Question about Briggs & Stratton Garden
I wish to know where to get a free download manual for lawnmower Rover Wayfairer. Model No:31391. Briggs & Stratton Quantum XE 45. Would appreciate some help with this matter. Regards Edwin
  • 61 Answers
SOURCE: 5hp briggs & Stratton lawnmower
ck fuel pump its on the side of the carb
3or4 screws hold cover on .
Posted on Sep 06, 2009
rwvanlue
  • 486 Answers
SOURCE: Briggs & Stratton 6.75 lawnmower. Won't start.
1) Determined that there is spark?
2) Have you used a type of spark tester?
3) What is the condition of the plug. Brown or dark brown is OK. Black or silver is NOT Ok.
*If you do not have a spark tester,
a) remove the plug, and with it connected to the wire,
b) find a portion of metal around the cylinder that you can ground it on, and then pull the rope.
c) If the plug is black, you may see spark, but you should replace the plug.
*** PLEASE NOTE ; if there is excess fuel in the cylinder or on spark plug,
it can catch fire, so be carefull to cover the hole with a heavy rag so that any fuel
cannot be exposed to spark plug durning test !!!!
Get back with me on how this issue works out.
thanks, rwvanlue
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your local lawn & garden dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 26, 2009
  • 2841 Answers
SOURCE: briggs and stratton lawnmower engin the exhaust
Sounds like it is running too rich on fuel. Try resetting the carb adjustment screws. Turn them in until it starts to stall and them turn the screw back out 1/4 turn. It may also be a partially clogged muffler or the screen on top of the engine may be clogged. In rare instances it may need the valves adjusted.
Posted on May 01, 2010
  • 10 Answers
SOURCE: Lawnmower timing settings needed
yep
Posted on Jul 25, 2010
SOURCE: I have a Brute by Briggs Stratton 21hp driveable
JUST RAISE THE MOWER TO HIGHEST POSITON TO ALLOW YOU ACCESS TO BLADES
REMOVE BOLT AND BLADE AND INSTALL NEW OR SHARPENED BLADE
ENSURE IGNITION SWITCH IS OF
Posted on Sep 02, 2011
How to adjustment static governor on a quantum xe 40 briggs and Stratton lawnmower please thanks Robin
1. Move throttle control to wide open throttle position,
Fig. 45.
2. Loosen lever adjusting screw. Item 8
3. Turn governor crank counterclockwise and hold.
4. Torque lever adjusting screw to 15 in. lbs. (2 Nm.).
Mar 31, 2015 | Garden
Manual for briggs and stratton 12000 series mowers quantum
B/S makes the motors for several brands of mowers. Go to the web site and search your model for a download.
Oct 07, 2014 | Briggs & Stratton Quantum Lawn Mower...
Qualcast 46SP manual required
I do not know where you can get a free manual for this. If it is Briggs and Stratton. You can try http://www.briggsandstratton.com/us/en/support/manuals/engine You will have to have the model type and trim (they call it) If that is no help and it is briggs contact them Monday - Friday 1-800-444-7774.
Jun 24, 2014 | Briggs & Stratton Briggs Stratton...
Craftsman owners manual model 944.362400
SearsPartsDirect they may have one you can download if not try PartsTree.com
May 08, 2014 | Briggs & Stratton Briggs Stratton...
Rover mowers manuals
Did you air to blow all holes in carb out?
Mar 01, 2014 | Briggs & Stratton Garden
Garden Logo
120 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
