Question about Sanyo Televison & Video
The picture on my 42" SANYO lcd tv comes on briefly but then goes out--the audio works fine
  • Sanyo Master
  • 3,866 Answers
The cause of you tv blacklight comming on then going out is a bad inverter board, the issue here is simple have a new inverterboard put in the part is only like $40-60 bucks pretty straight forward and easy to put in if you know what your doing. A local shop will take around $150 of your hard earned cash if you had it done professionally. So you might want to get a service manual and the part and do a DIY repair and save big. We can help you with this if you start a chat with us when you got the part in order. We also have phone support.
Hope to see you soon.
please do click the accpet button as you solution has been delivered.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Aug 05, 2010
I have a 42" sanyo LCD TV. There is audio but no picture. There are no backlights but I can see an image on the screen with a flashlight. Can you help me?
Common issue, you have some shorted LED lamps in the panel and will need to be replaced, the LED driver section of the power supply is shutting down after a second or so because of over current, chances are its not a board issu
Apr 03, 2018 | Sanyo Televison & Video
Hi I have teviono 42" lcd4203id model and tv is white picture nothing on there the TV powers up light comes on but it doesn't bring picture what the fault would be?thanks
TEVION 42" FLAT SCREEN LCD TV MODEL LCD4203ID
www.ebay.co.uk/.../TEVION-42...TV-MODEL-LCD4203ID-/1213...
eBayTEVION 42" FLAT SCREEN LCD TV MODEL LCD4203ID in Sound & Vision, Televisions ' eBay.Missing: white
main board for tevion lcd4203id 42" lcd tv mhdv4201 ... - eBay
www.ebay.co.uk > ... > Other TV & Home Audio Accs.
eBayMAIN BOARD FOR TEVION LCD4203ID 42" LCD TV MHDV4201-ZC01-01 (B) ... Mouse over image to zoom .... *Please open the back cover of TV then check the part number of screen, it would be on white label at back of screen ... of actual item in yourTV as well as check either if it is compatible with your TV model.
LCD TV Repair made easy # 1 - YouTube
? 7:38
https://www.youtube.com/watch?v=GryA_Zl4EBk
Aug 27, 2009 - Uploaded by Grants Pass TV Repair
I have a 2008 model Sanyo dp42848 42' lcd tv with ccfl lighting. .... bought a Seiki tv and within 1 month ...
LG 42LC2D 42 in. LCD HDTV Fusing unit - Que
Dec 29, 2015 | Televison & Video
My 42" Sanyo LCD TV which is 4 years old no longer
This is not a user repairable fault. Should be checked from its main power regulator board, and is a skilled work. Actually this is a repairable fault, but can do only by any technicain.
Jul 11, 2013 | Televison & Video
Sanyo dp42849 tv blinks on then off has sound.was working fine?
If sound stays on and doesn't goes off then you need the video logic main board, if the audio goes out, it maybe the power supply
Dec 07, 2010 | Sanyo DP42849 42 in. HDTV
Sanyo 42" LCD will not turn on!!!
Power supply board is dead.Buy a refurbish power supply board at Shopjimmy.com,Ebay.com for the replacement.
Mar 26, 2010 | Sanyo 42 in. LCD TV
Sanyo Sound going in and out
the first thing you should try is to connect exturnal speakers, if they work fine, then use them, as the wireing harness has a bad solder joint (inside the TV) you will need to go to yoru onscreen menu to activate the exturnal speakers. If this still occurs, then there is a major inturnal fault, with luck it is still under warrenty, otherwise it will be costly to fix. Due to teh high number if flatscreen failures I and other tech friends of mine have run into, we all agree this is the one case where extended warrentys are well worth the investment.
Feb 08, 2010 | Sanyo DS27800 27" TV
Sanyo 42" lcd tv
use a spike guard from next time
Oct 18, 2008 | Sanyo DP32746 32 in. LCD Television
Televison & Video Logo
20 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
