Question about Eureka Capture Upright Vacuum Vacuum
I have a eureka surface max 300, i saw smoke come out of my vacuum i seen that the belt was broke every time i change belt i run it on it snaps every time ive put 3 new ones and each one break right when i start it it looks like the metal piece is burning it is there a piece missing?? what am i doing wrong?? ugh i just purchased it couple of months agoo not even older then 6 months .. what do i do?
  • 10 Answers
SOURCE: smoking belt
Belt is slipping because the bearings on the beater brushes, which it turns, are jammed or full of dust.
Alternatively the belt has stretched after being overheated and needs replacing because it now slips.
Posted on Dec 31, 2007
  • 30 Answers
SOURCE: Burning smell and smoke
I ran into a scenario similar to this at work. With the burning smell and smoke combined, it leaves only one problem remaining; the motor. The motor and the pulley that enables the belt to spin could be malfunctioning (causing friction between the 2 parts) and thus causes the burning smell and the smoke. I'd highly advise not to touch either part after having the unit on (YOU WILL BURN YOURSELF).
The only other likely possibility is to make sure there aren't any hairs caught in or around the motor and the bearings of the agitator.
Posted on Mar 08, 2008
bastoe
  • 34 Answers
SOURCE: How do I to change the belt on an eureka altima 12?
the belt is on the bottom right (looking at it from the front). the Eureka website does have the manual for download, http://www.eureka.com/service/manuals/80244.pdf
With the vacuum flattened (straightened) out, turn it over and remove the back roller cover, (2 screws) once off, the roller should just pop out on the opposite side (opposite from the belt). Don't forget to turn the roller to center the belt once you have it on.
Posted on Jun 14, 2009
  • 21 Answers
SOURCE: My Eureka Boss vacuum belt keeps breaking
How long hace you had your vacuum? THe belts on this vacuum are actually supposed to last a really long time. If the belts brake faster when your using the hose that impies your clutch which tightens and loosens your belt to keep the brush from spinning while the vacuum is upright couild be malfuntioning. If you post your serial number i can tell you if your still under manufacturers warranty.
Posted on Jul 23, 2009
  • 69 Answers
SOURCE: new eureka vacuum has not real suction
Is the belt slipping. Are all the seals good
Posted on Mar 27, 2010
Eureka 300 Light Upright Vacuum Cleaner Belt
the belt that broke should have a # on it.
Mar 04, 2013 | Eureka Vacuums
I need to know the correct belt for my Eurecka Boss 4870 Refurbished. Every time i put the belt on it brakes.
the correct belt for this machine comes in a package. It should be Eureka Style R belt. (61110-A)
Pic attached.
This is the correct belt. Anything else will just snap right away.
Good luck.
Nov 13, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
It smells like something is burning and then I saw smoke coming from the bottom, where the roller brush is.
That means that the belt is very worn and it is slipping on the motor. You need to replace the belt. Here is a link to the belts you need and a manual you can view with instructions:
Replacement Belts
Owner's Guide (3.4 KB download)
Dec 08, 2009 | Eureka Uno 2998AZ Bagless Upright Vacuum
Eureka Boss - Belt is not broke but brush will not turn. I have already turned it over - checked belt - and pushed the reset button.
The belt may look fine but they can still be stretched or worn and it won' turn the brush. Try changing the belt and see what it does. You can get Eureka belts here:
Eureka Replacement Vacuum Belts
Nov 07, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Metal Spring in Belt area?
Yes the metal spring is used to pivot one of the rollers in that area.
You would need to take it apart one more time and check to see if any of the roller travel up or down while you press it with your fingers. look to the edge on either side for a place to attach the end of a spring. then a place on the chassis to add the other end of the spring. Then redo the belt.
May 24, 2009 | Eureka 4700A Maxima Bagless Upright Vacuum
How to change belt on Eureka maxima 4700a
hey i had the same problem with mine, (standing over it and looking straight down) there should be two screws on the top of the yellow cover, one on each side, take those out and the yellow cover should easliy pop off. if the white ink is off the belt or the belt isnt tight than replace, once off just pop the wheel brush (which has the belt around it) up out of its socket and take off of the belt from the wheel brush and motor's metal pole, then put on the new one just like the old one was. let me know how it works out, redsox_belcher@yahoo.com
Jan 17, 2009 | Eureka 4700A Maxima Bagless Upright Vacuum
Eureka Altima is smoking!
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618889&thid=606496
Posted by saysay on May 18, 2008
Help! My vacuum is smoking. It won’t work anymore and starts to smoke as soon as it gets turned on.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Eureka Altima Upright Vacuum Model #2996AVS – it is probably doing 2 things, it could be the belt and or brushroll and the easiest ay to check is to remove the belt and see if the motor smokes, if the motor is fine then buy a new belt and check the brushroll to see if the brushroll spins freely, there are bearings in the brushroll and thread and hair get bound up in the ends and needs to be cleaned out. So #1, check the belt – no smoke from the motor then check the brushroll to see if it spins freely then changed the belt. If the motor smokes check your purchase date it may still be under the one year factory warranty from the dop. #2. Either clean or replace the brushroll and belt. If you have any further questions, feel free to contact your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don The Vac Man
Go Ahead. Use Us.
May 18, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Belts keep breaking
Check the brush roll ends to see if they have melted or frozen. They should turn freely, part #361869-1. Make sure the belt isn't being pinched somewhere.
Apr 15, 2008 | Eureka WhirlWind Litespeed 5844 Upright...
Smoking belt
Dec 22, 2007 | Eureka 2961AVZ Bagless Upright Vacuum
Eureka Capture Upright Vacuum Vacuum Logo
362 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
