Question about Dryers
I dried a burgundy comforter in my new dryer & the inside turned pink. How do I get it out & will it stain other loads, such as my whites?
  • 4 Answers
I recommend using Automotive Brake Cleaner and following up with mild dish soap . Dry with towel. Run dryer for 15 minutes with a few old but clean towels . If the stain is still visible but not on the towels then I would say that it would NOT stain you other clothes.
Posted on Apr 26, 2008
How do I get a pink stain out of my kenmore dryer drum after drying a burgundy blanket that stained it?
I've never had any luck, it won't hurt anything if that's any consolation.
Sep 27, 2015 | Kenmore Dryers
Strange yellowish circle appearing on white shirts
i believe the stains are actually semi burn marks. If you are drying your whites try a lower heat setting. i had this problem with my kenmore dryer before too. Got bad especially with towels. Make sure your vent is not clogged and your filter is cleaned regularly to let the heat flow better. should help.
Sep 17, 2007 | Whirlpool LER8648L Electric Dryer
Gray colored clothes after drying
Check the flue where the heat enters the dryer this the tube where the flame from the burner leads into the dryer you will have to take the back panel off and a few screws to remove tube forgot to ask is the inside of the tumbler drum stained
Mar 22, 2014 | Amana ALG331RAW Gas Dryer
No lint on filter? Where is it all going? Checked exhaust vent bought a vacuum attachment and there is no lint. Twice and sometimes triple the drying time! Help!
Instructions
  1. Dryer Does Not Run
    • 1 Close the door firmly. The dryer will not operate if the door is not completely closed.
    • 2 Press the "Start" button firmly or push the knob in to start the dryer.
    • 3 Turn the dial past the "Off" position and away from "Wrinkle Prevent." The dryer will not start in the "Off" or "Wrinkle Prevent" position.
    Long Drying Times
    • 4 Remove the lint screen. Clean it and replace it.
    • 5 Check the temperature of the room. The dryer will not operate properly in temperatures below 45 degrees Fahrenheit.
    • 6 Inspect the area around the dryer. It requires at least 1-inch clearance on the front and sides of the dryer. A 5-inch clearance is needed on the back of the dryer. Move the dryer, if needed.
    • 7 Separate large loads and do not use an air dry cycle.
    Lint, Stains and Wrinkles
    • 8 Clean the lint screen before drying each load of clothes to prevent lint buildup on clothing.
    • 9 Add fabric softener sheets before starting a drying cycle. If the sheets are added after the load has partially dried, they can leave stains on the clothing.
    • 10 Dry small loads and remove clothing as soon as the drying cycle completes to prevent wrinkling.
    Dryer is Noisy
    • 11 Check the inside of the dryer for loose change, buttons or other items. Empty the pockets on clothing before drying.
    • 12 Separate items that are knotted together and restart the load. Knotted or balled up clothing will bounce and make the dryer vibrate.
    • 13 Level the dryer. Turn the leveling legs on the front of the dryer clockwise or counter-clockwise until the dryer is level. Turning the legs clockwise will lower the dryer. Turning the legs counter-clockwise will raise the dryer.
Jan 15, 2013 | Admiral Dryers
The Dryer is Dead. It will not make a sound when the start button is pushed
Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or OK like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
If the vent doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket thermometer can be used for this. It should cycle approx between 120 degrees and 160 degrees ( without clothes ). Check that the drum seals are not worn out.
Be careful in using laundry products not to spill them on the exterior surface of any washer or dryer. Wipe up any spills promptly with a damp soft cloth or paper towel. Most exteriors are painted synthetic enamel, which can be damaged or removed by chlorine bleach, ammonia, solvents or other chemicals often used in laundering and stain removal. Do not use dryer top as a work-top for stain removal unless it is protected by a heavy plastic cover, or for rust removal. Use the sink instead and follow remover product label directions exactly, including flushing the sink with cold water.
Do not spray per-wash stain removers on clothing on top of the dryer unless the top is protected completely; this may corrode plastic control parts as well as paint.
Clean lint filter after each load for efficient drying. If the load is loaded with lint, clean the filter part-way through the drying cycle also. Clean out the exhaust vent system at least once a year, and be sure it is not clogged at any time. NEVER vent a dryer into the house; vent to the outside
If crayon gets into the dryer and melts onto the drum, remove as much as possible with non-flammable household cleaner. (READ LABEL TO BE SURE.) A flammable cleaner could cause a fire in the dryer. Apply cleaner to a sponge or cloth and the wipe interior. Do NOT spray or pour on the interior; it might get down inside the dryer. Wipe off with rags or paper towels. Then tumble old rags to remove any residue left, until no more comes off. A colored stain may remain on the drum.
