Question about Refrigerators
GE side by side 26 cu ft and there is frost build up on the ice dispenser inside the freezer and also frost build up at the auger that feeds the ice into the door.
  • 2,272 Answers
Check the water Passing line.Is it frozen or clogged.Check out.also check the solenoid valve is it having power or no power.Also check the fan in the freezer section .Is it running or not running.Also if not getting a seal on that flap. It sounds as if it may be warped. THe reason the frost and ice is building up is due to the flap not sealing there.If all checked ok then its faulty timer or main board. The Defrost system consists of a defrost timer a defrost limit and a heater. On newer GE's the defrost cycle is controlled by the motherboard on the back. Also try manual defrost before doing any other troubleshooting. Unplug the unit.wait for 24 hrs.keep the units door open and empty the unit.after 24 hours connect the power to the electric outlet and set the temperature to normal settings.check out after 3-4 hours.If the problem solves then manual defrost helped.if not then the above mentioned parts needs to be checked and replaced as per faulty/.to get required parts you can get it from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 05, 2010
Freezer thermastat is stuck and ice dispenser clogged, how to fix the problem
Check rear of the freezer for frost , If you have frost there you will need to service the defrost circuitry. More times than not the defrost heaters are the problem
Aug 02, 2014 | GE 25.2 cu. ft. Side-by-Side Refrigerator...
The ice maker will not dispense any ice. When the dispenser lever on front panel is pushed the dispenser door opens but the auger motor does not operate. If I thaw the freezer the auger motor will...
It sounds like your auger motor has an issue in my opinion. How i check them is: remove ice bin, open freezer door, hold door switch down, depress the freezer ice dispenser button on the door and see if the auger motor has the torque when it turns, if the motor has power and turns but cant turn w/ torque or has power and dosen't turn. you need a new auger motor. lmk if u need more help!
Aug 04, 2013 | Frigidaire FPUS2686LF Professional 26 Cu....
Ge Profile Stainless Steel 26 ft Refrigerator ice maker dispenser
try pulling out the ice bucket, remove all ice and look for signs of damage on the auger mechanism... most of the time the ice tends to clump up and that prevents the auger from moving freely.
Mar 24, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Frost buildup inside freezer door at ice dispenser
you are still not getting a seal on that flap. It sounds as if it may be warped. THe reason the frost and ice is building up is due to the flap not sealing there isn't any other reson for your problem. Good luck on your repairs
Dave
Oct 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice dispenser frost build up - Amana refrigirator
This sounds like your ice may be melting and freezing around the chute. You may need to replace that rubber gasket on the chute. Otherwise, if you use a lot of crushed ice, that will build up badly on the chute and you can manually clean that off. I hope this helps you!
Aug 14, 2009 | Amana 25.8 cu. ft. Side-by-Side...
GE profile Artica side by side. I am getting a frost build up
Sounds like the dispensor flap is not closing completely , pulling outside air in . Using a flashlight on the outside of the flap , look inside to see if any light is visible . If so , then the ice flap plunger and solenoid will have to be replaced . Also , excessive crushed ice can also cause frosting .
Jul 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Frost build up around ice dispenser in freezer
Suddenly having the same problem. Any solution?
May 16, 2009 | Amana 25.8 cu. ft. Side-by-Side...
Frost gathering in freezer, icemaker dispenser freezes over
well check to see if door seal is split if it is get new one!! need to see photo of the frozon over dispenser- found before that when ice not bein used alot the odd time you will have to take out the ice in the bucket crack it up and put back in try this???
Feb 03, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker dispenser and frost
outside moister cause making frost, probably you can not do it youself,if you know , do it.
Jun 17, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
