Question about Mitsubishi VS-50607 50" Rear Projection Television
My Mitsubishi vs 50607 has blue green and red lines jumping all over the screen what is the problem and fix
    New Friend:
    Problem Solver:
  • 6 Answers
Also check the solder connections on the convergence amplifier modules. Get a magnifier and look for cold solder connections. I had the same problem with my VS-5002, soldered all the convergence output amp pins and it went away.
Posted on Feb 18, 2015
    Sergeant:
  • 252 Answers
You have some bad filter caps in the convergence section of your set or a bad convergence chip
Posted on Aug 05, 2010
Black screen red curved lines
if it looks 3-D then you need to change the convergence IC's
you can get the complete kit here
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.tvrepairkits.com/xcart/home.php?partner=larry
techman
Feb 18, 2010 | Mitsubishi VS-50607 50" Rear Projection...
I have a Mitsubishi VS 50607 and the sound and color are good, but the screen is jumping. The picture is there but it is almost as if there are two of them. Anyone know of a solution?
Howdy,
CHECK and replace C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB. REPLACE NO MATTER WHAT.
gOOD lUCK, BIG irish.
Dec 29, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Powers on to blue screen and nothing else
press the input button until it cycles through all of the inputs.
Feb 11, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Rolling screen
my screen on my mitsubishi won't stop rolling
Aug 22, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS 50607 Problems
Vertical output IC most likely needs to be re-solderd. However this model is famous for the CRT leaking coolant in the area of the Vertical output IC and corroding the solder. Check for a sticky residule near the Vertical IC indicating a leaky CRT seal.
Apr 09, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi 5o in
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
Feb 12, 2008 | Mitsubishi VS-50607 50" Rear Projection...
I have red green and blue lines thru the screen
Difficult repair = requires chassis pull and convergence circuit
repair.....Replace convergence IC's and any bad soldered in fuses..........then check alignment.................T.
Nov 30, 2007 | Mitsubishi VS-6041 60" Rear Projection...
VS- 60705 Red,green,& blue lines all over screen.
sounds like your screen controls are too high? thay are behind the front cover 6 contols 3 for focus and 3 are screen the screen controls.
Apr 12, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-50607 50" Rear Projection Television Logo
95 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
