Question about Honda 3000 Watt Portable Generator
I have a honda 3000IS generator it runs good for many hours then it starts idling up and down and quits when we restart it sometimes it runs good again or it may idle up and down and quit again any ideas would be helpful
  • 3,740 Answers
Hi and welcome to Fixya I am Kelly. This symptom is typical of fuel starvation. It can be caused by
1. A dirty fuel filter (if installed)
2. Debris in the bottom of the fuel tank
3. Fuel shut off selector not all the way on or debris in pet-c^ock bowl. This is located on the bottom of the fuel tank.
4. Float needle assy not allowing proper fuel flow in the float bowl
5. The fuel supply line or the plastic "Y" just before the carb is cracked and air is being introduced into the system as the fuel hose swells from heat.
I really think you have a fuel supply issue. A break down can be found here of your carb:
http://www.boats.net/parts/search/Honda/Generator/0/EU3000IS%20A%20GENERATOR,%20JPN,%20VIN%23%20EZGF-1000001%20TO%20EZGF-1079999/CARBURETOR/parts.html
Fuel tank cap removed
You should be able to remove the angled drain screw (Item 6 above link) in the bottom of the float bowl and have fuel flow freely out of the hole. (I use spray paint can cap / lid to catch the fuel. If you can not fill the spray paint cap to the inner circle of the cap in one continuous attempt there is a problem with fuel supply ( 1 - 5 above )
If you can avoid it DO NOT remove the carb. Getting all the linkages correct during reinstallation is tedious even for seasoned techs on this generator. You can safely remove the float bowl and check for debris / give the jets a blast of carb cleaner. If you do use carb cleaner also direct a shot into the fuel hose connection (hose removed) on the side of the carb with the bowl off. The jet is in the very bottom of the center post.
PLEASE do a leak test before starting the engine with the fuel selector on. (Safety issue)
Make sure you replace the fuel tank cap before starting the generator.
Thanks for choosing FixYa.
Kelly
Posted on Aug 05, 2010
  • Kelly
    Kelly Aug 10, 2010
    If your generator has been in service there is a good chance that there is water in the float bowl. On the side of the sloat bowl there is a plug that is at roughly a 45 deg angle. It will be item 6 of this link:
    (Use the fuel tank supply fuel shut off to control fuel flow on / off as required)
    http://www.boats.net/parts/search/Honda/...
    Using a catch basin such as a spray paint can lid, remove the plug (Item 6 above link) and drain out the moisture. You will know for sure if you have water in the float bowl as you will see it in the fuel. If water has been present for sometime it will have a rust color to it. If you see the rust color the float bowl will have to be removed by removing the bottom nut (Item 7 of above link) and the rust in the float bowl will have to be physically removed / cleaned out. There is an O'ring on the bottom of the carb body that you should also wipe clean so that when you reinstall the float bowl that is seal properly.
    Additionally most of these smaller Honda generators have the float needle physically attached to the float itself. Pulling the hinge pin out will remove the float and the float needle. Depending on the float assy used (2 types) the float needle may not be able to be separated from the float assy. The float needle rubber tip should be soft to the touch and the rubber surface should be clean. Using carb cleaner on the float needle and in the needle seating area is recommended. You do NOT have to remove the carb. Just spray it into the hole to remove any debris. When you reinstall the float guide the float needle into the hole, let the opposite side of the float drop down at an angle so you can reinstall the hinge pin. If you use cab cleaner make sure to spray into the very bottom of the center post to clean out the fuel orifice hole. Then reinstall the float bowl.
    Make sure the fuel is on, wait 30 seconds for the fuel bowl to re-fill and then start the unit. Check for residual fuel leaks before returning the generator to normal service.
    Kelly
Why can't i run my a/c with honda 3000is generator
This generator will run an a/c unit up to 13500 btus and is good for 2800 watts. This is a small generator, the nameplate rating numbers need to jive before overloading the energy supply.
Jun 03, 2017 | Honda Electrical Supplies
13,500 a/c blows circuit and won't run off our honda 3000is generator
will it blow any circuit? if so, the a/c has an electric problem. will the a/c run when plugged into a
service power supply?
I have a Miller blue star 3500 with electric start Honda engine.
Have you stripped and cleaned out carburettor?
sounds like a blocked idle jet?
Dec 27, 2016 | Miller Welding Tools
I have an 83 Honda CB650. After running it for a half hour or so, it starts to idle really rough and will die if I don't stay on the throttle. Then it won't restart until the bike has cooled down......
indicates an electronic unit failure from internal shorting and overheating
could be the (ECM)control unit or coil/sif not electronic control , then the ignition module
Apr 24, 2017 | Honda Motorcycles
Honda EU 3000is only runs on half choke
Overhaul the carb. When you have to choke it to run, there is not enough fuel getting in
May 04, 2013 | Honda EU3000iS Inverter Generator
Honda generator starts, runs, then stalls and backfires
Honda makes quite good gasoline motors. I doubt it is a valve timing issue but it might be a burned valve or a valve adjustment issue. What does after a while mean? A couple of minutes or 4 hours? Is it running for just a short while and then stops or it runs well for a long time and then stops?
Aug 01, 2012 | Honda Generator Eb4000x Eb5000x Eb6500x...
1985 Gold Wing Interstate - shuts off after driving 2 or 3 miles. Will not restart immediately. After it cools down will start again and run fine, no missing, but sometimes shuts down again. When...
by the goldwing parts sellers ebay
84 to 89 1200s goldwings have a pulse generator
1984 models have the PGs at the back of the engine. The engine has to come out to get at them, or I think you can pull the swingarm instead.
From 1985 the PGs are under the timing belt covers. Still not the easiest to get at.
a goldwing owners forum
GL1200 Pulse Generators
Apr 16, 2017 | 1985 Honda GL 1200 Interstate Gold Wing
I have an em3500 honda generator which starts stalling out after 1/2 hour to an hour like it is running out of gas and then shuts off. I can restart it and it will run for 1/2 hour to hour and do the same...
Recheck for spark when it stalls. If you have lost spark I would say a heat damaged coil.
You should also drain and inspect the carb bowl. You may have low fuel flow which limits full throttle operation to 30 minutes or less. When it dies you are just refilling the bowl for the next run.
Good luck and be careful!
Aug 10, 2010 | Honda 3000 Watt Portable Generator
I have a 3000is not starting. Has gas spark oil.
Use fresh gas! Dont just pour some on top of the old...Change it out.
Drain the carb bowl (Honda carbs have a drain screw slightly off-center of the bowl bottom).
The Honda EU3000is uses a vaccuum-operated fuel pump and old gas will ruin it also.
Take the fuel supply line off the carb inlet, direct it in a container and spin the engine over. It should pump a stream that is FULL LINE DIAMETER.
If still no start, take it to an AUTHORIZED Honda Power Equipment Dealership.
Find one here.
Hope this helps.
Sep 27, 2009 | Honda 3000 Watt Portable Generator
Battery in a honda 3000is
The battery is behind one of the end plastic casing pieces. You have to remove the center plastic panel, then remove the bolts holding the handle in place, and then remove the small, lower metal panel. I don't remember if it is on the side where the exhaust opening is or not, I believe it is on that same side.
May 04, 2009 | Honda 3000 Watt Portable Generator
Honda 3000 Watt  Portable Generator Logo
651 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
