Question about Frigidaire Dishwashers
Hi there My dishwasher drain is blocked - won't drain Thanks
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasherHi there
My dishwasher drain - 2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Aug 05, 2010
LG dishwasher model # LDS5811ST won't turn on
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then try to reset the dishwasher control by pressing the HEATED DRY button and hold it for 15 seconds, if its still not resolved then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 31, 2011 | LG Dishwashers
Hi we have a Kenmore Dishwasher Model # 13744K and it won't turn on. It has water in the bottom that won't drain. Please advise. Thanks. John Webster.
For a dishwasher that was rated pretty high by Consumer Reports, it does not clean very well. In addition, the plastic control button cracked in less than a year and I must constantly clean around the inside of the door ... and I never received my rebate.
Despite those issues, it has been a workhorse. My wife is a daycare provider and the machine is used twice a day (on average) and still runs well. On a monthly basis, I alternate a pint of lemon juice and a pint of vinegar to keep it clean and once per year I use a granulated dishwasher cleaner.
Aug 14, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
Dishwasher won't start
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jun 18, 2011 | Maytag 24 in. MDB9750AW Dishwasher
What would cause my dishwasher not to drain?
not sure if you have posted the model number of your dishwasher.
There are several reasons for dishwasher not to drain.
1. faulty drain pump
2. clogged kitchen sink drain
3. drain cycle is not reached due to faulty dishwasher controller
4. clogged drain hose
5. the wash cycle is not completed due to heater not heating water - (try rinse cycle to confirm)
Happy to help if you can provide some details on when the drain cycle is not working. do you get any alarms on dishwasher..etc.
Feb 25, 2011 | GE Nautilus 24" Built-in Dishwasher
We had a short in the wiring where the dishwasher plugs into the wall. After fixing the wiring, the dishwasher now has a message "OE" when I turn it on.
Hi
Thanks for using FixYa. Error OE in your LG dishwasher is a drain error, which is displayed when the unit won’t drain out in spite of 5 minutes drain operation. To resolve this issue you’ll need to check the drain hose for any blockages, also check the wiring connection to the pump. If still the issue is not resolved then you’ll have to replace the drain pump/motor. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 14, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishwasher not draining
Thanks for writing to Fixya.com.
To fix a dishwasher that will not drain, remove any clogs that are blocking the drain line by pouring a paste of baking soda, vinegar and water down the drain, and then pouring boiling water to clear the clog. Repeat the process several times to remove a severely clogged dishwasher drain. Thanks for contacting Fixya and please accept the solution if it has helped you.
May 15, 2010 | GE 24 in. Profile PDW7800 Built-in...
My bosch dishwasher won t empty the water and stuck in middle of programme
Hi, The first thing I would do is undo the drain hose from the spiggot under your sink and try and see if there is food scraps or some other kind of blockage in there. If this isn't the problem, the drain pump itself could be blocked?
Jun 16, 2009 | Bosch Dishwashers
LG LD-14AW2 (03 error)
agreed O3 is not a LG error code. OE is more likely and if so it could be the main pcb faulty, a blocked drain pump or a blocked spigot under the sink where the drain hose connects onto.
take care.
May 11, 2008 | LG 24 in. LDF 7811 Built-in Dishwasher
Dishwashers Logo
61 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
