Connecting a laptop to car sound speakers
HI...I was wondering if it was possible to connect my laptop to the IPOD socket in the car in order to get the sound while watching a DVD on my laptop transmitted to the car speakers.......
Maybe , that is what i a asking, i don't know
Posted on Jul 31, 2008
How do I get better sound with my roku tv
The speakers on a lot of TVs are not very good quality and seem to rely on owners providing their own audio solution. You have a couple of options if the TV speakers are not up to expectations.
1. Sound Bar - available from Audio/video retailers/Amazon.com etc.
2. If you have a hifi system or Ipod dock in your house with a 3.5mm jack input, and you TV has a 3.5mm jack headphone socket then you could connect it up and this will use the speakers on your audio equipment which will improve the output.
Dec 01, 2014 | TCL 55" Roku Ready Tv 55fs4690
How do I get audio out of 32lc2d to go to the external surround sound system
Depends on your external sound system... If it supports HDMI, then just connect an HDMI lead between the TV and the external amp. If you don't have HDMI, look for two RCA/Phono connectors (small circular connectors) on the back of the TV (should be coloured red & white) and connect these to the external sound system. Finally, if you don't have either of these look for a 32 pin scart socket (rectangular with a bit sticking out) and get a scart to phone cable. Plug the scart plug into the TV and connect the Red & White output leads to your external system - hope that helps :-)
Aug 18, 2014 | LG 32LC2D Television
Sound bar does not work with tv
You are not the only one with this problem!
Try plugging some other speakers into the soundbar and seeing if that works.
If it does, then the problem could be in the TV - its internal speakers may need to be turned off first; and/or check you are connecting with the right socket eg: 'Output'. on the TV. Read the manual!
Mar 05, 2014 | Element Skateboards Element 46" Class...
Distorted sound
It is very possible that a speaker is bad. If you have the connections, try connecting external speakers to the TV to see if it still has the distortion. If so, then the audio output on the TV is bad.
Jan 12, 2014 | Televison & Video
My 40bv801b has no sound
Try sound on headphone socket, if TV has one.
If sound comes, the problem is in the speakers or connecting circuits.
Aug 06, 2012 | Toshiba 40BV801B LCD TV
When conect speaker, the original tv speaker sound are off
Hello
You are connecting external speaker from your TVs headphone socket I thinks. It is quite normal that the internal speker will cut off when external a headphone is connected to the headphone socket. OK.
Jan 28, 2011 | Televison & Video
I'm having a buzzing sound coming from the speakers on my olevia tv
Assuming you are not attempting to play it at ear shattering levels, this may be due to an alignment problem in the IF/audio demodulator, a bad audio IC or other circuitry, bad connection, or a defective speaker.If your TV has an earphone or audio line out jack, try this to see if it is clear. If so, then your problem is in the final audio amp or speaker(s).
If only one channel of a stereo TV is affected, it is almost certainly the audio amp or speaker for that channel. Interchange connection to the two speakers temporarily and see if the problem moves.
If the problem is at all intermittent - try gently whacking the TV - then it is likely a bad connection - either a cold solder joint or a dirty or tired IC socket.
The audio amplifiers in newer TVs are almost always ICs and replacements are usually readily available. If the IC is in a socket, remove the IC, clean the pins and socket contacts and reinstall it. Sometimes, the contacts on old socket lose their springiness and do not provide solid connections. Such a socket will need to be replaced.
If the set uses discrete transistors, it s also possible for one of these to become noisy.
If your TV is fairly old - 10 years or so - this may be an alignment problem requiring tweaking of a coil in the sound IF. See your service manual. It may be possible to have similar problems with newer TVs but this is relatively rare.
There could also be bad electrolytic capacitors, probably in the power supply area. Even though you might think this would result in hum and there is none (even when there is no audio in the program or the sound is turned down) dried up caps can result in distorted sound that may sound like a sort of clipping. An ESR meter is best for testing (with power off!) but carefully jumpering known good caps across suspect ones (again with power off, then turn on the set and check), will eventually find the bad one(s).
Hope this helps....
Jul 02, 2010 | Televison & Video
CANT CONNECT MY BOSE COMPANION 3 SPEAKER TO MY 42LG50 LCD TV
I have just brought the bose companion 3 speakers and i connected it to the headphone socket in my tv and it worked.
Hope this helps
Jan 06, 2009 | LG 42LG50 42 in. LCD HDTV
Connecting laptop audio to tv
i had the same issue with a thinkpad T61 which i was connecting using VGA and a audio jack going straqight from the headphone socket to the back of tv.
I had picture but no sound and i found that once connected the issue could be solved by rotating the projection setting on the laptop(Fn+F7). Basically switched back to laptop only display, then back to laptop and projector display again and teh sound just kicked in.
i think it's related to the projector setting on the laptop rather than an issue with the tv.
Oct 12, 2007 | Protron PLTV-32 Television
Televison & Video Logo
293 people viewed this question
Top Televison & Video Experts
Electro Med Services...
