Question about HP Photosmart Premium C309A All-In-One Printer
I am trying to install an HP Photosmart C309g to be part of my network (wirelessly). I have Verizon FiOS and my wireless router (modem/router actually) is an Actiontec MI424WR. When I try to configure the printer for the network, it fails and the troubleshooting report says "MAC address filtering may be enabled on your wireless router" When I go into the settings for my router, I find that MAC filtering is disabled. Any thoughts?
  • 1 more comment
  • dhwachs Aug 05, 2010
    I understand what MAC filtering is but don't see the need in my situation to turn it on. But why would the printer think MAC filtering is on when it is not?
    Could this be some other setting on the router?
    According to the printer's Network test report, all the wireless tests (finding SSID, accessing the network with a successful password) passed. But the test to access without filtering failed.
    Yes this solution was very helpful For a change, it was nice to see that the "expert" listened to what I said and didn't just scan for a few key words and give a set answer.
  • HP Master
  • 6,487 Answers
Base from the description of your problem this can be a problem with the printer settings or with the router settings, first thing that you can do here is to reset the network settings of your printer from its MENU then try to connect again to the router , by the way make sure that you have the correct security type and security key for the wireless security if you have that on from your router.
Posted on Aug 05, 2010
  • 1 more comment
    I tried re-connecting to the router again with the same results. The "Wireless Network Test Report" that the printer provided told me that the printer found the SSID, the security settings "passed", the printer settings were consistent with the wireless router settings, but failed on filtering with the message that "MAC address filtering may be enabled". But I have the router's administration page open and I see that it says "MAC Authentication Disabled"
  • Mark Gil
    Mark Gil Aug 05, 2010
    OK thank you for the update, next thing to to do is to power cycle the printer and the router, power off the router and the printer for 1 minute then check again if they are now connected fine if still giving same error enable and disable the mac filter on your router .
    Son of a gun! That worked. You'd think after all my years in IT I'd remember the first rule of problem solving... when in doubt, reboot.
    Thank you so much!
  • HP Master
  • 1,183 Answers
Troubleshooting wireless printing on home networks sometimes is bit tricky and require a lot of patience . The first step would be to run the HP network diagnostics, that may help resolve the issue. Also wanted to ask was the printer working earlier on the wireless setup or are you configuring it for the first time.
Link to Run HP diagnostics
Though you may have configured wirless printers earlier, there could be setup you might have missed while installing the HP printer on the computer. To re-run on how to configure , just verify the steps from the link below
Setup-wireless Printer
Thanks for using Fixya
Proton
  • 942 Answers
Most Wi-Fi access points and routers ship with a feature called hardware or MAC address filtering. This feature is normally turned "off" by the manufacturer, because it requires a bit of effort to set up properly. However, to improve the security of your Wi-Fi LAN (WLAN), strongly consider enabling and using MAC address filtering. Without MAC address filtering, any wireless client can join (authenticate with) a Wi-Fi network if they know the network name (also called the SSID) and perhaps a few other security parameters like encryption keys. When MAC address filtering is enabled, however, the access point or router performs an additional check on a different parameter. Obviously the more checks that are made, the greater the likelihood of preventing network break-ins.
To set up MAC address filtering, you as a WLAN administrator must configure a list of clients that will be allowed to join the network. First, obtain the MAC addresses of each client from its operating system or configuration utility. Then, they enter those addresses into a configuratin screen of the wireless access point or router. Finally, switch on the filtering option.
Once enabled, whenever the wireless access point or router receives a request to join with the WLAN, it compares the MAC address of that client against the administrator's list. Clients on the list authenticate as normal; clients not on the list are denied any access to the WLAN.
MAC addresses on wireless clients can't be changed as they are burned into the hardware. However, some wireless clients allow their MAC address to be "impersonated" or "spoofed" in software. It's certainly possible for a determined hacker to break into your WLAN by configuring their client to spoof one of your MAC addresses. Although MAC address filtering isn't bulletproof, still it remains a helpful additional layer of defense that improves overall Wi-Fi network security.
