HEY,MR.GURU, ON 4/10 A QUESTION WAS ABOUT (DEAD) SONY 40". THE STANDBY LITE WAS ONLY THING HAPPENING. MIND IS DOING SAME THING. LIKED YOUR ANSWER, BUT I PAID $1400.00 2 YRS AGO. TODAY THEY SAY IT SELLS FOR AROUND $600.00. DEALER WAS REX ELECTRONIC WHICH HAS CLOSED DOWN. IS IT WORTH TAKING 50 MILES TO HAVE IT FIXED. OR SHOULD I CONSIDER NEW ONE. COUNTRY BOY FIRST LCD TAKEN OUT BY POWER SURGE. EVEN HAD SURGE PROTECTOR ON IT.
  • 12,061 Answers
"IS IT WORTH TAKING 50 MILES TO HAVE IT FIXED" (sic) Well this depends on EXACTLY what is wrong? I would do so, initially to find out whats what..
One has little to loose if one takes the unit in to the repair place and asks for a "Quote" before proceeding with any repairs this way you can get an idea of costings and weather to repair or replace.
Unfortunately the reality as you have discovered is that they go down in value by under half almost as soon as you buy it!
I always tell my clients that they must consider replacement, and putting the monies that would be spent into a nice new unit, with a warranty, and also they will be up-to-date with current technology.
Often my clients,do not go through with repair, unless it is of moderate cost, but in some of the more costly jobs, they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the OLD TV down, and sell the Known Good bits. You'd be surprised who needs parts, i myself often must by from third party sources to effect a repair. So money could be recouped, somewhat,and help out someone else.
Power surges are a real bane, we get them all the time these days, and surge busters seem to do little to protect equipment, however it is always better than nothing.
Posted on Aug 05, 2010
My 15 month Celcus LCD423D913FHD tv will not turn on. The standby light is lit and will flicker but will not power up the tv. What is the likely problem?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 20, 2014 | Televison & Video
My caprice is dead
You could have a failed ignition switch or any part up to and including the starter.
Mar 07, 2014 | 1978 Chevrolet Caprice
2004 trailblazer, after getting gas,check gages lite came on, then turned off. truck running rough and after going over 40 miles per hr, service engine lite flashes.
Sounds like there was water in the gas, which would make the engine run rough, service engine lite might go on. Try adding an octaine additive to gas.
Oct 24, 2013 | 2004 Chevrolet TrailBlazer
Sony Bravia KDL-40V5100 stuck in stand-by mode
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.6_8_2012_3_55_52_pm.jpg6_8_2012_3_56_10_pm.jpg
Jun 08, 2012 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
Lg 40 tv shuts off
ISSUES:
Answers to issues:
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_14_2012_2_38_47_pm.jpg
May 14, 2012 | Universal 40-42 Inch Flat Screen Panel...
Hallo! I have a sony kdl 46d 3550 that blink 2 times then pause I checked the power but I do not find the fault Please help...
ISSUES:
Answers to issues:
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_3_2012_10_26_37_pm.jpg
May 03, 2012 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Why does my sony tv turns off buy its self
All sets have a latch or shutdown which is monitoring things--something wrong it shuts down the set----a general answer:
ISSUES:
Answers to issues:
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.4_27_2012_5_30_46_pm.jpg
Also: All Sony sets usually will have a red light that if set fails to come on will blink a specific number of times---an error code specific to each model set.
Apr 27, 2012 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Sony Bravia KDL-40v2500 not on
ISSUES:
Answers to issues:
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
If the set is opened up at least look for bad puffed up caps like these.
Apr 17, 2012 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Picture get dark than light
On your remote control, press the huge circle, which should be settings or menu, there, go on brightness, put it up to max if u want bright, and low if u don't .If the problem still happens, ask customer service to help, or return it!!
Feb 19, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
