Question about KitchenAid KGYS750LQ Gas Dryer
No heat, dryer works fine otherwise - KitchenAid KGYS750LQ Gas Dryer
  • KitchenAid Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
l'l'
Posted on Mar 04, 2011
Drier has no heat. Seems to run fine, otherwise. might I nee d to re-light the pilot through the small hole in the front of it?
heatman101
Jan 24, 2011 | Kenmore 60172 Electric Commercial Dryer
The dryer no longer heats up and the timer no longer turns the dryer off .. .... the dryer works fine otherwise ... it is a gas dryer.
heatman101
Dec 29, 2010 | Dryers
No Heat
before working on any appliance-be sure to unplug it to keep from getting shocked & damaging your appliance
problem-runs but will not heat
1.loose wiring-check terminals & wiring
2.defective thermostat
3.defective centrifugal switch in motor(check linkage to motor)
4.defective timer-replace timer
5.open heater element--replace
Jul 27, 2010 | LG DLE3777 Electric Dryer
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
Whirlpool dryer model LER4634J...will heat fine for 3 or 4 loads in a row, then may not heat for a couple cycles. then work fine again. when i run it i use the heavy/60 min. cycle. when it drys it works...
possible timer, or electrical issue in wall receptacle.be sure wall venting is perfectly clear w/no hinderance to air movement whatsoever .try removing vent hose off dryer for a couple of loads,to bypass venting completely just for testing. otherwise the safety thermostats or cycling t-stats may be in question
Nov 12, 2009 | Whirlpool LER4634J Electric Dryer
My Frigidaire gas dryer isn't hot. Otherwise it runs fine.
it could be either your ignitor(glow coil) flame sensor control, or a defective thermal switch telling dryer its at temp and shutting off gas supply before it even fires initially
Oct 17, 2009 | Dryers
Dryer not heating up
it sounds like your thermostat located near the heater check with multimeter
Jun 24, 2009 | Frigidaire FullFGX831C Size Stack Gas...
Dryer will not heat but works fine otherwise
Could be problem with timer contact for the heaters.
Aug 04, 2008 | Whirlpool LEQ9858P Electric Dryer
Maytag dryer giving heat only for shor time
if heat works, and vent is definitely not an issue, i would look to replacing the valve coils(279834), the coils heating up and not allowing the valve to re-open on subsequent tries through length of cycle. $20 repair
Mar 03, 2008 | Maytag MDG9606 Dryer
KitchenAid KGYS750LQ Gas Dryer Logo
141 people viewed this question
Top KitchenAid Dryers Experts
Tim Whalen
Oloyede Monsuru
Virgil Watts
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
