Question about Canon PIXMA MP830 All-In-One InkJet Printer
Error U043 - Ink Tank Cannot be recognized
I get this message after installing new cartridge.
  • 1 more comment
  • Challenge Apr 27, 2008
    Just had unit serviced and ink pump replaced and plugged in and U043 popped up - cannot recognize Magenta ink tank even after installing new Magenta same message comes on menu screen - help?
  • Anonymous May 29, 2008
    I get that message after trying to put in the PG5 cartridge. Please advise what I shold do.
  • Anonymous Aug 22, 2008
    All of a sudden none of the ink tanks are recognised. The lights oh all is not on.
    Problem Solver:
  • 8 Answers
Try to open and close the main cover a bit, ... ink recognition will start and may solve the probleme ...
... otherwise remove the cartridge and clean the chip contacts e.g. with spirit
Maybe also pressing the stop/reset-button for >10s will also help to continue printing, but in this case the fill level of the cartridge will no longer be shown
Posted on Aug 29, 2008
Hi, I refilled cartridge CLI-526M fromCanon Prixma MG5250 and I have the error U130. How can I resolve the error to reprint? Thanks.
FAQ: An Error Message Is Displayed on the LCD
Issue
If an error message is displayed on the LCD, take the corresponding action described below.
Cause
The following ink may have run out. Replacing the ink tank is recommended. U041 Print head is not installed.Install the print head.U051 / The type of print head is incorrect.Install the correct print head.U052 Some ink tanks are not installed in place. U072 / More than one ink tank of the following color is installed. U071 The remaining level of the following ink cannot be correctly detected. Replace the ink tank. U130 The following ink tank cannot be recognized. U043 U140 U150 The following ink has run out. Replace the ink tank. U163 There are no photos in memory card Contact the support center or service center for ink absorber replacement. Press OK to continue printing Ink absorber full. Service required Timeout error has occurred The device may be incompatible. Remove the device and check the manual supplied with the connected device An unsupported USB hub is connected. Remove the hub. B200Printer error has occurred. See the manual **** Printer error has occurred. Turn off power then back on again. If problem persists, see the manual
Jul 06, 2011 | Canon MG5250 Printer
I get the U043 error on my Magenta. Cartridge is set properly.
Ink tank not installed.
[1660]
U043 (Applicable ink tank
icon)
Install the applicable ink tank(s) properly,
and confirm that the LED's of all the ink
tanks light red.
Sep 13, 2009 | Canon PIXMA MP600 all-In-One InkJet...
U043
The U043 error code indicates that an ink tank is not installed. One or more ink tank icons on the LCD should also be lit up. The lit up icon indicates the applicable ink tank. Verify these tanks are indeed fully seated in the print head and that they are lit up red.
You can also press the OK button to clear this message and continue.
May 19, 2009 | Canon PIXMA MP600 all-In-One InkJet...
MP500 ink tank cannot be recognized error U043
I had the same problem. My mp630 is also only 4 months old. I replaced all colour ink cartrdiges(inc black), but was only able to release the function for detecting the ink levels for magenta and cyan. Yellow and black then started giving error message U043, with them alternating between working, but never working at the same time. Getting them all clicked in with the lights glowing red does not solve the problem, as once the printer cover is closed, the same error message turns up. The only thing that worked for me is moving the chip slightly out of alignment, by pushing the sliding chip holder, and I only had to do this twice before they all started working and the printer was unlocked.
Jul 30, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Same problem - two solutions I found helped me work out mine. One said contacts needed to be cleaned and it worked to use a Q-tip and alcohol or just click it in position several times until it recognizes the cartridge - this may work. Another said that they got it to work by installing a brand new cartridge - cool, but I have one full of ink it won't recognize. So I pulled the little circuit board off a used cartridge (like you need to do with some refills) and put it on the cartridge that it wouldn't recogrnize - works great. Still haven't figured out how to get it to acknowledge ink levels though. Canon really should be more consumer friendly since these problems seem to be intended to compel the use of proprietary cartridges.
Dec 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
I have a canon mp510 pixma same message U043 and a u150 fault.
I cant see any chip to replace and have replaced my original cartridges with a non branded cheaper type, this might be why. Does this make a difference or is this the same problem occurring with replacement canon cartridges as well.
Dont want to buy genuine ones if its not going to make any difference.
Anyone who can help me would be appreciated
Nov 14, 2007 | Office Equipment & Supplies
I had the u043 problem on the blue cartridge on my mp830.
I was using non-original replacement inks but re-using the chips from the originals - replacing the blue cartridge would cause it randomly work but i then noticed the chip holder was not centred so I realigned it and hey presto! the problem was solved first time.
Sep 17, 2007 | Canon Pixma MP500 All-In-One InkJet...
Ink Cartridge Error PIXMA MP830.
pleaz clean the cartridge sensor and also align cartridges by program in your manual
Sep 09, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
2,016 people viewed this question
old marine
old marine
