Question about RCA Televison & Video
SHUTS OFF AND RESETS MY POWER STRIP - RCA Televison & Video
  • Willard Broughton Aug 05, 2010
    What is the power rateing for your power strip?
  • RCA Master
  • 1,527 Answers
Hello the reason for this is 1 of the components has shorted to ground causing the tv to trip the rcd box don't plug in again until the component is found i'd call an engineer as soon as possible
regards
shaun
Posted on Aug 05, 2010
LG washing machine shuts off randomly, why?
only suggestion, next time it happens, unplug like you've done and then hold in power button for 15 seconds to see if that resets it.
Aug 30, 2015 | LG WM3470HWA Front Load Washer WM3470HWA
A6660z Desktop won't power on
First make sure that if the computer is plugged into a power strip, that the actual strip did not trip during the outage. There is normally a little button on the end of it that resets the power. You can also check this by plugging something else into the power strip to see if that powers on. Otherwise the power supply on the computer may be out and is usually about $50 to replace.
Worst case is the motherboard/hard drive had a complete failure...
Jan 28, 2014 | HP Pavilion a6660z Desktop PC
KDL55HX800 dims and then shuts off and red LED blinks 6 times
IIC bus clock and/or data lines low at power on 06
Aug 25, 2012 | Sony KDL55HX800 55 in. TV
A/C runs three to four minutes; shuts off. Press, reset button, on the power cord (note: a/c inserted in power strip; and I've tried other outlets, as well).
The Power Strip may just be the problem. As far as I know, there are no manufacturers that approve the use of a Power Strip, for their AC unit to be plugged into. I know of two units, that had their electronics fried, while being plugged into a power strip. Which brings us, to the point, that your AC may already being showing the results of being plugged into a power strip. Most don't encourage an plain extension cord
Plug the unit directly into a wall outlet and try lowering the temperature by 3 to 5 degrees F, to see if it will run longer. Also, check your air intake filter and clean it, if necessary.
If the icontinues to turn OFF prematurely, it may be time to decide whether to repair or replace.
I hope this helps you and thanks for choosing FixYa.
Jul 27, 2011 | Kenmore Heating & Cooling
Srtyws
The cheapest method of all.
Make sure your PC is plugged into a power strip and after windows shuts down just hit the off switch on the power strip.
Unless you want to shell out some cash for a new power board for your monitor.
Mar 11, 2010 | Sony SDM M51 15.1" LCD Monitor
Sony KV-34HS420 shuts of and stand-by light blinks
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Source
Sep 01, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Blinking Green Timer Light
I suspect the lamp area is VERY dirty as is the cabinet's filters and fans. This causes great stress on your tv and lamp. Take the time to clean all of them fully. Is the unit in a dirty area? or in a high temp area? DLP's dont like high temp or contaminated areas as they are NOT air sealed units.
Aug 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
TV power problem
Does anything else work in the same outlet?
Also do you have it plugged into a power strip?
Unplug it wait about 20 - 30 seconds and plug it back in see if it resets its self
Jan 02, 2008 | Philips Magnavox 51MP392H Rear Projection...
WHEN PRESSING COOK TIME OVEN CLICKS ON FOR ONE SECOND AND RESETS CLOCK
Please try on some other power point as if there is loose contact or sparking in point which cause to switch off as soon as you start because of heavy current drawn by oven and clock also resets. If not solved even then must have some short circuit or over loading in timer circuit or magnetron. in this case you have to call for a service engineer.
Jul 26, 2007 | GE JVM1860 Microwave Oven
Televison & Video Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
