I have a canon ir 3200c copier asking to replace drums all 4 i just want to reset code can you help me
  • osilva004 Aug 06, 2010
    i just need to know how to resetdrum replcement code
  • 10,515 Answers
Unfortunately, there is no way to reset the counter on this model unless a new drum is fitted.
You could find the same information in the service manual. If you wish to go for service manual, you could buy it from :-
http://www.tradebit.com/filedetail.php/4550842-canon-ir-c3200-series-copier-service-manual
Good Luck!!
Thanks!!
Posted on Aug 06, 2010
  • 2,272 Answers
Did you tried replacing all the 4 units.and checked.If the toner is got low then it will show the error codes and this is indication to replace the drum units. Keep updated.with any error code received after replacing the drum units.
Posted on Aug 05, 2010
  • 677 Answers
Messing with the drum could be dangerous. The drum operates with high voltage. It would be advisable to have replaced by a professional tech
To reset
. Press the additional functions key - that is they key with the star inside it - then select 'system settings' then 'network settings' then select 'ip setting'. Once you've got into the ip settings you can enter all your own network settings. All you need to enter is IP address, subnet mask and default gateway but you'll know all that.
  • osilva004 Aug 05, 2010
    what setting IP have to do with resetting drums plesae help
  • ikechukwu joshua
    ikechukwu joshua Aug 06, 2010
    Try this: POWER ON THE COPIER, when copier is ready than press (four
    steps) " C , exp. button left , C ,exp. button left " display go
    blank, then enter 24,press start, enter 7 , press start, After
    display blinks few times you just switch OFF and ON the copier. Drum
    indicator is now off! You have 12.000 copies credit.
    BR
Clearing error e000067 canon irc2880i
Error Code Canon IR C2880i E-067-102 - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Feb 6, 2013 - 10 posts - ‎5 authors
I have a Canon C2880i that has been giving strange messages. It started with the ... Had to clear dc-con for the drum lifes to regulate. Problem I ...
Canon ImageRunner Error Code Reset - Question Defense
https://www.question-defense.com/.../canon-imagerunner-error-code-res...
Nov 10, 2008 - These are the steps to resetting error codes on the iR5570/iR6570 and other ImageRunner printers. This also refers to eCopy, so follow the ...
How to give code for Normal ERROR in canon IR 3300 ...
? 2:28
https://www.youtube.com/watch?v=WyVgSjP_xms
May 19, 2014 - Uploaded by Prince tv
How to give code for Normal ERROR in canon IR 3300 ... thank you sir my canon ir2870 err no E000002-0000 ...
Jan 18, 2016 | Canon Office Equipment & Supplies
Hello possible to obtain the device reset canon 2202
canon ir 2202 - The Copier Network
www.thecopiernetwork.com > ... > Canon - Black and White
Jul 31, 2014 - 2 posts - ‎2 authors
am facing E0001-000 on new canon ir 2202 ; can any one know how to reset error from this model?
Canon imageRUNNER 2202 - Canon Europe
www.canon-europe.com > For Business > imageRUNNER 2202
The imageRUNNER 2202 is a basic solution to your A3 black and white ... Requestinformation ... Canon's toner and long life drum technology allow users to run theirdevices for longer without the need to often replace consumables. .... We use cookies to provide you with the best possible experience on our website.
Canon iR 2002 2002N 2202N - YouTube
? 1:36
https://www.youtube.com/watch?v=I5ywBlOfwPA
Sep 28, 2014 - Uploaded by Shageesh A
Canon iR 2002 A3 Print, Copy, Scan Canon iR 2002N A3 Print, Copy, Scan, ... How to reset ID and PASSWORD ...
Dec 21, 2015 | Canon Office Equipment & Supplies
Canon2202ir E0000-000 This error code deals with the fuser unit. It is saying that the fuser is not warming up. It needs to be reset in service mode.
How can I enter service mode on canon ir 2202? - Fixya
www.fixya.com/.../t25374950-any_one_help_me_enter_service_mode_...
Jan 19, 2015 - In standby mode, press the "Settings/Registration" key. 2. Press the "Reset" key. 3. Press the "Back" key. 4. Press the "Settings / Registration" ...
Error Code ir 2202n - CopyTechNet.com
Nov 22, 2014 - 3 posts - ‎2 authors
... pls help me ....i know how to enter service mode but ......pls help. ... Copier Technical Discussion · Canon. [Error Code] ir 2202n ... ir 2202n. how to print jam history in ir 2202.......i dont know pls help ... mm its a new machine , i need to know how to enter the service mode if u please ... Press the "Reset" key. Error Code canon image ronner 2202N
Aug 21, 2014
Canon IR 2200 error E000001-002
Jun 18, 2009
More results from www.copytechnet.com
Dec 21, 2015 | Office Equipment & Supplies
System error 007 for canon ir 2018
this is error for fixing film rotation. There is no reset code, you need to replace fixing film in fixing unit, Fixing unit is located under left sideway door above drum unit ( green roller ).
Call service!
Aug 26, 2011 | Canon iR 2016i Black and White Copier
I have an e 000012-0002 error on my ir 3100 - can you help please?
Hi error code refers to a drum drive motor error code,
more than likely you have a tight Drum. remove drum and see if you can turn it by hand if not replace the drum unit
Oct 02, 2009 | Canon imageRUNNER C3200 Copier
Error code E000020-01b0, E000020-0260
E020 is a Drum/developer error code
-01b0 is a yellow drum error
-0260 is a magenta drum error
drums need replaced
7622A001AA Yellow drum part#
7623A001AA Magenta drum part#
7624A001AA Cyan drum part#
7623A001AA Black drum part#
Aug 20, 2009 | Canon imageRUNNER C3200 Copier
Canon IR C3200 Error Code E000020-03C0?
plz tell me reason of e602 code in canon ir c3200
Mar 20, 2009 | Canon imageRUNNER C3200 Copier
Canon IR 1600 error message
Note: To reset E000, E001, E002, E003, go to service mode 4. select SET, go to "#7 PRINT-ER," in service mode. Then press Execute "#4 PRINTER RESET." Power the unit off/on.
May 17, 2008 | Canon imageRUNNER 1600 Laser Printer
37 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
