do a reset back to factory settings as lots of...
Flecha ABAJO
Pulsar asterisco *
Pulsar almohadilla #
Poner en 1 el SC001
ok
ok
Y después
Flecha ARRIBA
ok
ok
Y ya está en valores de fábrica. Saldrá en inglés
May 06, 2011 | OKI B2520 All-In-One Laser Printer
Code 173 for oki c5500
Service call 172:Error & 173:Error
Both errors mean -
Abnormal temperature detected by fuser thermistor (high-temp or low temp.)
Does error reoccur?
YES -
Turn power ON again. Replace fuser unit.
Jan 19, 2011 | OKI C5500n Printer
I have an OKI 5650 printer and am getting a 172: Fatal Error - how do I fix this?
detected by
fuser thermistor
(high-temp or low
temp.)
Replace fuser unit.
Feb 12, 2010 | OKI C9300 Led Printer
OKI B2540 MFP IS GETTING A FUSER TEMP ERROR, DO YOU KNOW HOW TO FIX THIS ERROR?
Sep 04, 2009 | OKI B2540 MFP Printer
PRINTER NOT WORKING
That is a fuser code. Turn off and take out fuser(the part that gets hot) and inspect it. Put it back in and turn back on. If code is still there replace fuser.
Aug 02, 2009 | OKI Electric Industry C3520 Laser Printer
I have a OKI B2500 Series. When Print Says Printer Error FuserTem
If you have not fixed this by now, I have the fix.
Turn the printer on, hit the following keys on your printer:
down arrow, *, #, ok, 1, ok
After that, hit the down arrow until you see T>Printer and then hit ok.
Next turn off the printer, count to 5, and then turn back on.
Repeat the first step, but in place of the number one, insert the number 0.
These were the steps given to me by the oki customer service and it fixed my printer. If you have problems, the number is 800-654-3282.
Jun 07, 2009 | OKI B2500 Black and White Copier
Error Code 155: Fatal Error
Looks like a fuser error-
re-seat fuser
check for paper scraps, etc in fuser and printer.
Service call
155: Error
Defective fuse
cutting of fuser
Is the fuser installed correctly?
Does the error recur?
Reinstall the fuser after its
connection connector is cleaned
if error still exists-
Turn on the power supply again
Replace M32 board after check
the cable connection.
Jul 29, 2008 | OKI KIT-C3530N MFP LASER CLR P/S/C/F USB...
OKI C3530 MFP
Looks like a fuser problem.
Re-saet the fuser.
Check for pieces of paper, etc. in the path.
Service call 155: Error
Defective fuse
cutting of fuser
Yes
If error still exists_
6,771 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
