Question about Goodman CKL36AR36 Air Conditioner
Where is the filter on my Goodman model capf3636c6ba ?
  • 407 Answers
The main places that filters are located are:
Return Air Vent or Vents
Inside Coil Box
Underneath Furnace (Will have a small access door)
Filter Box Attached to Return Air System
A lot of people still look for their filters inside the coil box, but more recently installed units will have them in the return grills inside the house. Follow your return air from the vent inside the house back to the unit and it will be somewhere in between there. Hope this helps!
Posted on Aug 05, 2010
  • Nashiq Jun 26, 2011
    I just changed my filter on this one. Open the front of the unit (should be 4 screws) in the bottom section on the left you'll see your old filter in front of the return. It's held in by a metal clip. Mine was 16x25x1.
    Cheers.
Changing the air filter on a goodman model # gpg13300701bb outdoor gas AC unit
There should be a panel to remove without needing to remove any screws. Or a panel that states AIR FILTERS. If not, you'll need to remove panel by panel, near the part of the unit where the ductwork connects. If no ductwork connects to the side discharge panels, start farthest away from the o.d. fan motor section. Turn off line voltage power first! Electricity and moving parts are inside and may cause bodily harm or injury. I normally install "Gas Packs" with a filter grille or filter base in duct for easy filter maintenance.
Sep 03, 2017 | Goodman Heating & Cooling
Trying to find out how to change the filter for Goodman AC model # ARUF36C14BB
The filter compartment is at the front bottom of your indoor section of the air conditioner.
There should be an access plate located there and may have a 5/16" screw on each side you need to remove to get the access cover off.
An air filter should be visible, and you should slide the filter out toward you for removal.
Mar 27, 2014 | Goodman Heating & Cooling
Capf3636c6ba
That is a 36000 btu inside unit.
That is a 24000 btu heat pump.
The heat pump is undersized and that will never work out.
Sep 04, 2013 | Goodman CKL36AR36 Air Conditioner
Hi I have commercial hvac goodman unit and trying to change my filter, but i have no idea where the filter is located. the model number is GPG13480903AB
On this package unit, there are no places for filters inside the unit itself unless a technician rigged something up to accept one, but not a common thing at all. These units will use filter return grills inside the building. They are usually 2x2 grills on a dropped ceiling grid or could have a filter grill located right off the return plenum from the unit. Either way, it should be inside somewhere and easy to access. Hope this steers you in the right direction and good luck!
Aug 24, 2010 | Goodman Heating & Cooling
Goodman furnace model#GCH90904CXAB the red light
This model is equiped with a diagnostic error control. Take off the front panels and look for a wiring diagram pasted on the reverse side of the panels. On this diagram there will be a chart telling you what 4 blinks represent and where to start looking for the issue. I suspect the air filter may be dirty or the pressure switch may be bad, however make sure the condensate hoses are free of any debris. Good luck to you!
Apr 25, 2010 | Goodman Heating & Cooling
Need to Know Where to Change the Furnace Filter
On the bottom of the indoor unit should be a cover or tray. Sometimes a large grill inside the house, close to the unit is where they are placed. Good luck
Apr 23, 2009 | Goodman Heating & Cooling
Goodman heater
Depending upon your installation the filter could be located in the bottom section of the furnace right or left of the blower, remotely located in its own housing in the return air plenum or it may be missing altogether. If you can find a spot to put one in, do it. You may just have to reset your thermostat. Some models have a pre-timed indicator that comes on after a number of hours reminding you to check your air filter. Post the model number of the thermostat and maybe we can help you reset the timer.
Nov 10, 2007 | Goodman GMS90703BXA Heater
GOODMAN ARUF3642
These guys list the actual sizes of a good selection of goodman filters - just measure the old one or the space where it should be and match it to the right filter(should be a fairly tight fit). http://www.filters-now.com/products/dgb.html#skipmenu and this site describes what the different filter types available are http://www.oxyclean.com/goodman.html Hope this helps :)
Mar 07, 2007 | Goodman CLQ36AR49 Air Conditioner
Goodman CKL36AR36 Air Conditioner Logo
306 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
