Question about Onkyo TX-SV414Pro Receiver
My Onkyo TX-SV424 keeps blowing the fuse when turned on
  • 16 Answers
SOURCE: Onkyo TX-SR 606 KEEPS CLICKING INSTEAD OF TURNING ON WHEN POWERED
Here are your options:
1. An electrical problem, where your receiver has a grounding problem.
2. Your speaker wire connections are actually touching each other and that's why your receiver is not turning on.
Posted on Nov 15, 2008
  • 4234 Answers
SOURCE: i have a onkyo tx-sr506 receiver that turns it self off
This unit is in protect mode. This means that a problem was detected and the unit has shutdown to prevent further damage. The most common cause of this is failed output transistors. Plan on $20-$40 for parts for this repair.
Dan
Posted on Nov 04, 2009
SOURCE: won't turn on.standby light on,fuse under cover is
Mine will turn on for a few seconds then whill shut off again but the standby light would stay on
Posted on Feb 16, 2010
  • 1527 Answers
SOURCE: Onkyo TX-DS696. No right channel speaker sound
hello there 2 transistor 1 for the right channel and 1 for the left first thing 2 do is a visual check in good light check for any burn't part or any bulging capacitors if everythink looks ok then check underneath the board for dry joints if then you will need a mulitmeter to start testing components
regards
shasun
Posted on May 15, 2010
Testimonial: "Thanks - i'm gonna hv to take in in for the experts as i couldnt see anything visually."
smarthome2
  • 1114 Answers
SOURCE: Onkyo TX-SR607 keeps turning off
The most common problem found on FixYa for Audio Video Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Jun 03, 2010
Onkyo tx-sv424 keeps blowing power up fuse,i blew it hooking up about 8 speakers insteaqd of the 2 i got with it
Unless you hook up the speakers so that you present the correct load to the output amps, you will continue to blow fuses and eventually damage your output stages. And if you hook up all those speakers in parallel you are indeed in deep duty. Get yourself a book regarding speaker wiring, etc.
Mar 31, 2017 | Onkyo Audio Players & Recorders
How to hookup a onkyo TX-SV424 amplifier to a RCS HD50LPW175
HOW TO CONNECT ONKYO RECEIVER PT1 - YouTube
? 7:00
https://www.youtube.com/watch?v=5qF2P34k7RU
Apr 22, 2012 - Uploaded by Tampatec
HOW TO CONNECT TV TO ONKYO RECEIVER REVIEW, MUST USE AUDIO CALIBRATION TOOL AFTER .
Dec 10, 2015 | RCA HD50LPW175 50" HDTV
Tx-8511 blows fuse when turned on. I used Radio shak 5-amp 125 volt replacement fuse. Turn on and it blows
If the unit keeps blowing the fuse means you have a shored parts on it.
See my tips by clicking http://www.fixya.com/support/r8053361-fuse_keeps_blowing. This is also applicable to your unit. The only thing added to check is the stepdown Transformer for short, also the output IC.
Hope it may help you.
Thanks for using fixya.
JDVillanueva
Feb 02, 2011 | Onkyo TX-SV414Pro Receiver
Proper wiring connection on bose 901 speaker with onkyo tx-sv424 purchase 5 years ago
trying to hook up sereas 2 901 to onkyo sx 424 i have access to carver c 1 if that will help
Nov 29, 2009 | Bose 901 VI Main / Stereo Speaker
Does The Onkyo TX-8210 take a slow blow or fast blow fuse?
slow blow (aka time delay) fuses are used in motor circuits. Electronic devices use normal or fast blow fuses
Oct 02, 2009 | Onkyo TX-8210 Receiver
Onkyo tx-sr606b no power - blown fuse?
it either a bad fuse or your transformer that is blown
Jan 06, 2009 | Onkyo TX-SR606 Receiver
Nov 09, 2008 | Onkyo TX-SR605 Receiver
Onkyo amp keeps turning off
Check your fuses sounds like one may of blownout
Nov 04, 2008 | Onkyo TX-SR875 Receiver
Will not power up but stand by light is powerd up
I have onkyo tx-ds575 and i need to conect it to my tv and have audio from a LCD flat panel.
Oct 05, 2008 | Onkyo TX-DS575 Receiver
314 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
