Question about Garmin nuvi 650 GPS Receiver
Hi guys. I have a nuvi 650 that has a touch screen that has to be recalibrated at all start up`s and will require a recalibration during use. This has has become very dangerous during trips to use as a nav. tool for gas / food . To give more description all pressure points shift right by a half inch or more.At main screen you have to touch the right edge of the screen to go to tool setup for recalibration.
  • Garmin Master
  • 2,130 Answers
Please see this link for more info on this common problem.
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Posted on Aug 10, 2010
  • SHARCNET-USA
    SHARCNET-USA Apr 12, 2011
    The fact that you are constantly having to recalibrate indicates a defective "drifting" touchscreen. It needs replaced.
My touch keyboard doesn't work
You need to recalibrate your touchscreen. If the screen can not be recalibrated, then it needs to be replaced. Please see this link on how to recalibrate your touchscreen:
Use the Nuvi 14xx procedure
http://www.sharc.net/discus/messages/6/77.html?1315261162
Apr 10, 2013 | Garmin Nuvi 50 LM
My nuvi 650 screen won't work can u help me
This is a common problem, caused by a touchscreen failure. You can try to recalibrate the screen. If this doesn't work, then the touchscreen will need to be replaced. The recalibration prodedure can be found here:
- Jim
Jan 22, 2011 | Garmin Nuvi 660 GPS Receiver
My Garmin 660 Nuvi touch screen will not respond I have put in the latest update, held the start button down untill the touch dot calibration shows and tryed the reset button none of this has worked, no...
This is a common problem due to certain style of touchscreen that is known to fail due to temperature. if you can not recalibrate the screen, then the touchscreen needs to be replaced. More information, including the recalibration procedure can be found here:
- Jim
Jan 18, 2011 | Garmin Nuvi 660 GPS Receiver
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
Touch screen not responding at all. Garmin powers up okay.
This is Garmin's response to me after having the same problem on a 2 year old Nuvi 650: We are no longer replacing or repairing this model unit. However, let me give you some steps to try to calibrate the screen of your unit. The following 'Fix' did not work. I won't be buying another Garmin.
To recalibrate the touchscreen on your nuvi 600 series device please follow the steps below:
  1. Plug the device into the computer via USB data cable
  2. Double click My Computer (Mac Users can skip this step)
  3. Double Click the Garmin or nuvi drive
  4. Double click the Garmin folder
  5. Delete the GUPDATE.GCD file (if this file is not on the device please skip to the next step)
  6. Unplug the GPS device from the computer
  7. Power the device off
  8. Press and hold the Power button
  9. After a short period a screen should appear that says Touch Dot
  10. Release the Power button
  11. Touch the dots as they move around the screen.
Your touchscreen should now be recalibrated.
If the screen is still not responding, then the unit will need to be replaced with a new unit at this time.
With Best Regards,
Benjamin B
Product Support Specialist
Automotive Team
Garmin International
913-397-8200
800-800-1020
913-440-8280 (fax) Att: Benjamin B, Associate #6891
www.garmin.com
Additional solutions may be found at http://www.garmin.com/garmin/cms/site/us/support/searchsupport
Sep 05, 2010 | Garmin nuvi 650 GPS Receiver
Gramin GPS screen not responsive
Hi,the problem you are experiencing with your GPS device can be solved by simply recalibrating the screen.this is how you recalibrate the screen of your device;
1.Touch "display" .
2.Touch the "recalibrate" button,then follow the on-sreen instructions,until you are done.
Thanks and take care
Apr 22, 2010 | Garmin nuvi 750 GPS Receiver
Touch screen not functioning
Please see this link. Most likely uou have one of the newer SHARP touchscreens that is known to fail prematurely.
- Jim
Dec 15, 2009 | Garmin nuvi 650 GPS Receiver
Garmin Nuvi 650 Touch Screen trouble...
Yes, this is a common problem with a new style screen being used by SHARP. Please see this link:
- Jim
Dec 07, 2009 | Garmin GPS
Garmin nuvi 650 GPS Receiver Logo
197 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
