FixYa.com
Tags:
Maytag Neptune MAH5500B Front Load Washer
Rotate the doors
posted by mikegolf on Apr 26, 2008
Since my house is set up so that my dryer must be on teh left side. I want ot make the doors on both the washer and dryer swing outboard. Both currently swing inboard making transfer of clothes from the washer to dryer cumbersome.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 14, 2008
Not Rated (0)
IFIXALL
Rank:Wiz Wiz
Rating: 84%, 287 votes
You can reverse the doors and it is not very hard to do.If you need assistance I'll be happy to provide the help to do this.
Comment by IFIXALL, posted on May 14, 2008
start with the Dryer .Remove the 2 screws that are holding the hinge to the dryer.Now lift up the door to slide the hinges off the frame.You should lift up and pull toward you to pull it off.Now the easy part.One part at a time start by taking the two screws off the hinge of the door and install the hinge on the oppisite side and continue with any part you can switch over.That is the door latch,& both hinges.Thats it!!
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Washing Machines problems?
bearing
Sounds like a bearing going... Answer This...
not spinning, not drying
washer is not drying Washer... Answer This...
MAH8700AWW
We were washing a load and the... Answer This...
can someone help me please,,,,,...
the ccu board went bad, I put... Answer This...
Maytab Neptune FL washer
the lights on the panel won't... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
