Question about Hifonics BXI 1606D Car Audio Amplifier
The amp from time to time gives a tone to the speakers even when the rca audio cords are not hooked to the amp the protect light isnt on and all the wires work properly i hooked different amp to the speakers and ruled out that its not the speakers then i noticed at spacific times when the amp wasnt producing a tone threw the speakers their was a faint crackling noise near the rca audio hook ups.
  • 407 Answers
You are on the right track. It's not the amp, but it is the rca wires. When you have them plugged into the stereo, you can touch them together and it will make the same sounds you described also, though I don't recommend doing that! Rca wires can be weird sometimes but usually I replace them with new ones. Even a brand new set of cheap ones will do the same thing sometimes. The noise you here is causes by either a small short in the wiring, running the rca's to close to the power wire for the amp (or any other power wire for that matter), and sometimes you can buy a grounding kit for them that is fairly cheap that will help. Most of the time for me, it was just the connections, but replacing them basically took me through all these steps at once. Just remember, you still have a chance that your head unit is the cause by the connections getting old and wore out on the inside. Hope this helps!
Posted on Aug 05, 2010
  • n_injallo Aug 07, 2010
    well thats the thing i unhook the rca audio wires directly from the amp and the woofers still mkae the tone ive got it down to a pouint when the done isnt being sounded inside the amp theirs 2 large coil looking things one of them has a crackling noise coming from it
  • Michael Carroll
    Michael Carroll Apr 21, 2011
    I have this EXACT same problem, same amp, same everything. The second coil inside the amp is making that crackling noise like you said, please tell me you figured out a fix?!
GREEN LIGHT IS ON BUT NO SOUND
Do two tests:
1) hook up another speaker that you know is good. Does it work?
2) Unhook the RCA cords from the input and plug in another device (like an iPod using a headphone-to-RCA cord). Does that give you sound?
Let me know.
Jul 03, 2011 | Kole audio PH15500D Car Amp
Hooked the damn thing up power my subs wonderfully for that evening, and all day today, got in this evening and nothing, checked the amp and red light, ok, fine, checked the manual, says the light protects...
probably something corssed in your speaker wiring. be sure that you did not exceed the ohmage capabilities of the amp, and that no speaker wires are crossed, or shorting out on the frame. if you have too many speakers hooked up, that can reduce the ohmage, and your not supposed to go below 2 ohms -per channel, or 4 ohms bridged mono.
Mar 13, 2011 | Pyle PLA2200 Car Audio Amplifier
I have a 1400 watt cruch amp & i hooked it up myself. when i turn the radio on the power wire on the amp comes on, bt if the audio cords are hooked up, the protection light comes on. if i dnt hook the...
Should the amplifier go into protect mode, simply disconnect all RCA and speaker leads, while keeping +12 volt, power ground and remote leads connected.
1. Now turn the amplifier back on, and if the diagnostic LED lights, the amplifier has an internal fault.
2. If not, plug the RCA cables back, and reset the amplifier. If it goes into diagnostic now, the fault lies in the input, either with bad cables or source unit.
3. If the amplifier seems fine with RCA cables plugged in, connect the speakers, one at a time, and if one of the speakers or its wiring is faulty, it will activate the diagnostic
system.
Dec 08, 2010 | Mobile Authority A-500 Car Audio Amplifier
Why is the red light that says protect on? my amp turns on but it dosent work, i have a sup hooked up & it dosent work. the red light that says protect is on.
first thing check all ground and power wires and make sure ur rca wire make sure it isnt cut in anyway. after that unplug ur sub and unplug the negative wire from ur amp, while its out check the fuses on the amp if all is well put all fuses back if not get new. then plug the negative wire back in if protect goes off check for heat and if no heat inspect the wires from speaker out put all the way to the sub, look for any wire touching another this is were most problems are even the smallest wire can trip a protect. if u still cant find the problem. an amplifier specialist is in order.if its trashed go on ebay and buy a powerbass there goin cheap right now. hope i could help
Oct 12, 2010 | Lanzar VIBE266 Car Audio Amplifier
Protection light keeps flashing on and off
try hooking up only the power ground and remote see what happens if protection light is on then u have a problem with amp if it goes off then hook up rca if still off then hook up speaker wire if it turns on then u have a prob with speakers
Feb 02, 2010 | Kicker ZX10001 Car Audio Amplifier
I got a protection light on in my amp and low pass filter cuts out rear speakers even when hooked up front inputs to rear speakers im using the high level inputs as i only have one rca set
Try unplugging all the speakers and then powering the amp up, plug in one at a time to determine when the amp cuts out to protection. Chances are you may have touching wires or a speaker that is about to blow or at worst a amp going/gone bad
Oct 26, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Xm-2002gtr amp keeps kicking protect light on
check your amp and speakers and make sure their both hooked up 4 ohm instead of 2 ohm because if you have 1 set of voice coils on your speakers they can only be hooked up four ohm and not bridged to your amp because if you keep trying this you will lock up your speakers if the speakers are only 4 ohm than just hook them up regular to each channel on your amp if your trying to brigde four ohm speakers to your amp it will keep going into protect or worst case scenario you will fry your speakers and you can check your ohm with a ohmmeter trust me my brother owns a stereo shop
Oct 19, 2009 | Sony Car Audio & Video
Red protection light
If the amp is going into protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp almost certainly has shorted output transistors and will need to be repaired.
Sep 12, 2008 | Nitro BMW-482 Car Audio Amplifier
RCA CABLES
RCA cables are the best way to get the audio from your head unit to the amp. If your head unit doesn't have RCA outputs, you might be able to use the speaker outputs of the head unit to connect to the "high power" or "high level" inputs of the amp, if the amp has such inputs (check your manual).
Mar 23, 2008 | Lightning Audio LA1.300.2 Car Audio...
Protection Light Is Coming On
You say the protection mode only occurs when you plug the RCA's in. Does it have to be both RCAs or just one?
The other end of the RCA cable is plugged into the HU?
It possible the RCAs have too much DC voltage on them, causing the amp to go into protection.
Is there a short in the RCA cable?
I would definitely check out the RCA connection at the back of the HU, as it sounds like there could be other issues there. Make sure the RCA connectors aren't touching any other metal (especially +12V).
Mar 14, 2008 | Car Audio & Video
Car Audio & Video Logo
82 people viewed this question
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Marvin
Marvin
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
