Question about Frigidaire Refrigerators
I have a black, side-by-side 26ft3 model # GS6SHAXMB00 dated 9-03. The refrigerator door handle is working loose. I do not readily see a way to tighten the handle. Please advise. Thanks, bill
  • lucwp Aug 30, 2010
    There is no plastic "button" covering the screw. Maybe the cover pops off the entire handle?
    Genius:
  • 1,478 Answers
The screw is covered with a plastic.
Use small flat head screwdriver to pop up the plastic cover, its about the size of a penny.
Tighten screw and push plastic cover back on.
Take care.
Posted on Aug 05, 2010
Loose door handle thermador refrigerator
I'd appreciate thoughts on how to tighten THERMADOR not another brand refrigerator door handles. Model: KBUDT4860 A02 which is a stainless steel side by side 2 door freezer / refrigerator. Thanks.
tried the other suggestions above and damaged the surface.
Jan 16, 2013 | Thermador Refrigerators
We have a Whirlpool side by side Fridge/Freezer and the fridge side door handle is very loose and we're not sure as to how to gain access to tighten them up. Any ideas?
Try RepairClinic.com. They may have exploded views of the parts for your refrigerator. They also provide detailed step by step help making repairs. You'll need the approxomate date of manufacture, Model #, and serial #.
Feb 27, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
How to tighten loose door handle
should be a small access cover on the handle top and bottom pop them open with a flat small screw driver screws should be underneath
Jun 09, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Freezer door handle is loose
Usually those handles push directly up to come off the pegs. You really have to "lean in" to push the handle against the door and then try to slide it up. Once you get it off, you can tighten the studs (or whatever hook/clip thingy they came up with) and slide it back on.
Feb 10, 2010 | Frigidaire FRS3R5EMB Side by Side...
On my Kenmore Elite #106.56683501 the refrigerator door is loose
Depending on the model, and the color, here's your fix.
Stainless with stainless handles- you'll need a hex key. The tiny hole is on the inside of the handle, close to the center. Turn the key until it's tightened.
Stainless with black handle/white/bisque/black- push the door handle up. Careful not to scratch the finish! once the handle pops, pull it straight off. Take a phillips head screw driver, tighten the top screw A LITTLE BIT and then attach again. Insert screws on the door into the holes on the handle, slide down. (will need to be a little tough with it.)
Sep 03, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
DOOR HANDLE LOOSE MODEL#gs5shaxnq00 Whirlpool sxs Ref side
Ther is nothong wrong with the ice Dispensing unit the screws in the door handle are loose and we can not figure how to tighten them.
the model# is GS5SHAXNQ00
Aug 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
How to fix loose door handle on GE model DSF25KGTB BG side by sid
If the screws aren't obvious, they will be locater under a pop out plug on under a nameplate on the handle.
Feb 20, 2009 | GE GSS20IEP Side by Side Refrigerator
Loose freezer door handle on my whirlpool side-by-side refrigerat
you should be able to pull straight up on the handle (with force) and it will come loose from the retaining screw. usually its just the retaining clip that comes loose from the door but sometimes you will have to replace the entire handle to repair the unit. if your not having any luck getting it off message me with a complete model number for your refrigerator and i will see if i can get you a little  more detailed information. thx peyton
Jan 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer door handle loose
Can you give me the model number? Ther are alot of variation of handles.
Nov 14, 2008 | GE Profile PSW26P Stainless Steel Side by...
Door handle on 2dr model GS6SHAXMB00 is loose on the top and it will not slide up and off like the reference book shows. How to fix
jjust grab the bottom of the handle and the top and pull up slowly but firmly it will pop loose. If the handle is wiggly then just tighter the screws on the handle to tighten it. It will require a star key so if you dont have one just use pliers to tighten it. be sure to put handle back same way you found it because it has a slight curve on it. good luck! email me if anything at chrisrubio827@yahoo.com
-Christopher
Jun 30, 2008 | Whirlpool Refrigerators
Refrigerators Logo
53 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