Do not confuse MAC address filtering with content filtering. Content filtering on a wireless access point or router allows administrators to maintain a list of Web site URLs or addresses that should not be accessed from the home WLAN.
    I am familiar with what MAC filtering is, and honestly I don't mind that it is off. The problem I am having is that the printer is reporting that MAC filtering is on when it is not.
Wireless network very slow. We are fine when hard wired into the router but when not it's painfully slow. We have a Verizon fios wireless router westell 9100
Make sure you are connected to your network on wireless and neighbor's
open a browser and go on to www.speedtest.net
click to check your internet speed Fios is pretty fast!
Your wireless if connected to your own network the speed is comparable weather wired or wireless!
Try these steps and let us know the results to further help you!
good luck
Sep 11, 2011 | Computers & Internet
Can't get on line with my Linksys wireless router
you can daisy chain ..but you will need an eithernet run from the fios router to the linksys...
Jun 25, 2010 | Linksys Wireless-G WRT54G Router
Is there any advantage using my DLink DIR625 with my Verizon 9100EM modem/router set up using WPA2? I have one ethernet tethered desktop and one laptop, plus using an wireless Skype Ipevo phone on the...
I can see no problem with that. But the WPA2 could be the issue. Some wireless device doesn't support WPA2 level. You can give it a try. For sure the laptop will connect. Not sure with the printer and the skype device. If they can't connect, use WPA only.
Jun 27, 2009 | Computers & Internet
ZyXEL NMP-1100W wireless network goes down
WEP or WPA encryption code Wifi checked?
Modem or router going in to reset possibly.
Possibly 2nd device present with same key.
Apr 18, 2009 | Zyxel NMP1100W WIRELESS MUSIC BOX
Nonexistant customer service by Actiontec
After my second call to Actiontec ended with the help desh hanging up on me, Actiontec did respond to an emailed plea for help and prompty provided a complex script which they labeled confidential to address this problem. The bottom line seems to be Verizon either installed hardware that is incompatable with an Exchange server or they did not configure the insallation correctly. In so many words, Actiontec feels it is a Verizon problem. I wish me luck in getting to the right place to deal with that, even though I am a Verizon stockholder.
Mar 27, 2009 | Actiontec GT704WG Wireless Router...
Cannot Network printers on FIOS system
If both computers are connected to the router. Try turning off the firewall on both computers first. normally its firewalls blocking file and printer sharing that block the connection.
Mar 07, 2009 | Westell Wirespeed VersaLink...
Wireless Router Advice
what kind do you have right now? verizon fios offers some great wireless routers that are very strong
Dec 06, 2008 | Computers & Internet
I have Verizon Fios install in my home. I use to have Comcast. This is the situation, before the Fios my linksys wireless router was connected directly to a modem. Now my linksys wireless router is...
Your IP address for you linksys router needs to be changed.  More than likely there using the same IP address such as 192.168.0.1.
You have to convert your linksys router to a switch and change the IP address range it uses to on that doesn't conflict with the Verizon router.
10.150.1.1 should work.
Oct 08, 2008 | Computers & Internet
Cannot connect to the internet with my laptop
To connect to the router wirelessly using a Windows XP, right click on the wireless network connection icon on the lower right corner of the screen and choose view available wireless networks. Select your existing network and click on the connect button. If you are using Vista, go to network and sharing center of your control panel then select connect to a network. If you still having problems, please provide details of the problem like your Internet service provider and if there are already other computers online with your WRT54G2.
Jul 11, 2008 | Linksys Ultra RangePlus Wireless Routr...
The battle: Acer Vs. Verizon FiOS
Verizon needs to apply a firmware update for the Atheros wireless adapter in your notebook. I work for Acer and I end up having to tell people this all day long. If you take this to a wireless router that is not from verizon you will have no problems with your connection. Maybe if enough Fios customers complain they will provide a firmware update for this.
Mar 06, 2008 | Computers & Internet
HP Photosmart Premium C309A  All-In-One Printer Logo
930 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
