Question about True TUC-27F-ADA Undercounter Freezer, -10° F, 6.5 cu. ft., 2 shelves, 300 series s/s top - sides, w...
Unit is not lowering in temperature. There is not suction port to check pressures. Compressor 5.8RLA, Condensor is clean. Evaporator frosted, not frozen. 32F need 22F.
    Guru:
  • 1,524 Answers
Use a tap a line.
Posted on Aug 05, 2010
R22 unit running at 160/58. Took bulb out climbed to 61 on suction then right back to 58. Replaced txv. Charged to 220 head, suction stays at 60. Clean coil, no filter, good airflow. Ideas?????
Sounds like bad valves in the compressor.
A good indicator is how fast the pressure changes when you shut the compressor off. It should take several seconds for the suction pressure to rise. If it's immediate, then expect a bad valve.
Mar 07, 2016 | Heating & Cooling
Motor & comp. run.every thing cleane. will not get cold. has feron ?
It still could be low on refrigerant. Check suction pressure to see if it is lower than normal. Check the suction line to see if it is WARM - near room temperature. Check the compressor discharge to see if it is hot. check the Condenser to see if it is warm. Check the capillary tubes to see if they are warm. Check the evaporator to see if it is extremely cold near inlet and check the outlet to see if it is room temperature. check the amp draw on the compressor to see if it is to high. if these conditions are present then it is under charged.
Jun 24, 2014 | U-Line Icemaker
Goodman unit runs and at the a-coil there is a piston where your suction and liquid lines connect. On the liquid side the piston is cold but warm on the other side of piston. A/C unit will not cool.
That piston is the metering device. On the liquid line, before the metering device it is always warm (this is sub cooled, high pressure liquid), but should flash to low pressure, lower temperature vapor once it passes through the metering device. The suction and liquid line never connect together.The liquid line brings liquid from the condenser to the evaporator. The suction line brings super heated vapor from the evaporator to the compressor. Since the unit does run, I'd have to put a gauge on it,but if I had to guess, I'd guess you have high head pressure. Check for dirt or debris on the condenser, check for proper clearance of the condensing unit and check for operation and directional rotation of the condenser fan. This could also be the result of an over charge.
Aug 26, 2013 | Goodman CKL36AR36 Air Conditioner
Kelvinator fridge compressor running constantly, but freezer section barely freezing
CHECK THE CONDENSER COILS UNDER THE UNIT. THEY PROBABLY ARE DIRTY AND CANT REJECT THE HEAT.
Oct 18, 2012 | Kelvinator Refrigerators
Temperature is at 51 degrees. Door has been open and shut all day but the temperature shouldn't be this high and it doesn't seem to be going down.
check the evaporator fan and condensor fan. condensor coil clean. compressor warm.how much frost build up . if frost build block air way, i am sure the problem is heatelement or defrost thermostat. good luck.if the compressor not work . need to check the relay
Jan 10, 2011 | Sub-Zero 650 / O Bottom Freezer...
Air conditioner in 1999 mercury tracer won't work. It's not the compressor nor does it have a leak. what could be the problem?
the tracer is the same as the ESCORT, right?? TRY THIS--I WORK ON PLENTY OF ESCORTS--LOOK UNDER THE AIR CLEANER/CONE ASSEMBLY--THERE WILL BE A BLACK METAL BOX(FULL OF RELAYS) ONE OF WHICH IS THE A/C RELAY--TRY TAPPING ON IT WITH A LONG SCREWDRIVER OR SOMETHING SIMILAR WHILE U HAVE THE A/C ON. IF THE A/C SUDDENLY STARTS WORKING U NEED TO GET A NEW RELAY BOX(I THINK ITS CALLED A GEM MODULE) i do have a question- does the blower motor work?? how do u know the compressor is good??do you have 12 volts going to it??? this relay box is pretty common to go bad--u have to remove the air cleaner in order to get to it.get back to me.
Sep 07, 2009 | 1999 Mercury Tracer
''does a new radiator need refrigerant added to it''
You need to replace the condensor, then take it to a shop to have the a/c system evacuated and recharged to purge moisture because the system was opened. That will cost around $150. You do not need to replace the receiver/dryer/suction accumulator even though they will tell you that you do.
go to car-part.com to find prices of condensor from salvage yards. Page with asterisk on it is the lowest priced part.
The Refrigerant Cycle
During stabilized conditions (air conditioning system shutdown), the refrigerant is in a vaporized state and pressures are equal throughout the system. When the A/C compressor (19703) is in operation it increases pressure on the refrigerant vapor, raising its temperature. The high-pressure and high-temperature vapor is then released into the top of the A/C condenser core (19712).
The A/C condenser core, being close to ambient temperature, causes the refrigerant vapor to condense into a liquid when heat is removed from the refrigerant by ambient air passing over the fins and tubing. The now liquid refrigerant, still at high pressure, exits from the bottom of the A/C condenser core and enters the inlet side of the A/C evaporator core orifice (19D990).
