Question about Garmin nuvi 200 Car GPS Receiver
How do you shut the garmin nuvi 200 down I can't get it to shut off
  • 3 Answers
Plug it to your power charger (connected to the el-net, of course). After the map loading has completed and you can start using it, unplug from power. A dialog box will pop up and ask you either to turn it off or to continue using it on. Choose to turn it off.
You will not be able to turn it completely off as long as it's connected to either a computer or a charger.
or you on/off push button is not working and needs to be repaired.
On my nuvi 200 the push button is a bit loose, and it easly turns on when I carry it in my pocket. Some adhecive tape will keep the button in place.
Posted on Aug 09, 2010
  • 9 Answers
SOURCE: Garmin Nuvi 200
Surely, you can remember where you were when you set the pin code, just return there and it will unlock itself.
Garmin use this to deter thieves from unlocking stolen units.
Posted on Apr 04, 2008
sharcnet
  • 2130 Answers
SOURCE: Garmin Nuvi 200 Voice no longer working
Does your Nuvi 200 have a headphone jack? If so, try that with a pair of headphones. If you hear sound, then your internal speaker went bad. It's a known problem with the Nuvi.
- Jim
Posted on Sep 04, 2008
SOURCE: GARMIN NUVI 200 SAYS NO DETAILED MAPS FOUND THAT SUPPORT ROUTING
MY GARMIN NUVI 200W NOT WRONG AND SAY NODETAILED MAPS FOUND THAT SUPPORT ROUTING. THE NUVI CANNT BE USED WITHOUT THEM
Posted on Sep 22, 2008
SOURCE: GARMIN 200 LOCKED
how do i get a passcode a for a garmin nuvi 200 if its lockd and u forgot the code and u cant send it back to da company
Posted on Oct 01, 2008
OAKside
The downloaded map file (ex: "Garmin_RMU_CNNANT2010C.exe") contains all of North America, and you must select the correct subsection (ex: "Lower 49 States+PR") that you purchased, which is listed on your Garmin myMaps page (My.Garmin.com).
I am a GPS newbie as well and selected "all of North America" when installing my free nuvi 205 map update. A mistake that's too easy to make, esp. considering Garmin still has very little info about selecting the correct map subsection listed on their support site.
You do NOT need to re-download the huge map file, thankfully, but you must re-install (30+ min) to choose the correct map subsection.
"Bad on Garmin, IMHO for not making important details like that clear to us new owners." My thoughts exactly.
Posted on Apr 25, 2009
Does the garmin nuvi 200 have free map updates
Use the Garmin Express program from Garmin. Down load and install the program, then connect your GPS to your PC. The program will identify your GPS and tell you of any available map and software updates.
Jan 21, 2017 | Garmin nuvi 200 Car GPS Receiver
Tip
Garmin Nuvi 200 Favorites Backup and Restoration Procedure Models: Garmin Nuvi...
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Would you like to back up a copy of your Garmin Nuvi 200 Favorites and Waypoints?
Backup and Restoration Procedure for Favorites:
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
I hope that helps.
_________________________
Garmin Nuvi Hard Reset Here.
Download Nuvi 200 Manuals here.
Download Garmin WebUpdater here.
on Apr 17, 2010 | Garmin nuviĀ® 200 Car GPS Receiver
My garmin nuvi 200 it say no detailed maps
my garmin 200 nuvi say no detailed maps found that support routing
May 21, 2010 | Garmin nuvi 200 Car GPS Receiver
Can not find a USB slot in my Garmin Nuvi 200
I can help you update your Garmin Nuvi 200.
Here is a picture of where the USB cord plugs into your nuvi:
These are the steps to take to update your Nuvi 200:
Download and then run Garmin 200 WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Backup your favorites.
Nuvi 200 Hard Reset.
Apr 21, 2010 | Garmin nuvi 200W GPS Receiver
Shuts down when driving, looses power, and goes to battery
If your Nuvi's battery is low, and the plug becomes loose, then that may be your problem. If your Nuvi is acting up due to a firmware / system software glitch (common common common), then I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites (if your computer will still recognize it or if you have a memory chip you can pop into a card reader).
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Apr 11, 2010 | Garmin nuvi 200W GPS Receiver
Hellio, my garmin nuvi 200 cant find a satellite,
  1. Back up your Favorites.
I hope that helps.
___________________
Mar 24, 2010 | Garmin nuvi 200W GPS Receiver
Upon power up it stops and shuts down
Not being able to start up is a sign that the system software or firmware of your Nuvi has become corrupt.
I hope that helps.
___________________
Jan 16, 2010 | Garmin nuvi 200W GPS Receiver
I hv a garmin nuvi 200w which shuts down automatically
Your Nuvi has suffered the firmware or system software equivalent of a stroke.
I hope that helps.
___________________
Sep 29, 2009 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 200 keeps shutting down
You may need a new power cord, I have the nuvi 250w and the cord is getting bad after a year. The battery will only run it for a short time.
Sep 16, 2009 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 200 Car GPS Receiver Logo
65 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