If a drum is spotted by starched or tinted articles, wipe the interior with a cloth moistened with a diluted bleach solution. Use a sponge or clean cloth, dipped in suds, to remove the bleach solution from the drum. Rinse well and dry.
If the dryer is used to dry laundered clothing, such as children snow pants between outings, wipe the drum with suds and rinse. This will remove any dirt before clean laundry is placed into the machine.
Wipe the door opening occasionally. Clean the exterior with suds and rinse. To protect the finish, polish with an appliance wax.
A case of white clothes coming out of a dryer blue: New jeans had been washed and then dried in that dryer just before. Sometimes dye will come off new blue jeans and dry on the inside of the dryer drum, and then transfer to the next batch of wet clothes put inside. It's good to check the dryer drum after a load of brand new jeans. If it is dye coated, clean the inside with soapy water until no color comes off on the cleaning cloth. Wipe off all soapy residue with a clean wet cloth.
Check with your state or city to see if you need a permit to work on your gas dryer before doing any repairs. The first thing you need to do when your GE-HP gas dryer is not heating, is to check to see if your dryer ignite is glowing or not.
please comment on these solution by staying now helpful
If the ignite glows, the problem could be the gas valve, the coils or the gas supply to the dryer.
If the ignite doesn't glow, then you need to check the following parts.
The igniter:
The igniter is a resistor made of ceramic and other materials that will get red hot when electricity passes through it.
The job of the igniter is to open the contacts on the flame sensor and ignite the gas. A bad igniter could be the reason why your GE-HP gas dryer is not heating.
The flame sensor:
The flame sensor is located on the combustion chamber, the job of the flame sensor is to open the gas valve and shut off the igniter. A bad flame sensor will cause the dryer not to heat.
The timer:
The timer is a distribution center where the electricity is directed to the different electric parts in the dryer.
The mayor problem you will find inside of the timer are burnt contacts.
When the contacts are burnt, there is no way for the electricity to reach the intended parts. Contact B & A have to be close in order for the electricity to travel to the temperature switch.
The temperature switch:
This switch is another distribution control. It take electricity from the timer and send it to the selected parts on the thermostats. If your GE-HP dryer is not heating, this is one of the parts you need to check.
The thermostats:
There are three different thermostats in most dryers. From the temperature switch electricity has to pass trough the safety thermo left, the drum outlet thermostat, the control inlet thermostat, and to the heating elements.
A bad thermostat could be the reason why your GE-HP gas dryer is not heating.
The motor switch:
The motor switch has two contacts that allows the heating elements to be turned on, only when the motor is running..
Dec 21, 2010 | General Electric DBSR463GGWW Gas Dryer
Blue rubber glove in load stained dryer inside. How to clean?
take a boyyle of simple green solution, and get a clean rag, and this should take the stain off, after youwipe it down with this if it is coming off, wipe it down after with water, then dry it off with a clean rag, let me know if this gets it, it should thks larry
Apr 22, 2010 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Admiral 6.5 Cu. Ft. Super Capacity Electric Dryer not drying load
does the admiral aed4475tq have a reset button it will not turn on it is only 9 months old
Nov 29, 2009 | Dryers
Grease stains from Maytag MAV7200AWW washer
HI! I just posted a question to "justask.com" and am having the exact same problem. I paid $9 for this answer and was happy to pay it because I now know what it is! From what I have been told, it is from the transmission in your washer and will cost at least $400 to fix it (that's just a ballpark figure... I have a Frigidaire and that was the figure I was given). So, basically, it would be more cost effective for you to purchase a new washer.
Apr 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
HOW DO i REMOVE INK FROM THE INSIDE OF MY DRYER?
you really cant ,,i would just let it dry,,this is why,,because any product that will remove the ink will aslo remove the enamel,,and with out that coating ,,your chothes will get gray stains from the raw metal once the ink dryers it will not come even on the white clothes...
Jan 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Red t-shirt has run all over the wash. now have pink socks, pink backgrounds etc
did you dry any of this load in the dryer? If you did, the color is set you wont get it out.
If not rewash everything, Except the red t shirt! in the Hottest water the clothing can take. If its whites use a little bleach. you could also use a color safe bleach on colored items. You may want to divide up the load into similar items. Experiment what have you got to loose.
One time we washer a gray sweatshirt with a red sweatshirt, why the gray turned Pink! I dont know we line dried it and washed again, The pink came out.
Good luck
Oct 02, 2008 | Washing Machines
Dryers Logo
88 people viewed this question
Top Dryers Experts
