Question about Dewalt Small Angle Grinder 4 1/2"
Dewalt 28110 I believe since the stickers are off. At work cutting flag stone it started smoking and now it wont do any thing. My boss gave it to me.
  • 2,100 Answers
The brushes are shot and the armature is burned, you need to get the armature out, spin it in a lathe or something to clean it up, a piece of sandpaper, then replace the brushes, blow out all the dust. You might be able to save it. Hope this helps.
Posted on Aug 05, 2010
Ombudsman complaints
Look for legal advice is the first thing you should do when your boss gives you any notice. Someone on the union, will help you, At least he can give a little advice even if you are not a member.
Jun 25, 2014 | Computers & Internet
Why would my dewalt d28402 grinder start smoking?
could have been from an overload situation, usually SMOKE is from the electrical parts e.g. armature/field and would need to be diagnosed and repaired to prevent further damage.
Feb 21, 2012 | Dewalt Saws
Why dose my john deere ltr 180 have smoke near currung deck when i put the cutting deck down
the only thing other than a frozen pulley it could be check the routing of the belt it is rubbing somewhere.
Sep 08, 2017 | John Deere Garden
I have a husqvarna k750 sawing stone stawls under load whats wrong?
If the motor revs up ok it might be the type of disc you are using. I used a huge 2000 Sten one time from about 1961 going through rebar cemented inside cinder block wall to make some windows. It used the huge 18 inch discs and the older guy that was my boss said there is two types of discs - one is tar bonded abbrasives and the other is resin based which is three times better cutting and doesn't smoke up your lungs while you are breathing hard. They are usually dull red with no black in the grit if you look right up close. If the motor stalls or has a cutting out noise at high rev without load it may just be a dust covered gas filter which is deep inside the saw's gas tank on the end of a rubber tube.
Apr 10, 2011 | Husqvarna 965142201 K750 5HP 12" Gas Cut...
NO power wont lift
boss plow will not go up or down, do not have light on main control. Truck lights will go on but when toggle switch is activated, truck lights stay on and plow lights will not go on.
Jan 28, 2011 | 82" TruckSUV Snow Plow
The stone on my chop saw stops cutting. Why?
Sometimes the edgeof a cutting disk can become clogged with particles of the material being cut e.g. cast iron or soft metals.
Try cutting a piece of brick or other hard material to chip away the edge of the disk to expose new abrasive
Mar 30, 2010 | Dewalt Chop Saw D28700
Need replacement parts - accessories
If the kickback arm you seek is the type that is a round bar with pointed fingers on the bottom, I had the same problem. (different model DeWalt) I gave up trying to find one, and finally just made one. It was pretty easy, and works very weill I bought a piece of steel rod (1/2 inch I think) a steel repair plate (from which I cut a pair of tear-drop shapes with a hacksaw and file) a 1/4 inch hex-head bolt (which had about 1 inch not threaded) and a 1/8 inch roll pin. I looked at various pictures on the web to determine the shape of the teardrops. I drilled a 1/4 hole in the 1/2 rod. I cut the threads off of the 1/4 bolt so it was still long enough to accept the 1/2 rod, the two teardrops, 2 washers and the 1/8 roll pin. Then I put an 1/8 hole in the bolt allowing enough clearance so that the teardrops would swing freely. It works like a champ. One minor flaw is that with only two of the teardrops (instead of several) and being separated by 1/2 inch, it would be possible to make a skinny enough rip that only one teardrop would contact the board being ripped, leaving the other peice unguarded.
Jan 23, 2010 | Delta Machinery 10" Professional Radial...
Dewalt cordless drill
You have burned out the drill motor, it is shorted, the battery smoked due to a direct short, one thing I don't understand why the thermal limiter didn't trip in battery pack, I would contact manufacturer and try to get hem to buy you a new drill.
Aug 28, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt Small Angle Grinder 4 1/2" Logo
112 people viewed this question
Top Dewalt Saws Experts
Craig Butler
Craig Butler
JOHN LAPIER
Tim Venetis
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
