Question about Canon PowerShot S3 IS Digital Camera
My power shot keeps giving "change batteries" message. I've changed and checked batteries, and they are fine. It happens every time I try to shoot, and I am able to shoot one picture before camera shuts down. All I've done is change the batteries.
  • Dianna Ritchie Aug 11, 2010
    My camera is a Canon PowerShot S3 IS
    Keep getting error message to change batteries
    Have changed memory card
    Batteries
    Cleaned contacts
    pulled on contacts
    Camera turns off after one shot
  • Dianna Ritchie Aug 14, 2010
    My Camera will only take one picture and then shut off.
    I have changed batteries.
    Cleaned contacts in camera, and batteries.
    Are there any other ideas?
  • 10,515 Answers
The problem lies when batteries doesnt have enough power in it.
so either you need to charge your rechargeable batteries..
Are you using rechargeable batteries??
If you are just using plain batteries:
You're using the wrong type of battery. Regular alkaline batteries are not good enough to use in a high drain device like a digital camera, because they don't have much power in them. So, using them is a complete waste of time and money because they drain too quickly and once they're dead you have to throw them away.
The most economical type of batteries to use are rechargeable AA NiMH (high capacity, 2500-2700mAh). Using this type of battery will provide you with much more power than the regular ones, and will allow you to shoot approx. 400 images per full charge, whereas if using regular alkaline batteries, you will only be able to shoot around 150 images or so.
If you are using rechargeable batteries then re charge them and put them back in.
Other than this, there could be 3 more problems :-
1. Dirt, dust and debris on battery connectors. You could try to clean it with cleaning solution and clean cotton.
2. Sensor is at fault and needs replacement.
3. There is a fault in the circuitry that makes the battery to be exhausted very soon. The usual symptom of this fault is ' Battery would be very hot when touched '.
Good Luck!!
Thanks!!
Posted on Aug 14, 2010
  • 85 Answers
Hi, First try to reset you camera to default setting and clean the battery contact. If you can lift up the color gold pin using a tweezer or use paper clip,that you can found inside of the battery slot.sometimes that pins was goin down and cause of loose contact to the battery.
if the problem still occur bring to service center and request estimation first before they proceed to repair.
Good luck and thank you my friend
Posted on Aug 11, 2010
    Thanks Jonas,
    I've tried all but all of your suggestions except resetting camera to the default setting. I will do that next.
    President:
  • 2,185 Answers
The battery you are currently using could not be providing enough current volume on the camera. Make sure you are using Alkaline battery and NiMh.
Also, check if the contact areas of the batteries and the springs inside the battery compartment are free of dirt of rusts. This might result to low battery as well since it loses elasticity and will tell the camera to change battery. Clean the these contact areas or terminals and adjust the springs by pulling a little up with a small hook.
Please let me know how this goes. Thank you for using FixYa.
Posted on Aug 05, 2010
  • Dianna Ritchie Aug 10, 2010
    Okay, I have tried changing batteries, cleaning contacts, and tugging on springs. I can
    still only take one picture before camera turns off.
Camera has failed to operate giving a "change batteries" message
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Nov 29, 2009 | Canon PowerShot S3 IS Digital Camera
Underexposure problem maybe? please help!
Your camera probably needs a new battery.
The light meter needs sufficient power (5.5v to 6v) to work correctly.
Your ISO could have moved, even a double or halving of it will over/underxpose a full stop.
Nov 10, 2009 | Canon EOS-AE-1 35mm SLR Camera
Batteries won't hold charge.
What batteries are you using and how large a picture are you taking. Set the picture quality lower. 300X300 is fine for up to 8X10 enlargements. If you are using the preview screen for each shot, that uses battery power too. Don't use cheap batteries. They will let you down. Duracell or Energizers will give you better service than other batteries.
Aug 08, 2009 | Canon PowerShot A470 Digital Camera
I have the canon power shot 590 digital camera i keep getting the message CHANGE THE BATTERIES I CHANGE THE BATTERIES AND I GET THE SAME MESSAGE IS IT THE AMERA OR THE BATTERIES? ANN
are you changing them with top quality alkaline batteries... digital cameras basically eat batteries and you should invest in some rechargable batteries for it.
Robert
Jan 23, 2009 | Cameras
Change batteries message pops up with new batteries
Chargeable batteries usually last for a year or two. Alkaline batteries should only be expected to last for around a dozen shots (as such, NEVER rely on alkaline batteries). Recommend buying another set of NiMH rechargeables. Make sure you get 2500 mah or better power rating (look on the package).
Jun 23, 2008 | Canon PowerShot A85 Digital Camera
Camera not taking pictures
The camera may be trying to tell you that your flash is turned off in Auto mode, but to get a proper exposure you will need the flash turned on. Try turning the flash on and see if that works.
Hope this helps!
May 20, 2008 | Canon PowerShot A540 Digital Camera
For use with compatible battery only????
I've heard of this issue with more than one Sony (seems like there was a post in the forum not long ago with the same issue...). If you've bought a new battery, the problem would appear to be in the camera's power controller. With that in mind, I'm afraid you'll have to decide if the cost of repair is worth it, rather than simply putting the money toward a new camera.
Farid
Mar 23, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Change battery message
I am experiencing exactly the same problem with my Canon Powerhot S2IS. I tried the same thing to remedy it by cleaning off the contacts, but no luck. And it's not simply a cold weather problem. My camera does this with brand new Duracell batteries as well as with freshly recharged NMH batteries. What gives? I've had the camera for nealy 2 years and have taken excellent care of it.
Oct 24, 2006 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot S3 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
