Question about Samsung HC-R4755W 47" HDTV
I have an Akai pt5499HD tv and when i power up the set. it sometimes hums for a second then shuts off comopletely. I was thinking it was either the deflection board or the pcb-inline board. is there things i can do to check? is there somewhere to get parts also?
    Sergeant:
  • 252 Answers
I had a similar problem and I found it to be something I would have never checked. It was a ceramic capacitor in the high voltage section. Make sure to check all them in this section. I know they are least likely to fail but they do go bad.
Posted on Aug 05, 2010
Testimonial: "helped a ton!!"
  • 2 more comments
  • tmc0001 Aug 05, 2010
    how do you check them?
  • Willard Broughton Aug 05, 2010
    If you have a Fluke digital multi meter it should have the symbol for a capacitor. After you put the meter on this setting look at the capacitor rateing in farads and see is it in range with the farad reading that meter is giving. Of course you have to place one of the test leads on one leg of the capacitor and the other lead on the other leg before you can get a reading. If the cap reads short or below the rated farads recorded on the cap take one end of the cap out of the circuit board. If it still reads a dead short or below the rated value replace it. You can also by a capacitance meter that is just for capacitors online. As far as parts are concerned you can look up an electronic parts maker such as Mouser Electronics or MAP these companies will send you a cross refrence manual or you can use their on line manual. After you cross refrence it you can order the part online or call and order. Parts will be sent directly to your house or place of business
    does the power need to be hooked up? or can you do this without a power flow?
  • tmc0001 Aug 07, 2010
    is it wierd or odd if i have multiple capacitors that are out of range?
My Akai pt5499HD has no picture to it and i just replaced the flyback transformer to see if that was the problem. any suggestions?
You need to have copy of service manual for this tv and Samsung PT5499HD service manual will work on your Akai tv as both has same circuit.
Aug 26, 2010 | Samsung HC-R4755W 47" HDTV
Akai PT5499hd that has suddenly lost color alignment
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 23, 2009 | Akai PTH5498 54" Rear Projection...
Input cable piece broke off akai pt5499hd
The coaxial input can be soldered back in. You will need a new one however. Sometimes the internals in the tuner (where coaxial goes) may be damaged when coaxial connection breaks out. If that is the case a tech may charge more money. But just to replace the connection should be relatively inexpensive.
Apr 23, 2009 | Televison & Video
There is a loud hum on my 32" AKAI LCD TV on all channels.
The humming noise is cause by defective capacitors in the power supply 12 volts line. These capacitors become defective due to the amount of heat surrounding them.
I repair these power supplies. If you need further assistance, write to jah2mil@hotmail.com
Feb 01, 2009 | Akai LCT2715 27 in. LCD Television
AKAI PT5499HD
hello I am Jaime from Mexico, i have a 54" akai pt5492s don`t turn on, but timer on in red help me please
thanks
Sep 16, 2008 | Akai PT5492S 54" Rear Projection...
Akai pt5499hd
Either the convergence chip has gone bad or the Focus block is bad. In any case,you will need to consult with a professional technician to solve this problem
Nov 11, 2017 | Akai PTH5498 54" Rear Projection...
Akai pt5499hd just shut down
If you are electrically inclined, there is a power deflector board that may need to be replaced. This deals with the high voltage part of the TV, so I am not responsible. The part number we had to but and replace was BP94-01289A or about $130.
Oct 31, 2007 | Televison & Video
Samsung HC-R4755W 47" HDTV Logo
183 people viewed this question
Jerry Greenberg
Jerry Greenberg