The A/C evaporator core orifice is the restriction in the refrigerant system that creates the high pressure buildup in the A/C evaporator core (19860) and separates the high and low pressure sides of the A/C system. As the liquid refrigerant leaves this restriction, its pressure and boiling point are reduced.
The liquid refrigerant is now at its lowest pressure and temperature. As it passes through the A/C evaporator core, it absorbs heat from the passenger compartment airflow passing over the plate/fin sections of the A/C evaporator core. This addition of heat causes the refrigerant to boil (convert to gas). The now cooler passenger compartment air can no longer support the same humidity level of the warmer air and this excess moisture condenses on the exterior of the evaporator coils and fins and drains outside the vehicle.
The suction accumulator/drier (19C836) is designed to remove moisture from the refrigerant and to prevent any liquid refrigerant that may not have been vaporized in the A/C evaporator core from reaching the A/C compressor. The A/C compressor is designed to pump refrigerant vapor only, as liquid refrigerant will not compress and can damage the A/C compressor.
The refrigerant cycle is now repeated with the A/C compressor again increasing the pressure and temperature of the refrigerant.
The A/C cycling switch (19E561) interrupts compressor operation before the external temperature of the A/C evaporator core gets low enough to cause the condensed water vapor (excess humidity) to turn to ice. It does this by monitoring low side line pressure. It is known that a refrigerant pressure of approximately 210 kPa (30 psi) will yield an operating temperature of 0°C (32°F). The A/C cycling switch controls system operation in an effort to maintain this temperature.
The high side line pressure is also monitored so that A/C compressor operation can be interrupted if system pressure becomes too high.
The A/C compressor pressure relief valve (19D644) will open and vent refrigerant to relieve unusually high system pressure.
Item Part Number Description 1 19E762 A/C charge valve port (low side) 2 19E561 A/C cycling switch 3 19C836 Suction accumulator/drier 4 19703 A/C compressor 5 19D644 A/C compressor pressure relief valve 6 19D594 A/C pressure cut-off switch 7 19E762 A/C charge valve port (high side) 8 19712 A/C condenser core 9 19D990 A/C evaporator core orifice 10 19860 A/C evaporator core 11 — Low pressure vapor 12 — High pressure vapor 13 — Low pressure liquid 14 — High pressure liquid
  1. Connect the R-134a A/C Refrigerant Center to the low- and high-pressure service gauge port valves.
  2. Evacuate the system until the low-pressure gauge reads at least 99.4 kPa (29.5 in-Hg) (vacuum) and as close as 101.1 kPa (30 in-Hg) as possible. Continue to operate the vacuum pump for a minimum of 45 minutes.
  3. Turn off the evacuation pump. Observe the low-pressure gauge for five minutes to make sure that the system vacuum is held. If vacuum is not held for five minutes, leak-test the system, service the leaks, and evacuate the system again.
  4. Correctly oil match the system to verify that the correct amount of refrigerant oil is present in the system. For additional information, refer to Refrigerant Oil Adding in this section.
  5. Charge the system with the specified weight of refrigerant and refrigerant oil.
  6. When no more refrigerant is being drawn into the system, start the engine and select MAX A/C operation. Set the blower motor speed to maximum and allow the remaining refrigerant to be drawn into the system. Continue to add refrigerant into the system until the specified weight of R-134a has been added. Close the charging cylinder valve and allow the system to pull any remaining refrigerant from the hose. When the suction pressure drops to approximately 207 kPa (30 psi), close the charging hose valve.
May 14, 2009 | 1995 Nissan Maxima
A c starts off cooling good then compressor starts kicking in and
Several possible causes. Knowing the state of refrigerant charge would be helpful. Assuming it has a 'full' charge (full charge 680 Grams = 1.50 Pounds) Most common causes of AC problems:
1. Thermostatic switch (sensor) malfunction in the evaporator - allowing the evaporator to ice up. Check the vent temperature (using a cooking thermometer) to see if the temperature gets near or below freezing (32 Deg F.). If so, the thermostatic switch in the evaporator is defective. Replace it.
2. Refrigerant UNDER-charge. If the temperature does NOT get near freezing, then you need a set of AC gauges to check the compressor head pressure (High side) and the suction (Low side). High side pressure (nominal) is 229 PSI (+ - 20 psi) @ 2000 RPM. Low side (nominal) is around 20 to 40 psi. NOT common problems:
1. The magnetic clutch coil on the compressor... as it heats/warms up, the coil windings could be going 'open" circuit which would turn the compressor 'off.'
2. Compressor inefficiency (worn out).
3. Expansion Valve
4. Clogged Condensor
Mar 19, 2009 | 2004 Hyundai Elantra
Teco split system freezing up.
When you reversed it the fan stop because it went into defrost mode,Change the filter,clean the coil,let it thaw,and if it happens again,it may have a clogged cap tube or a leak in the system.
Please rate this solution.
Jan 20, 2009 | Samsung AW1203B Air Conditioner
Refrigerators Logo
83 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
