Question about Jenn-Air JCD2389G Side by Side Refrigerator
Refrigerator and freezer not cooling sufficiently
  • Jenn-Air Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
y
Posted on Sep 30, 2010
Refrigerator is not cooling Sufficiently ? Freezer is not Freeing
check for ice or frost on the back wall of the freezer, this would indicate a defrost issue... if no ice and the fans are running I would check for a sealed system problem next............. hope this helped... ken
Sep 30, 2014 | Samsung Refrigerators
Refrigerator is not cooling sufficiently. Freezer and icemaker both work. 33 months old.
check and see if your evaporator fan in freezer is running, and the settings and operations of any vents or dampers between freezer side and refrigerator side
Jul 04, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer cools & makes ice but refrigerator side does not cool sufficiently.
First thing check and see if the fan motor in the freezer is running, it circulates cold air to the refrigerator. Then check for ice anback panel of freezer if there is ice you have a defrist system problem
Jun 23, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Our Top Freezer Refrigerator, Amana, doesn't seem to be cooling sufficiently. Particularly the freezer. It's about 10 years old. I've vacuumed the condenser and grille at the back.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Mar 01, 2011 | Amana ATB2135HR Top Freezer Refrigerator
Would like to put older side by side refrigerator in our garage. I was told in the winter, when it gets cold the freezer side will not keep foods frozen. I had an older top freezer refrigerator in the...
It could be a problem depending on how cold your garage gets in the winter. Most refrigerators depend on the compressor turning on to cool the freezer section and that cold air is used to cool the refrigerator section. If your the temperature in your garage gets in the 30-40 degree range in the winter. The compressor may not turn on sufficiently since the refrigerator is typically around the 35-40 degree range. This will cause the freezer to warm up to the fridge temperature and your freezer items will defrost.
Nov 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator is not sufficiently cold. Changing
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Jul 14, 2010 | Sub-Zero Bottom Freezer Refrigerator
Subzero does not cool sufficiently, even with cool
yes you have 2 compressor. ona for fridge one for the freezer..
Nov 29, 2009 | Sub-Zero 650/SRH Stainless Steel
650 won't cool down to set temperature
Clean cooling coils. Check refrigerant level.
Jul 07, 2009 | Sub-Zero 650 / O Bottom Freezer...
Refrigerator not cooling sufficiently/ Freezer not freezing
Yes, if defrost board is bad it will cause problems. Need to listen for fan inside the freezer compartment also. If freezer does not defrost cold air will not circulate properly causing warmer temperatures inside refrigerator. Is model number SXD524VW ?
Let me know, Thanks, Sea Breeze
Mar 26, 2009 | Amana SXD524VW Side by Side Refrigerator
Not cooling enough
heatman101
./vnhc
Jan 23, 2009 | GE PTS25LBM Top Freezer Refrigerator
Jenn-Air JCD2389G Side by Side Refrigerator Logo
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Jose Pino
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
