Question about Mitsubishi Heating & Cooling
I have MXZ-4A36NA Mitsubishi split-type air conditioner with two MSZ-A09NA inside units and two MSZ-A12NA inside units. All inside units will work about four minutes, then shut off. Operation light begins blinking about every half second. Can you tell me problem help me fix it. Roger
5 Suggested Answers
  • 19 Answers
SOURCE: MSZ A12NA the inside fan is making noise how do i
It's a quite complicated procedure but i'll try to describe as best i can.
Below the air outlet there should be a couple of screws. They may have small tabs over them (purely for aesthetics!).
If you lift up the filter cover, remove the filters and remove filter cover (trying carefully not to break it... darn plastic!) there may be some screws above the air outlet.
Remove the fascia cover starting from the bottom. Pull it out over the louvre in the air outlet. It will be clipped at the top near the back. These can be difficult to undo. Once that's done, remove the cover.
For the next bit, make sure that the power is turned off to the unit. (power cord unplugged, isolator turned off or c/b off depending on power source)
Undo the screws on the power box.
Undo the screws on the drain tray and off the left side of the evaporator coil. (Big finned section of pipework). Make sure you support the evaporator coil as it's only connected with copper pipes which bend/kink fairly easily.
You'll need to pull the coil out a little (not too far) and take off the left hand rubber 'bearing' as such from the indoor fan barrell.
On the right hand side of the unit you'll find the fan motor (which is held in by the power box) There should be a grub screw that holds the fan barrell onto the shaft of the motor. This is usually undone with an allan key but have seen them with phillips head screws also. This grub screw might be in a few different places. It might simply be on the right end of the fan barrell or sometimes the righthand column of blades is missing a blade and the grub screw is accessed by putting allan key/screwdriver up missing portion. You only need to loosen the grub screw, not remove it.
Once loosened, the fan barrel can be pulled off the motor shaft and removed.
Once off, you can inspect it for obstructions or broken blades etc. To reassemble is just the reverse of these instructions.
Just a few things to note:
1. Be careful of the evaporator coil not to kink (or break!) the copper pipes or your a/c won't work properly.
2. The drain tray may have water in it if the a/c has been operating recently.
3. Make sure the power is off before pulling off the power box.
This can be a very difficult task and I would recommend having an assistant to help with holding stuff.
Hope this helps!
Posted on Jan 21, 2010
  • 767 Answers
SOURCE: My Mitsubishi Mr. Slim heat
Here is the service manual for the model # you gave. http://www.mehvac.com/UploadedFiles/Resource/MSZ-FD09~12NA_Service_Manual_OBH497C_12-01-08.pdf
Posted on Feb 15, 2010
  • 15 Answers
SOURCE: I have a Mitsubishi mini
just lift the filter panel on front of indoor unit and turn it on manually,remember this just sets the a/c to 24 deg,the unit decides whether to heat or cool it to 24 deg....at least it gets it goin so u can order a replacement
Posted on Feb 22, 2011
TheMobilian
  • 8220 Answers
SOURCE: mitsubishi slit air conditioner model MSZ-GA80VA I turn on and turn off cauting out door unit fuse blown I replaced still The fuse is blow is the out door air con unit Note.unit in door stop not inpos
turn off everything electrical in house and retry with good fuse or breaker if still blows unit needs repair possible shorted capacitor? if it runs it may need to be on its own circuit dedicated to it alone
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 05, 2017
Msz a12na unitHOW DO I TURN HEAT ON? it worked fine last winter...? now the icon doesn't come up on any of the 3 units i have in the house.
Clean filters. disconnect from power for 10 minutes Reconnect and replace flitrs restart units. Set to heat on high.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/john_28069c9efb56199d
Nov 09, 2013 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi Mr Slim MSZ-A12NA-1 my outside unit is not communicating with the inside unit.It will run for about 1-2 min and shut off. Help
Low freon levels can do that. Any storms lately? Could be a bad control board. Damage to wiring between units.
Sep 25, 2013 | Heating & Cooling
I have a Mitsubishi mini split system heat pump model MSZ-A12NA. The problem is the wireless remote has been lost. How do I get another one? Or, can a regular hard wired heat pump thermostat be used? I...
Feb 21, 2011 | Mitsubishi MSZ-A12NA Air Conditioner
Sometimes the mitsubishi Mr.slim unit is automatically fully off and an icon is on the remote control is blinking..what is the problem?
Check for timer setting you have done. If it is, reset the power to unit and also remove battery in remote and reset it. If still problem write again plz.
Dec 13, 2010 | Mitsubishi MSZ-A12NA Air Conditioner
How to turn heat on for split system MSZ GE 12NA
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals forall of the Mitsubishi line. The manual include both troubleshooting andinstallation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Nov 06, 2010 | Mitsubishi MSZ-A12NA Air Conditioner
We have a far-let LED flashing 1 second on 1 second off repeatedly indicating a communication error between the indoor and outdoor units. The practical outcome is that the outside condenser doesn't kick...
Call Mitsubishi Tech. directly...
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the Mitsubishi line. The manual include both troubleshooting and installation.
heatman101
Sep 03, 2010 | Mitsubishi MSZ-A12NA Air Conditioner
Heating & Cooling Logo
65 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
