I want to know voltage rating of power adoptor
  • 32,281 Answers
On the bottom of your power adapter there is a label printed with the input and output voltage also the output current.
If this adapter is for a laptop, then the label on the bottom of the laptop will show the votage and current requirements for this laptop.
Posted on Aug 05, 2010
I have replaced my new harddisk in my dell inspiron n 4010 and then onwards in my laptop no power is getting and even the led which will blink if the power adoptor is placed even not getting if adoptor is...
Try unplugging it as well as removing the battery. Than press and hold the power button for 30 seconds. If this doesn't solve it, their is a very good chance the motherboard on the computer is fired.
Jun 28, 2011 | Computers & Internet
My ac adoptor has a storhage and I need a new one where can I get a new one(ACpower adaptor)
On the back of one of the speakers, there will be 3 plugs; a green one, a grey one, and a black one. The black one is the power plug. Right below the power plug it says the voltage needed (I could only find one picture online, and it looks like it says 15v, which would be 15 volts). That number is the needed supply voltage, so search google for (number under plug) volt power adapter.
Mar 24, 2011 | Sylvania G-Netbook
I want a Purched a battery and adoptor model DZO-V38 send me rate indelhi ( india)
It is ideal not to waste time but to get your old adapter to be could with one in the general market. The cord of old adapter can be used while the voltage marked on the adapter can be suited from a universal type in the market-- every electronic store/ phone accessories.
Feb 05, 2011 | Aiptek Cameras
Does my ASUS N61JQ-X1 have a dual voltage switch for 110v to 220v and/or vice versa? I don't visibly see any.
notebooks or laptops do not have the switches it totally depends on ur adoptor ... if u are using 110 power the adoptor has to be capable of that and if 220 than too the adoptor should be capable , in the market now aday u get adoptors which handles multiple settings ... best way is call asus cust care and ask them if they have something for it or not if u want u can buy it from them or locally places like best buy and wal mart ... if u have purchsed it in US its bond to support 110... totally depending on the country wher u bought it
Dec 09, 2010 | ASUS N61JQX1 Notebook
#2701HG-B no power
make sure the adoptor is gving proper voltage .it is adoptor problem .
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 21, 2010 | 2wire (2701HG-B) Wireless Router
Monitor does not come on (screen is black) Wife turned off everything was fine now can't get back on. Is there some sort of lock on these units?
dear friend,
please do some activity to conform the problem in your laptop, veryfy while you are pressing the power button after some time, press the num lock or cap luck switch is it working means the light is blowing or not? are able to listen the windows start sound? then connect a external monitor and try to swict the vdo on it? if yes then it is the LCD problem and you need to change the LCD assembly. if no then try the following steps:
1: veryfy your adoptor light is glowing or not? if yes then go to next step, if no then replace the adoptor.
2: remove all the external connection, remove the battery from backsite. remove the power adoptor. press the power button for 2min. then connect the battery, adoptor and try... if no then follow below
3. then try to on the laptop by pressing fn+power on botton. try to refix the ram. is there any LED is glowing or not..........?if no then you need to change the mother board
Jan 19, 2010 | Dell Inspiron 6400 Notebook
No power
if you have voltage check meter just cchke it how much voltage you getting from the power adoptor.
Oct 26, 2009 | Philips Magnavox 26MD357B-37 26 in. LCD...
I am repairing purson in pakistan. and my client laptop have a problem in his charging side, when we connect the New adoptor to charge the Battery of Laptop after some time the power adoptor goeing to...
shortage you need to change the dc jack connector... because is chortage that one if did not replace the dc jact connector.. the same at all even you use the original adaptop or battery
Jun 26, 2009 | HP Compaq nc6120 Notebook PC
LI 6000 2-way charging base does not charge- no indicator light
Dear sir,
It seems that ur adoptor is not ok , u can save the money by purchasing any 9 V adoptor, It available for less than 1 USD in our country ..& cut the wires of ur budled adoptor & fix them in correct polarity with the wire connecting the charger base ..( before doing this proces check voltage output from adoptor by using a multimetre.)
Regards
Raj
Jan 12, 2009 | Cobra Li 6000-2 WX VP GMRS/FRS Two-Way...
Power problem in monitor
This type of problem generally occurs when adoptor stops working and battery goes down. Show first of all check your power adoptor, its working or not, to check-out remove battery and use power adoptor then try to boot. If there is power led on means adoptor is ok otherwise try to reconnect and also check whether the power supply is ok for adoptor. For canfirmation use another adoptor.
If above not working then you can try to these steps:
1. Remove Power connection (Adoptor connection to Laptop).
2. Remove battery.
3. Re-Connect power to laptop.
4. Make switch on.
If above does not work then after step 2 try the followings
A. Press and hold power button for abt 20-30 secs. keep holding on and insert Power connection now if power led get on leave the button. After that it should on.
If all above didn't solve your problem, then its time to take tour of service centre.
Thanks and Good Luck
Iqbal
Aug 16, 2008 | Dell Vostro 1500 Notebook
Computers & Internet Logo
Alun Cox
David Payne
David Payne
