Question about Conair Health & Beauty
WHAT DO YOU CLEAN THE CLIPPERS WITH AFTER USE - I USED THEM ON MY SHEPHERD AND THEY WORKED WELL, BUT I DO NEED TO CLEAN THEM. THANK YOU
  • 76 Answers
"Kool Lube" by Oster works to clean and disinfect the clippers. Hair should be removed first, this can be done by cleaning out hair with a toothbrush. Kool Lube is available at beauty supply stores such as Sally Beauty.
Posted on Aug 05, 2010
My husbands clippers won't cut
Blades are NOT moving HOW TO Fix a broken Hair clipper ...
? 2:42
https://www.youtube.com/watch?v=DX4Xc47F_IE
Mar 29, 2015 - Uploaded by You can Fix It!!!!
... blade fix how to won't cut by adjusting the blade adjusting the play with the motor so ... Blades trimmer trim trimming cut cutting cutter trimmers barber ... dog clippers shear shears shearing shave shaver shaving buzz cut ...
My clippers hum like their working but dont cut - Fixya
www.fixya.com/.../t3222969-clippers_hum_like_working_but_dont_cut
Jul 25, 2008 - my clippers hum like their working but dont cut - Wahl Designer 6 (8355100) question. ... hair clippers repair. Apr 22, 2013 ' Shavers · 1 Answer ...Clippers jam and won't cut when trying to use attachments. Jan 11, 2009 ...
Clipper Maintenance - Rapid Edge
www.rapidedge.com.au/cat/maintclip.html
Clipper won't cut cleanly or easily. Lack of oil and dirty. Sometimes a hair gets caught between the blades. Lubricate and clean your Clippers regularly.
Dec 21, 2015 | Health & Beauty
What is a shepherds axe?
A shepherd's axe used by shepherds in the Carpathian Mountains; it could double as a walking stick.
Feb 03, 2013 | Garden
I was shaving my dog using oster ultra cordless clipper, and suddenly the clipper is not cutting hair instead it grabs hair. I opened it and clean out hair under blade, but unfortunately, i did not help.
With most clippers, after an amount of use they need to be cleaned then oiled. Most sets come with some amount of oil for your clippers. Otherwise you can purchase it separately. This should fix the problem.
Aug 25, 2011 | Oster Health & Beauty
Sounds as if the trimmer is on but not with full power, is not able to cut hair?
Your clippers probably just need to be cleaned and oiled.
Unplug the clippers, then use a philips screwdriver to take off the clipper plate and reciprocating blade, and then thoroughly clean out all the hair residue from inside. Q-Tips seem to work fine for this job.
Here is one short Youtube video that demonsrates the basic process:
http://www.youtube.com/watch?v=43CpUK2AghA
I just use light mineral oil from the drug store to lubricate mine and it seems to work fine. Normally you are only supposed to use a few drops of oil when you put it back together, but you can really use as much as you like on the blade / plate area, just try not to get any down inside the body of the unit. Then just be sure let it run for 10 seconds or so and then wipe off the excess oil with a paper towel prior to using it next time.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
Jun 01, 2011 | Vacuums
I have an Oster Golden A-5 one speed that I bought 20 yrs ago. I have lost the manual and need to know if I can oil this unit and if so how? Thanks, Lorrietis
Here how you can oil your A-5 clipper, The button on the side of the clipper is the oiler, depress the button down with a small screw driver and while holding the button down, use Oster clipper oil it will take about 4 to 5 drops of oil. after you are finish wipe clean with paper towel and turn on your clipper, let it run for about 2 minutes. Turn your clipper off and you are done. We hope this will help you Thank You. Manny's Sharpening www.mannyssharpening.com
Apr 20, 2011 | Oster Golden A5 1-Speed Universal Motor...
I used the clippers to cut my dog... once finished I took it apart to clean out excess lubed parts and reassembled...I have done this many times before with no problems... I begin cutting and the blades...
Check your blade latch is working properly. If you took your clipper apart and your blades are not cutting it is one of 2 things. Your blade drive is not assembled properly or your blade latch is not holding the blade on the clipper. If you took your blade apart, check the blade alignment. The cutter blade needs to be slightly behind the comb blade.
Mar 11, 2011 | Andis AGC2 Hair Trimmer
Remington HC-921 Mens Clipper Kit Pulling hair not cutting
no but I can't wait until someone does- having same problem. They worked fine then didn't
Mar 29, 2009 | Remington Health & Beauty
Cleaning Oster 78004-011 Clippers and blades
OK compressed air is perfect for your clipper, thats all it needs! Take the filters off (at the bottome of the clipper, either side of the cable) periodically and clear from excess fur. Replace. As far as the blades are concerened, Brush the excess furr off with a toothbrush or similar. Slide the cutter (smaller of the 2 blades) to one side (past half way but not all the way off!) clean exposed teeth on both blades with a bit of oil and a toothbrush, push the cutter the other way and repeat. Blade wash's tend to rust the blades, you need a big pot of WD-40. Get a 5 litre tub from the internet, only thing is there, postage will be a killer. I work for a clipper repair, blade sharpening company and we have it delivered by the truckload! Do what you do with the blade wash, but do it in WD-40. Wipe off excess afterwards and dont soak the clipper in any liquid because of electrc shock.
Thats all you can do! When your blades go blunt or clipper needs service repair: www.sheareaseltd.com If I have helped you please tell your friends about our website! Thank you!
Feb 25, 2009 | Oster Golden A5 2-Speed Universal Motor...
OIL THE CLIPPERS AND CLEAN THE HAIR OUT REALLY GOOD.
Jan 11, 2009 | Oster 76076-010 Hair Trimmer
My andis clippers are experiencing blade not moving. it is not cutting.
Push top blade to right side right with finger,then turn clipper on and dip  into 3 in one oil,blades only,let clipper run for one minute,clean excess oil off blades,if clipper still want vibrate,take blades off the clipper and clean them,then place back on clipper, I've had this problem many times,i also repair clippers,adjust blades,etc...
Oct 09, 2008 | Andis 01690 Hair Trimmer
Health & Beauty Logo
353 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
