Question about Kenmore 53509 Dehumidifier
My Kenmore Dehumidifier Model # 580.53650200 is not turning on. It goes through it startup cycle and when the compressor should kick in it justs dims house lights for a second and repeats every 15 to 20 seconds but does not kick in. Any suggestions
  • 52 Answers
SOURCE: Kenmore Dehumidifier Isn't Running
It sounds like you have power to the unit but a component is failing to start the system get an AC tech to check it.
Posted on Jun 09, 2009
  • 72 Answers
SOURCE: Kenmore 54701 (70 pt) dehumidifier is not prerforming properly
could be a bad humidistat or a bad PTC relay on the compressor, check for voltage going to compressor, and check neutral continuity, if there is both then you have a bad compressor, check warranty on comp replacement, if no voltage then the humidistat is probably bad
Posted on Jun 13, 2009
SOURCE: compressor does not start
When the compressor tries to start, but only hums and draws a lot of current, the problem is most likely either a bad compressor or a bad run capacitor.
On the Kenmore model 25357510790, the capacitor is a 20 microfarad, 370V oil-filled capacitor, I believe. If you can get one at a reasonable price (around $25-35), it might be worth trying.
If the compressor is bad, the dehumidifier is not economically repairable, if not in warranty. Unless you know someone in the repair business that would do it for you for just the cost of the compressor, that is. ;<)
Other, less likely, problems:
A bad connection (high resistance, say, greater than 2 ohms somewhere in the circuit, including a bad plug or receptacle).
Posted on Aug 24, 2009
dmftrucker
  • 1922 Answers
SOURCE: A one year old Kenmore dehumidifier model
these units are notorious for losing their refrigerant charge,if the compressor isn't running that is one reason why, have a gauge put on the system to see sealed system pressures otherwise the low-pressure switch could be bad,you can test this with a continuity meter
Posted on Nov 14, 2009
heatman101
  • 43501 Answers
SOURCE: the Kenmore 106.955501 dehumidifier works well
The compressor will not start when it is hot or it is no longer bleeding the pressure off fast enough on the high side of the refrigeration system and it cannot start under the load. The start relay and capacitor could also be bad...that would give the same symptoms...
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 01, 2010
Testimonial: "thanks for the info, told me what i needed."
My Kenmore dehumidifier fan runs all the time & compressor kicks in & out. I the fan supposed to run continually.
yes if its less than two years old the new ones run the fan all the time and cycle the compressor off humidity of room , the fans even have speeds on some models so you can turn em down
Nov 08, 2014 | Dehumidifiers
Fan runs and the compressor tries to kick on and there is a low grinding sound and then it goes off and the fan continues to run. The cycle repeats itself and the compressor never engages. It is not...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 03, 2011 | Goldstar DH504EL Dehumidifier
The Kenmore 106.955501 dehumidifier works well when first started, coils get cold quickly, fan runs, air moves well. after 1 hr when the compressor needs to kick back on, the lights on that circuit dim and...
heatman101
May 01, 2010 | Kenmore 54501 Dehumidifier
Fan kicks on but compressor does'nt start. Humidity control checked out. Compressor ohmed out. Fan runs for about a minute then it shuts down.
i would do a continutity check on you relay and overload, other than that
what is the humidity level in the room, as well as the ambiant temp. these mahines cycle for that very reason, the fan will come on, do a check and then determine if it should start the compressor.
check if you have voltage at the compressor when its supposed to be running ( just a last thought)
ive seen compressors ohm out, but in fact be bad
Oct 09, 2009 | Kenmore 54351 Dehumidifier
Lamp(60watt bulb) dims slightly when dehumidifier starts up. The dehumidifier outlet is downstream of the lamp outlet. This dehum draws 5 amps at steady run, not sure what it's pulling at startup. Wiring...
The dimming is probably normal, especially if the motor is a split winding type that has a start and a run winding. Ususlly, it will use a capacitor also. You can view the wiring diagram to see if this is the case.
Aug 12, 2009 | Kenmore 53701 Dehumidifier
Jun 13, 2009 | Kenmore 54701 Dehumidifier
Kenmore 70 pint
you have a bad compressor. The clicking sound is the thermal relay resetting.
Nov 16, 2008 | Kenmore 53701 Dehumidifier
Compressor does not start
some of these units have a 5 year compressor warranty on them including labor worth calling sears and seeing if it does have the 5 year on the sealed system
Apr 09, 2008 | Kenmore 53509 Dehumidifier
Kenmore 53509 Dehumidifier Logo
186 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
