Question about Radio Shack Pro-82 Scanner
I have a pro-82 that had reg batt and was switch to rechargable. And the batt leaked out in the scanner. Now it dont work. is it something easily fixed?
    Genius:
  • 1,274 Answers
Hi, my name is John. You take out the old batteries, get some contact cleaner, fine grit sand paper, carefully clean, sand and spray the the battery contacts, replace with fresh new batteries. Turn on and Enjoy...Hope you find this solution a four (4) thumbs-up thanks..John
Posted on Sep 04, 2010
My Radio Shack Pro-82 Scanner is not working at all.i turned it on and it wont even scan. i cant even hear the squelch. and the only time it picks up something is when its on the air setting it picks up...
Ok I have had the same problem with the Pro 82 and the biggest problems I've found for it not to scan is Corrosion of the terminals not only outside but inside. Even on the keypad and pcb board. SOLUTION: Just take it all apart with a small philips pecision screwdriver and with a dry toothbrush scrape all the corrosion off the board. This always solves my problem and it should yours. Even if theres no corrosion visible on the terminals be assured there is still some inside keping this from functioning correctly. Shotgun420
Jul 30, 2011 | Radio Shack Pro-82 Scanner
Pro 82 has 1ch000.000.L/O CANT DO ANYTHANG HELP
that is because your pro 82 is not programmed....
Jun 29, 2011 | Radio Shack Pro-82 Scanner
I have as pro-82 scanner reciever but no instructions. Iwant to use the scanner to monitor air traffic
Your PRO-82 has a key marked "AIR". Press it while the scanner is powered ON and it will search the AIR band for you, stopping each time it detects an active frequency. For more details on programming and monitoring with your scanner, you can download and print the factory manual, at no cost, here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
Bill B.
Listening in since the 60's
Apr 20, 2011 | Radio Shack Pro-82 Scanner
My Radio Shack Pro-82 Scanner batt. went dead , now I have no sound
That means you have to put new batteries in your scanner... or recharge your rechargable batteries but if you use rechargable batteries use your yellow battery cradle for rechargeable batteries and your black cradle for alakline batteries....foe pro 82...
Feb 28, 2011 | Radio Shack Pro-82 Scanner
I NEED TO PURCHASE CIRCUIT BOARD #GE-O1D-5730 FOR RADIOSHACK PR0-82 SCANNER. CAN'T GET ANY HELP FROM ANYONE. SERIAL #C220076 ON SCANNER CAT# 28-315. BATTERIES LEAKED AND RUINED THE BOARD. PLEASE ADVISE...
Your scanner is at least 8 years old, so the board is out of production. If Radio Shack can't order it you're just not going to find it. If you're really interested in keeping a scanner of this age, you might want to check eBay. They currently have two PRO-82's listed . . .
Bill B.
Oct 15, 2010 | Radio Shack Pro-82 Scanner
Froze on WX scan
Reset it with a papclip inserted into the little hole on the left side of the scanner facing you.
May 28, 2009 | Radio Shack Pro-82 Scanner
HOPKINSVILLE KY. POLICE DEPT. CHANGED TO A
Unfortuantly the pro-82 is not a trunked scanner, it's only a vhf/uhf scanner and cannot pickup trunked systems. You need to replace it with atleast a pro-95 to pick up trunked systems. If you need your manual for the pro-82 follow this link.
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/2000315_PM_EN.pdf
Feb 19, 2009 | Radio Shack Pro-82 Scanner
How to program a pro 82 scanner
try using frequencies you knw the police inyour area are using. you can get them from cityfreq.com
Aug 08, 2008 | Radio Shack Pro-82 Scanner
Loss user manual for Pro-82 Scanner Reciver.
Hi - You can download the manual from the link below:
Radio Shack Pro-82
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 09, 2008 | Radio Shack Pro-82 Scanner
Scanner
If it's still under the year warranty I would reckomend taking it to your local radioshack Retail store to send in for repair. Otherwise it sounds like the the speaker or the audio amplifier might be going out.
Mar 03, 2008 | Radio Shack Pro-82 Scanner
Radio Shack Pro-82 Scanner Logo
Top Radio Shack Radio Communications Experts
john milligan
Steve
xxxxxx xxx
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
