Question about Sharp R-1480 Microwave Oven
Trying to remove r 1441. No screw from the top cabinet to remove. Where are the screws that mount it to the wall?
MicrowaveSvc
  • 9098 Answers
SOURCE: removal from a motorhome
We regularly repair the circuit boards of microwave which are hit by storm surges, etc.
This repair usually runs $39.95 to $64.95, depending on if we have to replace the low power transformer. I just thought I'd mention this if you're interested.
But if you've decided on replacing it, the installation manual should be helpful in removing it from the wall. See it here.
You will need the free Acrobat Reader to view or print it.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Oct 06, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: sharp carousel 1993 r1420b, how to remove from
One of these installation manuals may be close enough to yours to help you: manual 1 | manual 2 | manual 3
Posted on Dec 27, 2009
Testimonial: "thanks for your help, real fast return."
  • 1891 Answers
SOURCE: Trying to remove my Sharp R1830 microwave. We
remove the bottom of micro and filters / with a light look up wher the filter 's are on both sides and you will find a lever that when your pull it .. it will relace from back plate. make sure someone is holding it at this time so it will not fall on range below . ****
Posted on Jan 10, 2010
Testimonial: "Thanks so much...appreciate your help. The old microwave is now off and a new one in its place! Thanks again!"
MicrowaveSvc
  • 9098 Answers
SOURCE: I am trying to remove
We have the service manuals for these models and have uploaded them to our site here and here to help you.
Or our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you're having trouble with the display or cooktop lights, we solve these problems for the $39.95 with a one-year guarantee.
Posted on Aug 21, 2010
MicrowaveSvc
  • 9098 Answers
SOURCE: how to uninstall a sharp 1502 microwave. We've
We have the owner's manual at our site here, and it contains the installation instructions.
Posted on Dec 28, 2010
How to remove ge spacemaker xl
You want to take the microwave off the wall, is that correct. 1st unplug the microwave--plug should be in the cabinet over the microwave. Next--in the same cabinet you should see 2 or 3 phillips head screws with big heads going through the bottom of the cabinet into the microwave top. Have someone hold up on the microwave while you remove the screws. They are about 3 inches long. Once the screws are out, the microwave should tilt forward and downward at the front. The back of the MW sits on 4 tabs on the wall mount plate so to get it off completely you have to lift the back up slightly off the tabs about 1 inch. Feed the power cord down through the cabinet and you are done.
Feb 28, 2015 | GE Profile Spacemaker XL 1800 36"...
I have a GE OTR microwave JVM1460 spacesaver xl1400. I am trying to take it down. I unscrewed the two top bolts from inside the cabinet. I thought it should just swing down on the mounting strip, b
remove-ge-spacemaker-800x800.jpgRemove a GE Spacemaker
The GE Spacemaker series of microwave ovens are designed to be installed above an oven range, freeing up counter space in your kitchen. Some of these Spacemaker models are connected to an outside venting system to carry kitchen vapor and odors outside. Other Spacemaker models utilize a ductless system to do this. Removing a GE Spacemaker microwave oven isn't a difficult task, but, because of the size of some of the oven models, it is a two-man operation. Have a question? Get an answer from an appliance repair specialist now!
Other People Are Reading
Things You'll Need
  • Assistant
  • Sharp knife
  • Phillips screwdriver
Instructions
    • 1 Open the cabinet above where the Spacemaker microwave oven is installed. If you see a vent in the cabinet leading to the Spacemaker oven below, your Spacemaker is vented. This vent needs to be disconnected before continuing with removal. Disconnect the vent either by loosening the duct clamps or by cutting the duct tape away with a sharp knife. Pull the vent out of the top of the oven.
    • 2 Have an assistant support the oven from below. Loosen the mounting screws connected to the Spacemaker through the cabinet bottom. Loosen the screws by turning counterclockwise with the Phillips screwdriver.
    • 3 Unplug the Spacemaker from the socket in the cabinet.
    • 4 Continue loosening the screws while your assistant holds the oven in place. Once the screws are removed, have your assistant slowly lower the Spacemaker down by lowering the front face at a 45-degree angle.
    • 5 Feed the power cable for the Spacemaker through the hole in the bottom in the supporting cabinet.
    • 6 Help your assistant slowly pull the Spacemaker forward and out of the mounting brackets on the rear wall. Once the Spacemaker is cleared of the mounting cabinet and rear wall, set it down.
