Question about NetGear DG834G Router
Wep key I am trying to connect a macbook to the wireless router, i cannot remember the wep code and do not know how to access it either, i am curently on line by the ethernet.
  • Anonymous Apr 29, 2008
    wep key missing and lan proxy also required
Depending what router you have you will have to access the setup page by using your internet browser and typing in something like 192.168.0.1 This will allow you to then insert your username and password which will allow you to be able to see the WEP key. ( you will have to google your router model to find out how to access the setup pages so you can find the ip address to use instead of 192.168.0.1 )
Posted on Apr 29, 2008
What is the wep key on my psp to 2WIRE140
The WEP key is defined by the person who set your wireless router up. You will not be able to find out what the WEP key is, but you CAN change it if you have physical access to the router. If you are trying to connect to your wireless router and can't remember the WEP, then walk over to the router and on the back or bottom of it is a small little hole that you can fit a pen or paper clip into. Press the paper clip into the little hole for 10 seconds and release. This will reset all the settings on your router back to default and will allow you to access your wireless connection.
Note: doing this will take away all of your wireless security so make sure that you know what you're doing before messing with it!
Thanks and please rate if this helps you at all :).
Mar 30, 2011 | Sony PlayStation Portable (PSP) Console
I just bought an apple I pod but I can't connect it to the network. User name is Greatest Mom but I can't remember the password so I can connect. Is the someway to find out what the passsword is. I am...
Mar 29, 2011 | D-Link Xtreme N DIR-655 Wireless Router
Im trying to get my wep key to connect to my p3 but the codes on tthe router doesnt work..how do i get my wep key??
To access the configuration utility, open a web-browser such as Internet Explorer and enter the IP address of the router (192.168.2.1).
Enter the password (admin), the default PWD.. Leave the username blank by default.
If you have change the password to the router type it in , if you do not remember it, you will need to reset the router.
Click on the Wireless tab, then security tab under it. There you will see your WEP key.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 19, 2011 | Linksys WRT160N Wireless Router
HOW TO FIND WEP SECURITY CODE
You can acquire the Wep Key or Network Key by accessing the Wireless Settings Page of your router. I've listed the steps below to access the router. Make sure that your using a working computer that is connected to the router
To access the router page just open a browser then type 192.168.0.1. the username is admin and the password is blank. Go to Wireless Settings Page check the SSID or Network Name and Network Key or Wep Key. You can personalize the SSID and Network Key so that you can easily remember it.
Rate me if this will help you so that i can help other people
Thanks for using Fixya.
Jan 31, 2011 | D-Link 802.11g 54Mbs Cable/DSL...
Need a network password so i can get internt on my
Hi...
If you are trying to access the page 192.168.0.1 via wireless connection then I'm afraid it won't work.
You need to be connected to the router before you can access the routers set-up page.
You have 2 options.
1. Connect your macbook to the router with a ethernet cable then access page 192.168.0.1 or
2. On the back of the router is a small hole. (Reset Button) Using a needle or paper-clip press this button for about 10 seconds then release. This will reset the router to factory default settings and usually (Although not guaranteeing this as can be configured differently depending on where the router came from) mean that wireless is "OPEN" in other words no wep/wpa required.
Then you can access the page and set things up with passwords etc you can remember.
Also underneath the router should be the default wep key "IF" the wireless is passcode enabled.
And despite using 2 different netgear routers and updating the firmware. I have to now tell you.
They constantly locked up and dropped my broadband connection so bad I purchased different equipment.
Just FYI if you get connection issues.
Jul 17, 2010 | NetGear DG834G Router
Need wep key i am trying to install a wireless printer and have no idea what the wep key is for my router. how do i find this out? thanks
Go to your wireless router software, log in, and click on the security setting section. Create a WEP key by providing a secret code or password that restricts access to the network.
It can be anything ya want, as long as it is same at "Both ends" IE: when ya try to acess, connect to the Network/Router, from say a lappy, ya gonna get asked for ya" WEP Key" < READ "Password".. So ya type in the number/password ya first chose and put into the router. You generally only have to do this once and it will remember the setting for future access.
Jan 24, 2010 | D-Link DIR-615 Wireless Router
Where do I find my WEP key
To access the web-based utility, launch the web browser on
your computer (INTERNET EXPLORER), and enter the Router’s default IP address, 192.168.1.1, in the Address field/bar. Then, press Enter. A password request screen will appear. Leave the User name field blank then default password admin. (You can set a new password from the Administration tab’s Management screen.) Click OK to continue.
The Internet Setup section configures the Router to your Internet connection. Most of this information can be obtained through your ISP/ your internet provider. Internet Connection Type Select the type of Internet connection your ISP provides from the drop-down menu. By default, the Router’s Internet Connection Type is set to Automatic Configuration - DHCP, which should be kept only if your ISP supports DHCP or you are connecting through a dynamic IP address. 68be046.jpg IMPORTANT: If you are using WEP encryption, always remember that each device in your wireless network MUST use the same WEP your wireless network will not function properly.
WEP Encryption Select a level of WEP encryption, 64 bits
10 hex digits or 128 bits 26 hex digits. The default is
64 bits 10 hex digits.
Passphrase Enter a Passphrase to automatically generate WEP keys. Then click Generate.
Key 1-4 If you did not enter a Passphrase, enter the WEP key(s) manually.
Click Save Settings to apply your change
Nov 21, 2009 | Linksys Wireless-G WRT54GS Router...
T my WEP key is there a way I can find it
Hi!
WEP consists of 10 number and letters and is usually under your Wi-Fi (wireless) router...enter that code into ur PSP and it will grant u access to the internet.
Or type 192.168.1.1 or 192.168.0.1(which ever your router has set to access it) into your web browser and your loginour password is usually admin and Password is usually blank (as in don't type anything in it) for your router will pop up from there you can find your wep key or you can turn the wep off so your psp will not need a wep key.
Please rate this solution.
Thanks
Rylee
Feb 14, 2009 | Sony PlayStation Portable (PSP) Console
WEP key recovery
WEP is only for wireless connections. Connect to the router using a cable, enter its admin and see/change the key.
Jan 09, 2008 | Actiontec GT704WG Wireless Router...
NetGear DG834G Router Logo
384 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
