Question about GE (PSS26MSRSS) Side by Side Refrigerator
My landlord just put a Magic Chef fridge model CTN1511GEW in my apartment. How old is it? How do I adjust the freezer temp?Where can I get an owners manual?
catriver
  • 878 Answers
SOURCE: GE side by side fridge with Water and Ice despenser
djones, The evap fan motor should not change speeds in less than 1 minute of time. The fan motor has two speeds. Usually this is a indication of a failing main board. If you have a meter you can do a voltage check at the J-2 connector on the board. Check for 13VDC between pins J2-3 and J2-8 and 8 to 13VDC between J2-3 and J2-4. If this voltage stays steady, your problem lies in the evap fan motor. If this voltage drops out or fluctuates, it's more than likley the board....Catriver...post back.
Posted on Dec 14, 2006
SOURCE: magic chef gas/electric rv fridge
Mod. R47 gas RV fridge 1973. It lights and gets cold (sometimes below freezing in the bottom of frige) then it starts to warm up above 55, but the flame is still burning high. I try to turn it down with the fridge thremostate and it stays the same. Is it the thermostate? If so where can I order one?
Jerry toolster@cableone.net
Posted on Jan 09, 2009
  • 686 Answers
SOURCE: fridge is warm even when i adjust temp. control.freezer is good.
if your fridge has 2 set of dials one numbers and the other letters than you need to adjust the dial that has letters on it. If the fan in your freezer is not blowing, then it won't force the cold air from the freezer to the fridge. Make sure fan blows then adjust the letter knob.
Posted on Feb 17, 2009
Sea Breeze
  • 4655 Answers
SOURCE: fridge and freezer running too warm
You will need to unplug the refrigerator and remove the back panel inside the freezer. Check for ice or a frozen over evaporator coil. If frozen defrost and we will need to examine the defrost heater at the bottom of the evaporator. It may have a glass tube covering the heater element inside. I want you to check to see if it is burned out. The part number for the defrost heater is WR51X10042
You please let me know what you find. If the element is burned out I recommend you replace it and the defrost thermostat part number WR50X10068
You and order the parts by clicking the link below and entering the part number into the part number search feature and click FIND IT. Let me know what you find, Sea Breeze
PART NUMBER AND MODEL SEARCH FEATURE
Here is a photo of the defrost heater.
WR51X10055 Defrost Heater
WR55X10656 Mother Control Board
It is possible that there problems with you mother control board. Need to unplug and examine both sides for burn marks.
If you need help feel free to let me know, Thanks Sea Breeze
appliancepartsse@yahoo.com
Posted on Jul 30, 2009
  • 50 Answers
SOURCE: IFridge and Freezer too cold, temperature wont adjust.
you need a new thermostat e z to put on it takes a phillips screw driver the t.stat is hooked right to the knob that you turn to adjust the temp
Posted on Feb 24, 2010
Bottom of fridge not cold
After adjusting the settings switch or dial (usually inside fridge) you wait a couple of hours then see if bottom is colder. Most fridges (older models anyway) have an adjustment procedure. This worked for our Magic Chef purchased about 1994
Mar 03, 2013 | Kenmore Refrigerators
My Magic Chef refrigerator is maintaining a constant temperature of 60 degrees F, no matter what setting I put it on. We just moved into this duplex last week; when we moved in, the refrigerator had been...
The coil is on the bottom underneath the unit. More than likely it just needs to be cleaned. The best way to do it is remove the front grill and vacuum it out the best you can.
Aug 18, 2011 | Magic Chef Refrigerators
Frig does not cool, freezer works fine
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Apr 26, 2010 | Magic Chef Refrigerators
Hello, i have a magic chef fridge and im trying
It is ok to tilt frige back for hinge access be sure to unplug it and brace it so it doesn't fall on you.
Nov 04, 2009 | Magic Chef CTF2126AR Top Freezer...
Freezer temp is wear fridge shoud be.fridge temp 55 degress.
Check the fan in back which cools the compressor . Also check the coils to make sure they are clean of dust , lint , etc...
Aug 02, 2009 | Magic Chef CTB1821AR Top Freezer...
Side by side Magic Chef refrigerator. Freezer
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Could also be begining of a defrost problem.
Jun 14, 2009 | Magic Chef CTB1821AR Top Freezer...
Magic chef fridge not working
Could also be beginning of defros problem.
Jun 04, 2009 | Magic Chef CTB1821AR Top Freezer...
Our model is MCBR 415S. The top freezer acts as
You most likely have a bad thermostat control or a bad defrost timer.
Locate the defrost timer, probably inside the temp control panel.Defrost cycles should last 30 minutes then resume freezing.
Manually turn the timer control a 1/4 turn and see if it starts.
If so, replace the defrost control.
It could also be a bad temp control.
If the timer adjustment does not start the fridge. Tap the temp control. It may have stuck contacts.
Mar 10, 2009 | Magic Chef Refrigerators
Magic chef manual
You can download it here but you need the right model #.
http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=MCF
As for the temp adjust it is best if you get an repair man out to do that.
Good Luck
Dec 18, 2008 | Magic Chef 9522 Electric Double Oven
How many cubic feet (what size) is my fridge?
Need the cubic feet on our 16 year old Amana BX22A2W.
Jun 23, 2008 | Magic Chef CTF2125 Top Freezer...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