    • 7 Remove the mounting bracket from the rear wall by loosening the screws.
Read more : http://www.ehow.com/how_7344250_remove-ge-spacemaker.html
Nov 26, 2014 | GE Microwave Ovens
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
HI,
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Instructions
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
Jun 16, 2010 | Frigidaire Microwave Ovens
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
NEED TO REMOVE WALL MOUNTED GE JVM1190BY002 MICROWAVE
I also have a JVM1190 and was baffled as to removal. My very handy brother solved it in two minutes. Above the door and keypad there is a long grill secured by two small squarehead (Robertson) screws. Remove the screws and grill and you will see on either side of the opening a long bolt. They go through to the back of the microwave where the support plate attached to the wall. The bolts have a slot in the middle for a flat blade screwdriver. Simply turn the bolt to release from the back plate. Make sure there is a helper underneath as the microwave is fairly heavy. Do the reverse for re-installation.
Nov 15, 2008 | GE JVM1190 Microwave Oven
How to remove a sharp r 1481 over the counter microwave
If you are referring to an over your stove combination microwave/ vent system then they are typically secured thru the cabinet above them. Try opening the cabinet directly over the oven ( you may need a step ladder to see the mounting hardware) and look near the front of that cabinet for two screws on the bottom of that cabinet. These two screws go thru the cabinet and support the front of the microwave oven. You may also see the power cord for that mircrowave oven plugged into a receptacle inside that cabinet. Unplug that cord and then begin unscrewing the two screws. ( it's best if you have a helper work with you).. as you unscrew them, the front of the microwave should begin to drop down a bit. Once the screws are removed, you should be able to lift the back panel up a little bit to free the microwave of the wall mounting bracket. Once that is doen, you will be able to remove the microwave. I am assuming that your microwave does not have any vent pipe secured to it. If it does, then you will need to seperate that from the microwave vent on top ( assuming it is venting thru the top) .. These microwaves can be vented in any of 3 ways, thru the top, outthe back or configured to vent back into the room. In any case, you should see ductwork while removing this from the cabinet. Hope this helps you get the job done...
Sep 13, 2008 | Sharp Microwave Ovens
1985 GE Microwave Spacesaver Uninstall
A possible solution:
I was facing the same problem with my (1998?) GE JVM48006. In this models case, the microwave was housed in a support cabinet that was fastened to the wall behind. First, I removed the phillips head screws behind the louvered vent above the microwave. Then, I removed the screws of the slanted bottom panel that give access to servicing the stove top lights (underneath the unit) which were integrated into the support cabinet (separate from the microwave itself). On the right side was an electrical wire harness hidden behind a cover that had to be unplugged (similar to a car wiring harness). Then, I removed (4) 5.1/2 inch hex head bolts that secured the unit through the cabinet above. Now I was able to slide the microwave out towards the front (with some rocking back and forth). All that was left then was to remove the support housing (fastened to the back wall).
Aug 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore galaxy model 721 microwave hood combination
You put a mounting plate on the wall behind where the unit will be mounted. Then the microwave hooks onto the bottom of the mounting plate and you swing it up to the cabinet above it. Then you must screw 2 mounting screws through the floor of the cabinet above into the bracket on top of the microwave.
Jul 01, 2008 | Microwave Ovens
Removing Old Built-In Microwave
You did not note your Make and Model. As there are many different types, all I can give you are basic directions.
First make sure the Power Cord is UN-PLUGGED from the wall.
1. Remove the Top Vent Grille Cover. There are screws holding this on, either Three you can see (one on each side and one in the center), or Open the Door and look for screws at the top of the Frame that go Up Into the grille.
2. Look in cabinet above unit for screws that hold unit up. Usually two (one on each side, front), can be more. Remove.
3. Look where Top Vent Grille Cover was removed. There should be a Long Screw or Screw-Type Lock at each( top) corner. These hold the unit tight on the Wall-Mount Plate. Remove. You should have HELP at this point as you will slide the unit forward until it comes clear of the Support Arms.
GOOD LUCK!!
Jan 31, 2008 | Microwave Ovens
Removal
There are 3 mounting screws that anchor the microwave to the cabinet above it and a bracket on the wall behind it. Once you remove the mounting screws from the top, pull the oven straight out from the front and it will slide off the wall bracket.
Nov 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp R-1480 Microwave Oven Logo
56 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
